RE: Extra 260 27% Hangar 9er
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Extra 260 27
  • 3 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> 3D Flying! >> RE: Extra 260 27% Hangar 9er
    Page: <<   < prev  129 130 131 132 133 134 135 [136] 137 138   next >   >>
    Login
    RE: Extra 260 27% Hangar... - 5/19/2008 10:35:47 PM
    root
    Status: offline
    I just ordered this plane and it's on backorder till mid-June.
    I have patiently read thru 37 pages of this thread and skipped ahead, hoping that the gear issue was resolved by this page.
    Before that, I put a call into Horizon asked if the new batch has a "fix" for this ongoing problem. I'm awaiting a response and have my fingers crossed.
    Meanwhile, can you tell me what the general consensus is as far as servo choice and is the previous recommendation of rudder reinforcement still necessary?
    < Message edited by root -- 5/19/2008 10:54:34 PM >
    _____________________________
    "I should have zigged instead of zagged"
    (in reply to 3-D Flyer)
           Post #: 3376
    RE: Extra 260 27% Hanga... - 5/20/2008 8:35:07 PM
    tkapfer
    Status: offline
    No, they have not fixed the landing gear issue. I just purchased my kit in late March early April and just had this problem with it delaminating after about 8 flights. I put the aluminum gear on and have not had any problems. Although it is a little more weight than the cf gear. My plane comes in just over 16 pounds anyway, but I'm not stressing it with all the 3D, so it should be fine. With the DA50 motor and the MTW 75K cannister muffler, it sounds way cool and is very quiet.
    I reinforced my rudder with the c/f rod as you've seen previously. I did not have the problem before reinforcing the rudder, and have not had any problems since. I guess it's better to be safe than sorry.
    I have JR DS8711 servos all the way around except for the throttle.
    One of the really good flyers at our field said that those servos worked GREAT, very fast and responsive. He said it almost makes him want to go out and get one of these kits as well. Although using that size servo does force you to sand out each mounting hole to make room.
    Have fun. Decisions, decisions, decisions.
    (in reply to root)
           Post #: 3377
    RE: Extra 260 27% Hanga... - 5/21/2008 3:24:10 AM
    jfeenin
    Status: offline
    Those with DA-50's what Tygon tubing size are you using? Neither the DA-50 manual nor the H9 manual say specifically. Will the small size work OK?
    Joe
    http://starbase4.com/
    (in reply to tkapfer)
           Post #: 3378
    RE: Extra 260 27% Hanga... - 5/21/2008 3:52:21 AM
    tkapfer
    Status: offline
    I'm using 1/8 Tygon. I also have tied off all the ends with the small wires you can buy in packs.
    I also soldered ridges around the fittings on the brass tubes on the fuel tank and tied with wires so they will not slide off (inside and outside the tank).
    So far everything has worked great with no leaks.
    (in reply to jfeenin)
           Post #: 3379
    RE: Extra 260 27% Hanga... - 5/21/2008 4:02:26 AM
    jfeenin
    Status: offline
    Thanks, that's what I was afraid of. I started with that but didn't have enough so I went and got more but just asked for the small size thinking that's what I had, it wasn't. The smaller fit the fuel tank better but not the engine, the larger fit the engine and my DA filler stop better but wasn't as snug on the tank side. I also did the solder and wire ties but now I will have to take the tank apart again and put the larger back, oops!
    Joe
           Post #: 3380
    RE: Extra 260 27% Hanga... - 5/21/2008 4:24:20 AM
    root
    Status: offline
    Ah yes, the extra work sucks the big one but that peace of mind, money can't buy..... and be glad you were smart enough to ask.
    Check out the response from Hangar 9 regarding the ongoing landing gear delamination:
    > Bob,
    > Thank you for your e-mail.
    > I would guess that whatever issue might have existed on the
    > Hangar 9
    > Extra 260 landing gear has been corrected.
    > If you have any additional questions, please reply to this e-
    > mail or
    > contact us toll free at (877)504-0233.
    > Sincerely,
    > Horizon Hobby Product Support
    I wrote them again and attached a picture - stating it hasn't been "CORRECTED"
    Still no response......Go FIGURE.
    root
    ps One friend's recommending the Hitec 5985's
    One says the 5625's are good enough for the A&E and the 5645 for the rudd.
    What does anyone think of those apples?
           Post #: 3381
    RE: Extra 260 27% Hanga... - 5/21/2008 4:24:29 AM
    GTworks
    Status: offline
    quote:
    ORIGINAL: jfeenin
    If your going to take it apart you should change the piping too! The supplied piping isnt 1/8 id.
           Post #: 3382
    RE: Extra 260 27% Hanga... - 5/21/2008 4:34:16 AM
    GTworks
    Status: offline
    quote:
    ORIGINAL: jfeenin
    Also since your taking it apart ...go to your local weedwhacker supplier and ask for walbro part #125-527-1! youll be happy you did!
           Post #: 3383
    RE: Extra 260 27% Hanga... - 5/21/2008 10:12:46 AM
    cmoulder
    Status: offline
    quote:
    ORIGINAL: GTworks
    quote:
    ORIGINAL: jfeenin
    I like the felt clunks, but if you use a "T" fitting and a fuel dot that will prevent junk from getting into the tank, but it just goes straight to the engine! What I do is use a felt clunk inside the 2-gal fuel jug, then I use an in-line filter between the fuel dot and the "T" fitting. That way the fuel is thoroughly filtered before it even gets to the tank. Also, use an in-line filter on the vent line, because there is a little negative pressure there and it could eventually suck in some debris.
    -- Bob
    (in reply to GTworks)
           Post #: 3384
    RE: Extra 260 27% Hanga... - 5/21/2008 1:02:10 PM
    jfeenin
    Status: offline
    quote:
    ORIGINAL: GTworks
    I noted that as well, thanks for that confirmation too.
    < Message edited by jfeenin -- 5/21/2008 1:05:33 PM >
    Joe
           Post #: 3385
    RE: Extra 260 27% Hanga... - 5/21/2008 2:35:00 PM
    tkapfer
    Status: offline
    I have not done the following yet, but was told by one of my club flyers (who is really good), said to do the following:
    When you take back apart your fuel tank, on the inside, the line leading to the clunk cut in half, then insert a piece of brass tubing and put the line back together again.
    He said this helps if you are into some strong aerobatics or 3D it prevents the clunk from folding all the way around and possibly getting stuck in the front of the tank. Where it may not pick up well, since the line would be folded over. He said he has seen that happen before and then the engine shuts off. Not to good he said if you're hovering 15 feet off the ground.
           Post #: 3386
    RE: Extra 260 27% Hanga... - 5/21/2008 2:41:47 PM
    jfeenin
    Status: offline
    Just be sure to solder and wire wrap that middle tube too. I have heard the same advice although I am not (despite the parent topic this thread is under) planning on doing violent 3D myself. Then again there is always the "unplanned" 3D that happens sometimes.
    Joe
           Post #: 3387
    RE: Extra 260 27% Hanga... - 5/23/2008 2:44:00 PM
    jerrysu29
    Status: offline
    I have been flying all out 3D since 1999 and never heard of this problem. I have
