TManiaci
CA, USA Status: offline
quote:
ORIGINAL: beaggs thanks tman so is a 1000grams thrust posible is this more a heli motor i won the motor and a used once, u can do set up with sevos and a 2200 lipo for not a bad price in ozzy land thanks again beaggs Well, let's check it out. 3800 Kv x 11.1 V = 42180 rpm. Final Drive RPM will be 42180 / 5.3 = 7950 rpm. Motor specs say 22 amps burst, at 250 watts max. Right off the bat, STRONG 3D needs 12-15 watts per ounce. So, 250 watts is going to be best on a plane 16 to 20 oz's. Now, playing with, Wattage Calc to get the right order of magnitude, it says that at 7950 rpm, you should turn an APC 11x7E, and generate 228 watts (output). Assume you have 75% efficiency (gearbox), then your battery draw would be 228 watts / 0.75 = 300 watts... too much. Try again, we need 250 watts (input) x 0.75 = 188 watts (output). APC 11x5.5E will make 179 watts output. Close enough. Now we go to ThrustCalc, and with that data we see 2.09 lbs (33.4 oz's) Thrust. 0.95 kg... pretty close to his claim, assuming the motor will do 250 wattts, you got a deal!
_____________________________
TMan
