RE: RE: I maidened my Patty with a DA-50!
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Extra 300S 1/4 Wagstaff ARF - 1.60
  • 2 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> ARF or RTF >> RE: RE: I maidened my Patty with a DA-50!
    Page: <<   < prev  215 216 217 218 219 220 221 [222] 223 224   next >   >>
    Login
    RE: RE: I maidened my Patty with a DA-50! - 2/28/2004 12:39:32 PM
    TOFAST4U2C
    Status: offline
    How about when you use 2 6volt packs in parallel??
    _____________________________
    Born to CRUISE, Forced to Work!
    (in reply to Geistware)
           Post #: 5526
    RE: RE: I maidened my Patty with a DA-50! - 2/28/2004 1:39:37 PM
    Forgues Research
    Status: offline
    quote:
    ORIGINAL: rcguy1
    BasinBum is a regulator really necessary when you use a 6 volt battery pack? I'm using Hitec digital servos with Futaba radio equipment and no regulator on the 6 volt battery. Have had this setup over a year now with no problems. Also other fliers at our field have the same setup, 6 volt battery no regulator with 35% planes and no problems.
    If I may, you don't need a regulator with any 5 cell packs of NiCds or NmHds
    Some years ago, JR servos would not tolerate 6 volts, but as for Hitec and Multiplex, and most other brands will have no problems with 6 volts.
    Right after a complete charge, you will see close to 7 volts, but normally when take everything out of the charger and drive to the field, the batteries have stabalized to a lower voltage.
    Also if you have your transmitter very close to the airplane at the start of the day, you might see some jitters, because the RF is getting swamped , pull away a bit.
    Hope this helps.
    Roger
    Evo Engines
    http://forgues-research.com
    (in reply to rcguy1)
           Post #: 5527
    RE: RE: I maidened my Patty with a DA-50! - 2/28/2004 2:05:52 PM
    BasinBum
    Status: offline
    quote:
    ORIGINAL: rcguy1
    Asked and answered. They are not necassary but they are sure common. As Roger points out the voltage drops off quickly but if you tend to top off at the field it'll keep the servos from twitching. I have also read that the servos will perform more consistantly through the flight but I don't know if it's a noticable differance.
    As for 2 fasts parallel question it wouldn't change the voltage so that set-up does not have to have one either.
           Post #: 5528
    RE: RE: I maidened my Patty with a DA-50! - 2/28/2004 2:08:33 PM
    Geistware
    Status: offline
    There is not a problem with two 6 volt packs in parallel.
    http://www.geistware.com/rcmodeling/parallel_batteries.htm
    quote:
    ORIGINAL: TOFAST4U2C
    Aircraft Proving Grounds
    http://www.rcaircraft.net/
    Information on the building and flying of Radio Control Aircraft.
    Site for hobbyist in the R.C. Aircraft modeling world.
    (in reply to TOFAST4U2C)
           Post #: 5529
    RE: RE: I maidened my Patty with a DA-50! - 2/28/2004 4:33:33 PM
    rcpilotjae-RCU
    Status: offline
    RCGUY:
    These guys are correct. Especially with the HiTec servos which are supposed to be capable of taking up to 10 volts (I don't believe it as a constant 10v, although I maybe wrong). The only servos on the market that don't tolerate 6v too much is Futaba. They are marked as such although their digitals are more tolerant of 6v when it is regulated. As these guys pointed out with a regulator you get a more consistent voltage through out your flights. The regulators used today are better suited to battery packs of Li-Ion & Li-Po technology where the voltage out is any where from 7.2 to 8.4 volts and needs to be regulated. As pointed out a 5-cell 6 volt NiCad or NiMi doesn't need regulation with todays' servos.
    Too Soon Old, Too Late Smart
           Post #: 5530
    RE: Wagstaff Extra 300 - 3/15/2004 10:51:28 PM
    DENNIS C
    Status: offline
    Hey guys anybody have a new spinner that comes with the patty they want to sell. if so send me a e-mail please.
    "Opinions are like Buttholes EveryBody has one "
    (in reply to SMALLFLY-)
           Post #: 5531
    Crazy Pilots? - 4/6/2004 4:39:12 PM
    PlaneKrazee
    Status: offline
    Swift Bill,
    Where did you get your pilot and do you have contact information?
    KB1DTB
    AMA11123
    (in reply to X300Pilot)
           Post #: 5532
    RE: Crazy Pilots? - 4/6/2004 4:48:18 PM
    P-51B
    Status: offline
    Regarding the 6 volt pack and regulator issue...aren't the electronics, such as the receiver, built on a 6 volt platform? Therefore, isn't there a potential damage to the electronics rather than the servos (since the packs will hold more than 6 volts for some time)?
    < Message edited by P-51B -- 4/6/2004 11:48:58 AM >
    In order to think "outside the box", one must first accept there IS a box.
    (in reply to PlaneKrazee)
           Post #: 5533
    RE: Crazy Pilots? - 4/6/2004 7:10:42 PM
    rcpilotjae-RCU
    Status: offline
    Correct, most damage would show up in the receiver as it's not designed to take more voltage.
    Edge540T.com
    There's a Fine Line Between Hobby and Insanity
    (in reply to P-51B)
           Post #: 5534
    RE: Crazy Pilots? - 4/6/2004 7:20:25 PM
    Forgues Research
    Status: offline
    By far the best way is to use a 5 volt battery for the receiver and a 6 volt battery for the servos. This way the receiver runs clean without any issue.
    And here is one way of doing it
    Roger
    < Message edited by aerografixs -- 4/6/2004 2:20:42 PM >
    Evo Engines
    (in reply to rcpilotjae-RCU)
           Post #: 5535
    Patty With A Glow - 4/11/2004 9:02:30 PM
    Baker
    Status: offline
    for the guys here that are flying a Patty with a Glow engine!!!
    do you have any problems with a glow pulling the Patty!!
    (in reply to RobertC)
           Post #: 5536
    RE: Patty With A Glow - 4/11/2004 9:14:05 PM
    John Murdoch
    Status: offline
    My first Patty had the Moki 2.10 for well over 200 flights until I went gas. Works okay but nothing spectacular. She would do the basic and sportsman IMAC maneuvers but kinda had trouble with the advanced and beyond. Not enough vertical. But it was a great little engine to get the feel of the Wagstaff. Once I went with the BME and the DA, four vertical snaps, not a problem. If you're even considering the glow motors, remember the $$$$ you need for fuel. Even with the rise of gas prices, $2.00 a gallon is pretty cheap.
    < Message edited by 232Cap-Tain -- 4/11/2004 1:14:44 PM >
    (in reply to Baker)
           Post #: 5537
    RE: I maidened my Patty with a DA-50! - 4/11/2004 9:20:42 PM
    Baker
    Status: offline
    I have a Fugi BT-64A in mine and I have been told that it was the wrong engine!! to heavy and not enough HorsePower!!! How much did you spend for your Gas Engine?
    (in reply to John Murdoch)
           Post #: 5538
    RE: I maidened my Patty with a DA-50! - 4/11/2004 9:39:02 PM
    John Murdoch
