RE: Extra 260 27% Hangar 9er    Gallery
Logged in as Guest
    Search This Thread
Printable Version
ParkZone F-27Q Stryker - RTF
Seller:  nrthwing
Details:   $150.00   |  6/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> 3D Flying! >> RE: Extra 260 27% Hangar 9er
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Extra 260 27% Hangar 9er - 4/4/2005 1:40 AM
BARCC
Score: 100
Last Login: 7/17/2005
Status: offline
Would this plane be better with glow or gas, with that new Saito 2.20, will it be a gas hog? Thanks!!
_____________________________
Member of BARCC; Blennerhassett Area Radio Control Club, website: www.barcc.us please check it out!!
Hide Signatures
(in reply to PepsiMike)
       Post #: 26
RE: Extra 260 27% Hangar 9er - 4/4/2005 2:35 AM
Banche
Score: 105
Last Login: 2/18/2007
Status: offline
It sure wouldnt be cheap and from my experiences with my saito 100, it would bbe dounright expensive, I pay the price on my funtana 90 that I fly soo much and I am only 15, 30% is too darn expensive!!!
but the da 50 would be cheap fuel wise, I wonder how much the evolution is and whats it's weight and thrust compared to the DA 50?
anyone know
Hide Signatures
(in reply to BARCC)
       Post #: 27
RE: Extra 260 27% Hangar 9er - 4/4/2005 4:15 AM
BARCC
Score: 100
Status: offline
heres the specs on the evolution 58 gasser:
Type: 2-stroke Gasoline
Displacement: 3.6 cu in (58.188 cc)
Bore: 42 mm (1.65 in)
Stroke: 42 mm (1.65 in)
Cylinders: Single
Engine (Only) Weight: 1820 g (64.42 oz)
Crankshaft Threads: M10 x 1.25 mm
Benchmark Prop: Mejzlik 24 x 10 @ 6,900
Prop Range: 22 x 10 - 26 x 10
RPM Range: 1,000 - 7,500
Fuel: Oil w/Gasoline mix 1:40
Mounting Dimensions: 243 x 78 x 140 mm
HP: 8.5 hp @ 6950 rpm
Cylinder Type: Ring
Starting System: Electronic Ignition
Carb Type: Walbro
Crank Type: Ball Bearing
and heres the DA50 gasser specs:
Displacement: 3.05 ci. (50cc)
Output: 5 hp
Recommended Props:
2-blade: 22x10, 22x12, 23x10, 24x8.
3-blade: 20x10, 20x12, 22x10 narrow.
Weight: 2.94 lbs (3.13 lbs with stand-off mounts)
Length: 6.7" (170mm) (total with stand-off mounts)
Bore: 1.6771" (42.6mm)
Stroke: 1.3779" (35mm)
Reed valve.
Desert Aircraft auto advance electronic ignition.
Exclusive Desert Aircraft designed cylinder, piston, rod and crankshaft.
CNC milled 7075 alloy crankcase.
But heres the thing, the DA is $50 cheaper, but as you may have noticed, the evo has more power, but this engine will come out in may, but the plane will be out for a month before the evo!! Plus, we already know that the DA50 is reliable, and we know nothing about this evo
< Message edited by BARCC -- 4/4/2005 4:17 AM >
Hide Signatures
(in reply to Banche)
       Post #: 28
RE: Extra 260 27% Hangar 9er - 4/4/2005 4:21 AM
drumbum
Score: 110
Last Login: 4/14/2013
Status: offline
4LBS its a a heavyweight.. looks like fuji/ Zenoah territory.. stick with the DA
Lee Durham,
http://lee3d.tripod.com
Hide Signatures
(in reply to BARCC)
       Post #: 29
RE: Extra 260 27% Hangar 9er - 4/4/2005 4:23 AM
David_Moen
Score: 100
Last Login: 6/22/2009
Status: offline
I think that the 58 would push the wing-loading up too far. In the MVVS line (manufacturers of Evolution) the new 45cc engine would be a better choice. The 45 is a pound lighter than the 58 with a wide, flat power curve. Factory numbers suggest that this engine is competitive with other European 60s!
http://www.mvvs-canada.com/products.php?cat=2
I only wish they gave this plane an 80" wing span so it would qualify for "Big Bird" and IMAA events!
