cmoulder
NY, USA Status: offline
IMHO the 5645 is not robust enough for the rudder, and also that particular servo has a little too much slop at center. And once the oscillation starts, 4.8 volts doesn't have enough power to hold it. I had a big problem with elevator and aileron flutter on a AW Yak (50cc) with these servos, completely solved by using 5955's. So if the linkage is otherwise solid and tight, I would wager that going to 6 volts and using a 5955 (or something with a similar high torque rating) would solve the problem. Recently 5955's were on sale at TBM for $89, which is a very good price (making room for the 7955!). The 5955's have very little slop at center. I don't know your brand of Rx, but it should be able to handle 6 volts with no problem. However, if you use a Li-Ion or LiPo you will need a voltage regulator between the switch and the Rx. SmartFly regs are pretty good.
_____________________________
-- Bob
