RE: Extra 260 27% Hangar 9er
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Extra 260 27
  • 2 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> 3D Flying! >> RE: Extra 260 27% Hangar 9er
    Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
    Login
    RE: Extra 260 27% Hangar 9er - 4/3/2005 10:40:28 PM
    BARCC
    Status: offline
    Would this plane be better with glow or gas, with that new Saito 2.20, will it be a gas hog? Thanks!!
    _____________________________
    Member of BARCC; Blennerhassett Area Radio Control Club, website: www.barcc.us please check it out!!
    (in reply to PepsiMike)
           Post #: 26
    RE: Extra 260 27% Hangar 9er - 4/3/2005 11:35:37 PM
    Banche
    Status: offline
    It sure wouldnt be cheap and from my experiences with my saito 100, it would bbe dounright expensive, I pay the price on my funtana 90 that I fly soo much and I am only 15, 30% is too darn expensive!!!
    but the da 50 would be cheap fuel wise, I wonder how much the evolution is and whats it's weight and thrust compared to the DA 50?
    anyone know
    (in reply to BARCC)
           Post #: 27
    RE: Extra 260 27% Hangar 9er - 4/4/2005 1:15:03 AM
    BARCC
    Status: offline
    heres the specs on the evolution 58 gasser:
    Type: 2-stroke Gasoline
    Displacement: 3.6 cu in (58.188 cc)
    Bore: 42 mm (1.65 in)
    Stroke: 42 mm (1.65 in)
    Cylinders: Single
    Engine (Only) Weight: 1820 g (64.42 oz)
    Crankshaft Threads: M10 x 1.25 mm
    Benchmark Prop: Mejzlik 24 x 10 @ 6,900
    Prop Range: 22 x 10 - 26 x 10
    RPM Range: 1,000 - 7,500
    Fuel: Oil w/Gasoline mix 1:40
    Mounting Dimensions: 243 x 78 x 140 mm
    HP: 8.5 hp @ 6950 rpm
    Cylinder Type: Ring
    Starting System: Electronic Ignition
    Carb Type: Walbro
    Crank Type: Ball Bearing
    and heres the DA50 gasser specs:
    Displacement: 3.05 ci. (50cc)
    Output: 5 hp
    Recommended Props:
    2-blade: 22x10, 22x12, 23x10, 24x8.
    3-blade: 20x10, 20x12, 22x10 narrow.
    Weight: 2.94 lbs (3.13 lbs with stand-off mounts)
    Length: 6.7" (170mm) (total with stand-off mounts)
    Bore: 1.6771" (42.6mm)
    Stroke: 1.3779" (35mm)
    Reed valve.
    Desert Aircraft auto advance electronic ignition.
    Exclusive Desert Aircraft designed cylinder, piston, rod and crankshaft.
    CNC milled 7075 alloy crankcase.
    But heres the thing, the DA is $50 cheaper, but as you may have noticed, the evo has more power, but this engine will come out in may, but the plane will be out for a month before the evo!! Plus, we already know that the DA50 is reliable, and we know nothing about this evo
    < Message edited by BARCC -- 4/4/2005 1:17:43 AM >
    (in reply to Banche)
           Post #: 28
    RE: Extra 260 27% Hangar 9er - 4/4/2005 1:21:01 AM
    drumbum
    Status: offline
    4LBS its a a heavyweight.. looks like fuji/ Zenoah territory.. stick with the DA
    Lee Durham,
    http://lee3d.tripod.com
    (in reply to BARCC)
           Post #: 29
    RE: Extra 260 27% Hangar 9er - 4/4/2005 1:23:01 AM
    David_Moen
    Status: offline
    I think that the 58 would push the wing-loading up too far. In the MVVS line (manufacturers of Evolution) the new 45cc engine would be a better choice. The 45 is a pound lighter than the 58 with a wide, flat power curve. Factory numbers suggest that this engine is competitive with other European 60s!
    http://www.mvvs-canada.com/products.php?cat=2
    I only wish they gave this plane an 80" wing span so it would qualify for "Big Bird" and IMAA events!
    David Moen
    www.mvvs-canada.com
    (in reply to BARCC)
           Post #: 30
    RE: Extra 260 27% Hangar 9er - 4/4/2005 1:28:44 AM
    BR289
    Status: offline
    I always thought that 1/4 scale and up did qualify for IMAA legal size (?)
    Blair
    (in reply to David_Moen)
           Post #: 31
    RE: Extra 260 27% Hangar 9er - 4/4/2005 1:32:12 AM
    drumbum
    Status: offline
    i think this plane is 20% or 22
    Lee Durham,
    (in reply to BR289)
           Post #: 32
    RE: Extra 260 27% Hangar 9er - 4/4/2005 1:53:33 AM
    BR289
    Status: offline
    Its advertised as a 27%
    (in reply to drumbum)
           Post #: 33
    RE: Extra 260 27% Hangar 9er - 4/4/2005 2:39:17 AM
    Banche
    Status: offline
    So u are gonna compete with it?
    anywais I think I will stick with the DA 50, I seems to me that lighter is better, I think that it could pull the plane around very well for how much the plane weighs, I never really liked the look of the evolutioin engines and thought that they weighed alot and were underpowered.
    do you think that Hitec's 5645 digitals will be enough for this monster.
    (in reply to BR289)
           Post #: 34
    RE: Extra 260 27% Hangar 9er - 4/4/2005 3:52:33 AM
    drumbum
    Status: offline
    quote:
    ORIGINAL: BR289
    My bad ,, i wouldnt have thought it, but then again the H9 33% is in the 96" range so that sounds right.. Good point
    Lee Durham,
    (in reply to BR289)
           Post #: 35
    RE: Extra 260 27% Hangar 9er - 4/4/2005 5:27:42 AM
    ROMANBM
    Status: offline
    Hi guys my VON EXTRA 260 is legal for IMAC . This one is 35%
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    http://WWW.ROMANBUILTMODELS.COM
    VON EXTRA 260 35 %
           Post #: 36
    RE: Extra 260 27% Hangar 9er - 4/4/2005 8:19:21 AM
    Doug Cronkhite
    Status: offline
    The Extra 260 had a wingspan of 24' so at 78" the scale is 27.08%
    Doug Cronkhite
    (in reply to ROMANBM)
           Post #: 37
    RE: Extra 260 27% Hangar 9er - 4/4/2005 12:49:54 PM
    BARCC
    Status: offline
    Horizon doesnt want to admit that the evolution gassers are made by MVVS, cause when I called them they were getting mad, becasue I said they were MVVS, and he said that they were evolution factory, made not MVVS
           Post #: 38
    RE: Extra 260 27% Hangar 9er - 4/4/2005 1:10:03 PM