David Moen
www.mvvs-canada.com
Hide Signatures
(in reply to BARCC)
       Post #: 30
RE: Extra 260 27% Hangar 9er - 4/4/2005 4:28 AM
BR289
Score: 100
Last Login: 11/13/2012
Status: offline
I always thought that 1/4 scale and up did qualify for IMAA legal size (?)
Blair
Extreme Flight
Aircraft International
Hide Signatures
(in reply to David_Moen)
       Post #: 31
RE: Extra 260 27% Hangar 9er - 4/4/2005 4:32 AM
drumbum
Score: 110
Status: offline
i think this plane is 20% or 22
Lee Durham,
Hide Signatures
(in reply to BR289)
       Post #: 32
RE: Extra 260 27% Hangar 9er - 4/4/2005 4:53 AM
BR289
Score: 100
Status: offline
Its advertised as a 27%
Extreme Flight
Hide Signatures
(in reply to drumbum)
       Post #: 33
RE: Extra 260 27% Hangar 9er - 4/4/2005 5:39 AM
Banche
Score: 105
Status: offline
So u are gonna compete with it?
anywais I think I will stick with the DA 50, I seems to me that lighter is better, I think that it could pull the plane around very well for how much the plane weighs, I never really liked the look of the evolutioin engines and thought that they weighed alot and were underpowered.
do you think that Hitec's 5645 digitals will be enough for this monster.
Hide Signatures
(in reply to BR289)
       Post #: 34
RE: Extra 260 27% Hangar 9er - 4/4/2005 6:52 AM
drumbum
Score: 110
Status: offline
quote:
ORIGINAL: BR289
My bad ,, i wouldnt have thought it, but then again the H9 33% is in the 96" range so that sounds right.. Good point
Lee Durham,
Hide Signatures
(in reply to BR289)
       Post #: 35
RE: Extra 260 27% Hangar 9er - 4/4/2005 8:27 AM
ROMANBM
Score: 100
Last Login: 9/17/2006
Status: offline
Hi guys my VON EXTRA 260 is legal for IMAC . This one is 35%
Click to see fullsize image.
Click for fullsize
Click for fullsize
http://WWW.ROMANBUILTMODELS.COM
VON EXTRA 260 35 %
Hide Signatures
       Post #: 36
RE: Extra 260 27% Hangar 9er - 4/4/2005 11:19 AM
Doug Cronkhite
Score: 105
Last Login: 6/18/2013
Status: offline
The Extra 260 had a wingspan of 24' so at 78" the scale is 27.08%
Doug Cronkhite
Hide Signatures
(in reply to ROMANBM)
       Post #: 37
RE: Extra 260 27% Hangar 9er - 4/4/2005 3:49 PM
BARCC
Score: 100
Status: offline
Horizon doesnt want to admit that the evolution gassers are made by MVVS, cause when I called them they were getting mad, becasue I said they were MVVS, and he said that they were evolution factory, made not MVVS
Hide Signatures
       Post #: 38
RE: Extra 260 27% Hangar 9er - 4/4/2005 4:10 PM
drumbum
Score: 110
Status: offline
quote:
ORIGINAL: ROMANBM
big difference, this plane is $379 that one is $2000 ..
Lee Durham,
Hide Signatures
       Post #: 39
RE: Extra 260 27% Hangar 9er - 4/4/2005 5:36 PM
Banche
Score: 105
Status: offline
and who wants to cover it anyways?
the scheme on the h9 is col enough, it could of been a little more agressive though like on the show time 4d, I dont want to think abotut the sfg's though.
Hide Signatures
       Post #: 40
RE: Extra 260 27% Hangar 9er - 4/4/2005 8:13 PM
drumbum
Score: 110
Status: offline
quote:
ORIGINAL: Banche
Me,, I would rather build it too ,, but not a $950 kit.
Lee Durham,
Hide Signatures
       Post #: 41
RE: Extra 260 27% Hangar 9er - 4/5/2005 2:32 AM
ROMANBM
Score: 100
Status: offline
My airplanes are like the lamborgini of the industry. They are for the select few willing to pay the extra price for an excellent quality airplane made especially for the customer in any color they choose. Special care and consideration is put into building my airplanes with extreme attention to details. So if you choose to have an airplane at a lesser value know that you get what you pay for.
