rcav8or
Joined: 12/15/2001 From: Oxford, IN, USA Status: offline
Another vote here for the Sig Four Star .40 or .60 (I would go with the .60). Laser cut, keyed assembly (almost can't build it crooked, quick assembly (did one start to finish in 9 days), and a great kit to learn on. Flying is spectacular! Many have competed in the lower pattern classes with a 4*, and lands like a lamb... Get with other flyers around you, get all the opinions you can, and go with what you think you can handle, both in building and in flying...it's especially nice if you can see other's flying their planes of the same model... TO: Profile Pilot... I considered the Ultra Stick .40, called my buddies at Horizon, found out they all hung up the Ultra Stick .40, when the Pizazz came. I bought the Pizazz instead - WOW!!! What a great kit, plane, flyer - you name it! I have seen one with an MDS .58, plenty of power, and I have an OS .70 Surpass on mine, vertical is great, does EVERYTHING in the book. Use flaperon mix on it though! DISCLAIMER - The Pizazz is NOT good 2nd plane - maybe a 3rd or 4th...
_____________________________
Roger Phillips AMA #387890
