RE: Walkera #4 Fixed Pitch Helicopter Forum
Tower Hobbies
Logged in as Guest
Users viewing this topic: yoyozach
  Printable Version
More Resources on the
Dragonfly 40
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: Walkera #4 Fixed Pitch Helicopter Forum
    Page: <<   < prev  10 11 [12] 13 14 15 16 17 18 19   next >   >>
    Login
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/11/2005 12:13:24 AM
    chris6414
    Status: offline
    I clipped 2cm off my tips and with the stock packs fresh, she climbs pretty quick and I can hover with about 2/3 throttle. Punch it from a hover and she climbs out pretty quick. I usually get about 2 minutes of that performance with a fresh pack. I also got 1 or 2 minutes of extra time. I can't wait to try my 11.1 LiPo.
    < Message edited by gysgt6414 -- 10/11/2005 12:15:38 AM >
    (in reply to Schwede)
           Post #: 276
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/11/2005 2:40:03 AM
    tomcatguy74
    Status: offline
    Dang! I fractured my tail boom in a nasty crash !!!!
    What are you guy's doing to replace tail booms? Stock or upgrades?
    Rob
    _____________________________
    Traxxas Revo 3.3 & Stampede XL-5, 2 Team Losi Mini-Ts
    Team Losi Micro-T
    HPI Firestorm 10T
    (in reply to chris6414)
           Post #: 277
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/11/2005 3:07:57 AM
    tomcatguy74
    Status: offline
    Hey, does anyone know if there is an addon to FMS that lets you fly indoors? Like an indoor scenery?
    Team Losi Micro-T
    HPI Firestorm 10T
    (in reply to tomcatguy74)
           Post #: 278
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/11/2005 11:32:32 AM
    Schwede
    Status: offline
    tomcatguy74,
    Here is a link that has an indoor scenery (Rainbow Stadium). You might have to create a profile to download the file..
    Gunnar
    quote:
    ORIGINAL: tomcatguy74
           Post #: 279
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/11/2005 12:55:43 PM
    chris6414
    Status: offline
    Heli-hobby has replacements. Aluminum tube would work if it was light enough and right diameter.
           Post #: 280
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/11/2005 1:07:46 PM
    oops
    Status: offline
    You can buy carbon fibre rod by the metre for a few dollars.
    Just cut to size.
    The most difficult part (not hard) is to get the wires through it.
    David
           Post #: 281
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/11/2005 3:24:08 PM
    tomcatguy74
    Status: offline
    Which would be stronger, CF or Aluminum. Or shall I say MORE RESISTANT to rookie pilots in training like myself??
    Where can I get them?
    Team Losi Micro-T
    HPI Firestorm 10T
    (in reply to oops)
           Post #: 282
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/11/2005 5:59:26 PM
    chris6414
    Status: offline
    I chose an Aluminum control rod for my new flybar because I kept having rotor strikes when practicing indoors and it just bends right back. The CF rod I had shattered and was usable but I had to clip the end off and slide the rod to center again befor I put the paddle back on. Not as much control and I wacked it again and went to the Aluminum rod. Aluminum tube could be had a plumbing store or Lowes/HomeDepot but I don't know how you would attach it to the tail unless you dremelled slots and clamped it. Unless you really bent it to a kink it would be very durable and give on impact. Watch the thickness as it will effect weight and balance. The Aluminum may be a little heavier but you could probably shorten the tail boom a little to compensate with no harm to control just watch the tail rotor arc that it doesn't cross the main rotor arc.
           Post #: 283
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/11/2005 6:19:52 PM
    tomcatguy74
    Status: offline
    How is the stock tail boom held on? Glue? I could probably find an alternative to the cf with aluminum. i am sure there is a inner and outer diameter i could use on the tail. i just have to find it
    Team Losi Micro-T
    HPI Firestorm 10T
           Post #: 284
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/11/2005 9:19:56 PM
    NOZZARCHELI
    Status: offline
    HI, i have a DF4 and 36, i have recently been having problems wth the power of my DF4ch, i have a new nimh battery and i have even installed a new motor and it has no effect......i have installed heatsinks all round and balanced blades, im taking off and the heli doesn't have enough power to get much higher than about 1ft.................... im guessing it may be the receiver/speed controller.....or not......if anybody knows what could be wrong...PLEASE HELP......i wonna fly this thing again.......even though i have an upgraded 36 that works...............this little thing rocks!!
    ANY HELP WILL BE MUCH APPRECIATED !!
    MATT.
    Don't Steal, The Government hate's competition
           Post #: 285
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/11/2005 10:31:34 PM
    chris6414
    Status: offline
    I've clipped by tips down 2Cm and the thing jumps off the ground now. I was having the same problem. I would also try and take some pitch out of the mains. If the head speed sounds high then you might need to give the blades a twist to add some pitch to them. I had two sets of blades and they both had drastically different lift charactersitics. I even went as far as looking at the blades from the side with and making sure the trailing edges were even to ensure the trailing edge didn't have warps and curves in them that effect lift or lack of lift.
    (in reply to NOZZARCHELI)
           Post #: 286
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/11/2005 11:47:28 PM
