dknovick
NM, USA Status: offline
quote:
ORIGINAL: GTX SlotCar That's a good question. I've been using heat sinks on my main and tail motors forever. I also use high quality Arctic Silver heat sink compound for better heat dissipation. But... I've recently seen some temperature readings on a couple of a motors with and without using a heat sink, and the difference was less than 5° F for an aftermarket hot (or fast) motor, and only a couple degrees on a stock motor. I always assumed the heat sinks were doing some good, but I'm currently running without them to try it out and I'm not noticing any difference so far in the performance or lifespan of the motors. I guess the answer is, they can't hurt because they don't weigh much, but they probably don't help much, either. If you don't use a good heat sink compound, they probably make even less difference. Interesting... on the tail motor on my bird, without the heat sink, it's very hot to the touch after about 10min of hover. With the heat sink it's just warm (and that's without heat sink compound).
_____________________________
What goes up, most come down. How hard depends on you!
