RE: Wagstaff Extra 300
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Extra 300S 1/4 Wagstaff ARF - 1.60
  • 3 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> ARF or RTF >> RE: Wagstaff Extra 300
    Page: <<   < prev  215 216 217 218 219 220 221 222 223 [224]
    Login
    RE: Wagstaff Extra 300 - 4/20/2004 2:21:39 AM
    Baker
    Status: offline
    I am not done with my patty and once finished I plan to biuld a MidWest AT-6 with an 83" Span!!
    I plane to serch for a forum on it. Do any of you all have one or know some one that I could talk to about it?
    Baker
    (in reply to Joe Kelley)
           Post #: 5576
    RE: Wagstaff Extra 300 - 4/20/2004 4:13:04 AM
    aegis
    Status: offline
    Baker - Get yourself a comfortable chair for when you build the MW AT-6. There is a lot of building on that one! I don't still have mine, but I remember how much time it took to build. It's not a difficult plane to fly, but it isn't the easiest landing plane I've ever had. Can be difficult to get it set down without a bounce or two. I've seen that some people have incorporated flaps. They say it made a big difference landing it. If there isn't already a thread for it you'll want to start a separate thread rather than continuing the discussion here on the Patty thread.
    Dan
    (in reply to Baker)
           Post #: 5577
    RE: Wagstaff Extra 300 - 4/26/2004 6:45:09 PM
    TheEdge
    Status: offline
    Does anyone have a Canopy left over from a Patty that is still good and not being used ?
    Mine met with an accident and I could use another.
    Any help would be gladly compensated
    (in reply to aegis)
           Post #: 5578
    RE: Wagstaff Extra 300 & DA50 - 4/27/2004 12:55:44 AM
    RapidRobert
    Status: offline
    Hey Guys,
    I removed the detent ball and spring from my DA50 Walbro carb.
    I'm going to operate the choke with a servo in my GP Patty Wagstaff.
    I should have taken a picture.
    I can't seem to get the ckoke plate in the right spot.
    Any close up pitures out there.
    Thanks, Bob
    (in reply to RobertC)
           Post #: 5579
    RE: Wagstaff Extra 300 & DA50 - 4/27/2004 9:36:52 AM
    rcguy1
    Status: offline
    Call DA--they will be more than happy to help you get the carb back together.
    (in reply to RapidRobert)
           Post #: 5580
    RE: Wagstaff Extra 300 - 5/2/2004 5:24:37 AM
    Holton50
    Status: offline
    i'm putting the wings and horizontal stabilizer on the plane , an there is a significant gap on the leading edge of both parts. has anyone else had this problem? what did you do to fix the gap in the horizontal stabilizer?
    (in reply to rcguy1)
           Post #: 5581
    RE: Wagstaff Extra 300 - 5/2/2004 6:01:46 AM
    Icaro2004
    Status: offline
    I had the same problem. Make sure the stab is centered, and paralell to the wings. I used 30 min Epoxy, centered the stab and let it dry for a few hours before I continued working.
    (in reply to Holton50)
           Post #: 5582
    RE: Wagstaff Extra 300 - 5/2/2004 6:35:09 AM
    Holton50
    Status: offline
    dose anyone know how to fix the gap i have on the leading edge on my wings??
    (in reply to Icaro2004)
           Post #: 5583
    RE: Wagstaff Extra 300 - 5/13/2004 10:33:05 AM
    rcguy1
    Status: offline
    Call Great Planes and complain. They may send you a new plane. Of course you would have to send the one you have back to them. Try it, all they can say is no.
           Post #: 5584
    RE: Wagstaff Extra 300 - 5/13/2004 2:04:07 PM
    John Murdoch
    Status: offline
    It's pretty easy to take care of. I had to do this to two of my Pattys. When I set the incidence, I found that I had to sand the opening bigger in places which caused a bigger gap. It'll be a two step process. Just take a couple like 1/4" X 1/4" X 1" pieces of balsa and stick them in the gaps after you have your stab where you want them. These pieces may be too small or too big so cut them the size that you need. Just shim the gap every so often with the balsa sizes you need. Use 30 minute epoxy and coat each of the shims as you pull them out and reinstall in the same place you took it out. Make sure you stick the wooden pieces in a little beyond the flush area of the stab cutout. After that (the shims) has set, just fill the rest of the voids with 30 minute epoxy mixed with microballoons.
           Post #: 5585
    RE: Wagstaff Extra 300 - 5/14/2004 2:24:45 AM
    Nathan
    Status: offline
    Folks, if there were a way to combine the two Patty threads I would do it in a heartbeat. However, because I can't do that I'm going to close this one down in favor of a more active thread on the same topic.
    Please CLICK HERE to continue your Patty conversations. Thank you.
    _____________________________
    Nathan M.
    Administrator
    RCUniverse.com | Wattflyer.com | RCUvideos.com | Kaango.com
    (in reply to John Murdoch)
           Post #: 5586