Roman Scarfo
Builder and Pilot since 1987
VON EXTRA 260 35 %
Hide Signatures
(in reply to BARCC)
       Post #: 42
RE: Extra 260 27% Hangar 9er - 4/5/2005 5:11 AM
BTerry
Score: 115
Last Login: 1/1/2013
Status: offline
BANCHE: If lighter is better, why not cut off at least a pound or more and go with an OS 1.60FX or Moki/Mark 2.10? They would save a lot of money, a lot of weight, put out plenty of power, and the plane would certainly land better and perform the slow 3D stuff much better. The DA50 is probably better suited for planes with a bit more wing area. Also, the Extra 260 was the plane Patty Wagstaff flew until the mid 90's in competition, and that is the plane she donated to the Smithsonian. See attached pic.
BARCC: Are you experiencing technical difficulties, or trying to exaggerate your point (triple post)? You are probably right that MVVS makes the engines, but perhaps Horizon has tweaked the design a bit? I don't know anything about this, but I do have an idea how much it would cost to set up an engine manufacturing plant. It would be much cheaper to design an engine and hire a manufacturer to produce it.
ROMANBM: You are absolutely correct, excellent-quality and special consideration command a premium price. To be honest, I wonder how you can afford to sell your planes at your price given the quality of the craftsmanship and the amount of work and time going into each one. I have owned a couple of custom-built planes and they are truly head-and-shoulders above the high-quality ARFS I have owned. I have a custom-built 27% Cap 232 with 1250 in^2 wing area, ZDZ40, that weighs 12lbs and is a tremendous plane, lands slower than many trainers. It is 2.5# lighter and 300 in^2 larger than my Hangar 9 Cap 232 was. It had a tremendous amount of power but was scary to land.
This plane looks very nice and would be quite a performer. It has great lines and probably won't have many coupling problems. I like the plug-in wings and hatch. Hangar 9 is now getting much better at building light planes, and this one will probably continue the tradition.
Anyway, I look forward to some flight reports!
Brett
Click for fullsize
Hide Signatures
       Post #: 43
RE: Extra 260 27% Hangar 9er - 4/8/2005 3:23 AM
Banche
Score: 105
Status: offline
I cant wait for the ef yak, the extra and the st 4d from h9. they all are not for sale yet and they are the three that I want!!!
Hide Signatures
(in reply to BTerry)
       Post #: 44
RE: Extra 260 27% Hangar 9er - 4/8/2005 4:01 AM
BR289
Score: 100
Status: offline
Greetings,
I think most people are thinking Gas because of the cost of running a large 2-stroke, compared to regular gas ( even at todays prices ).
I am thinking of putting a F.P.E. 2.4 in mine when it comes in.........should be plenty for "Sport Flying", and economical too.
Blair
Extreme Flight
Hide Signatures
       Post #: 45
RE: Extra 260 27% Hangar 9er - 4/9/2005 5:25 AM
Banche
Score: 105
Status: offline
yes gas!!!! a saito that big is almost as expensive as the DA 50 and has less power, more mess and more price, by far!!!!!!!
Hide Signatures
(in reply to BR289)
       Post #: 46
RE: Extra 260 27% Hangar 9er - 4/9/2005 8:18 AM
BoneDoc
Score: 100
Last Login: 4/18/2011
Status: offline
How about the new 52 cc Revolution by Brisson? It weighs only 3 lbs, compact, and has 28 lbs of thrust... yeah baby!!!
Josh
Hide Signatures
       Post #: 47
RE: Extra 260 27% Hangar 9er - 4/9/2005 9:11 AM
BR289
Score: 100
Status: offline
It seems to me that anything 3lbs and under is fine......since the DA 50cc is 2.94lbs.
Extreme Flight
Hide Signatures
(in reply to BoneDoc)
       Post #: 48
RE: Extra 260 27% Hangar 9er - 4/9/2005 3:19 PM
50%plane
Score: 115
Last Login: 4/22/2013
Status: offline
The 260 is one of the best planes for both precision and 3D. Extra only made 6 I believe. Those who flew it in the United States had to go through extensive paperwork to legally fly it in competition due to it never passing FAA standards-it was to hot.
Model Airplanes don't kill people. Chuck Norris kills people.
Christopher A. Todd AMA# 637636
Hide Signatures
(in reply to BR289)
       Post #: 49
RE: Extra 260 27% Hangar 9er - 4/9/2005 3:24 PM
BoneDoc
Score: 100
Status: offline
what do you mean by "too hot?"
Josh
Hide Signatures
(in reply to 50%plane)
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.813RCU1
