combatpigg
WA, USA Status: offline
Hi ROG, If I can come up with a working design, I'll be happy to draw it up and send one off to you. It looks like rain all day again, so at least I won't be out goofing off [flying], but inside finishing this plane up. Tim, I've got a cheap plastic balsa razor plane [MASTER AIRSCREW?] and it makes short work of shaping. I draw a bunch of reference lines on the wood with a fine line marker, and these lines are like elevation marks on a map. After it is roughed out with the planer, then I switch to block sanding. In general , even with only 24" span, I ended up wimping out and threw in a short spruce spar. This is all I think the plane will need. I added the glass tape to force this thin wing to hold its' shape and not buckle. Any buckling or cupping changes the aileron trim. PATRICK, looks good! You gotta take the elliptical theme out all the way to the tail too, otherwise [IMO] it looks like a guy wearing an ARMANI suit with ARMY boots. I don't know about you guys and the 30 inch wings though, what are ya trying to build, GLIDERS ? Remember, real racer planes were called widow makers, guys DIED in them! I saw a COSMIC WIND at the CHINO AIRPORT MUSEUM and you would not believe how small and fragile it looked! All I remember saying to myself was, "NO WAY"!!
_____________________________
Led Zeppelin is NOT "old fogie" music.
