GTX SlotCar
ME, USA Status: online
When it takes off, it'll either tip to the right or skid to the left. It'll do either one at random. As far as I know, nothing can be done about this. It may also want to move forward or back. Adjusting the trim and CG helps this, though. It's a lot more stable when you get out of groud effects. The rotor wind hitting the floor will blow the little heli all over the place. So, at 18" it's easier to fly and at 3' it's quite a bit easier. I'm new at this, too, so I haven't had mine more than 4' off the ground. At 3' and higher it's smooth and pretty stable, but it won't just sit there hovering. It takes small stick movements. When it starts slipping in one direction, move the stick a little the opposite way, but anticipate what it needs. Don't wait until the last moment or you'll overreact. I've been able to hold mine in a fairly stable hover for 10 to 15 seconds at a time doing it this way. Balance your main blades. Have them fairly tight, but make sure you can move them. When they start spinning, they'll adjust to the right spot. As for the flybar paddles, they're supposed to be flat, but on a tip from somebody, I set mine at about +5° and I do find it a bit easier to hover.
_____________________________
Gary SuperSkids® www.super-skids.com
