RE: Walkera #4 Fixed Pitch Helicopter Forum
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Dragonfly 40
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: Walkera #4 Fixed Pitch Helicopter Forum
    Page: <<   < prev  337 338 [339] 340 341 342 343 344 345 346   next >   >>
    Login
    RE: Walkera #4 Fixed Pitch... - 3/29/2008 4:34:31 AM
    dknovick
    Status: offline
    quote:
    ORIGINAL: mysteryguymlt
    From where did you purchase it please maybe you can provide me with a link. is it a walkera part or another model please?
    ushobbysupply.com has 'em...
    _____________________________
    What goes up, most come down. How hard depends on you!
    (in reply to mysteryguymlt)
           Post #: 8451
    RE: Walkera #4 Fixed Pitc... - 3/29/2008 4:37:08 AM
    dknovick
    Status: offline
    quote:
    ORIGINAL: drobin
    I don't think it matters what the resistance of the potentiometer in the 4in1 is.If I remember,it doesn't do a thing.I've had mine over a year and at times tried different positions on it with no changed.
    If it's similar to the Falcon 40, it's suppose to adjust the tail motor gain. I haven't played with mine enough to see if it actually does anything. Maybe I'll poke around in my 4in1 and see where the pot goes...
    -Dave
    (in reply to drobin)
           Post #: 8452
    RE: Walkera #4 Fixed Pitc... - 3/29/2008 4:38:39 AM
    dknovick
    Status: offline
    quote:
    ORIGINAL: GTX SlotCar
    I was told that some power supplies needed a load somewhere, either to activate, or not burn something out. None of the ones I have need it, but I thought I'd throw the resistor info in just in case.
    2nd picture, that's quite a bird. Looks like a CP model. How's she fly?
    I didn't need to add a resistor to mine either. You're suppose to have to add a load to turn it on.
    (in reply to GTX SlotCar)
           Post #: 8453
    RE: Walkera #4 Fixed Pitch... - 3/29/2008 7:54:32 AM
    mysteryguymlt
    Status: offline
    thanks for the information. mysteryguymlt
    (in reply to dknovick)
           Post #: 8454
    RE: Walkera #4 Fixed Pitc... - 3/30/2008 4:03:39 AM
    jeff06
    Status: offline
    quote:
    ORIGINAL: dknovick
    quote:
    ORIGINAL: drobin
    -Dave
    Let me know how that goes.
    thanks
           Post #: 8455
    RE: Walkera #4 Fixed Pitc... - 3/30/2008 11:31:08 PM
    dknovick
    Status: offline
    quote:
    ORIGINAL: jeff06
    thanks
    Poking around, this is what I found out:
    The Gyro is connected to two of the inputs on the quad op amp (2In+, 2In-)
    Two of the outputs from the quad op-amp are connected to two pins of the 8bit microcontroller (2Out, 4Out).
    The pot (which I believe is 10k) acts as a voltage divider ranging from 0-3.3V
    The output (wiper) from the pot is connected to a pin on the microcontroller (8-bit ADC)
    There isn't a stop on the pot, so you can twist it round-and-round and it will just go from 0-3.3v-0-3.3v (you get the idea).
    One of the pins on the microcontroller (PWM output) drives the tail mosfet gate.
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    (in reply to jeff06)
           Post #: 8456
    RE: Walkera #4 Fixed Pitc... - 3/31/2008 12:06:51 AM
    GTX SlotCar
    Status: offline
    I probably shouldn't reply to this because it's been a long time since I've used my DF4 4in1 (I switched to Esky so I could use a different Tx), and mine was from a 2005 model and they may have changed slightly. But, here goes anyway. As I recall, on my 2005 model, the adjustment worked for tail gain but was all bunched at one spot of the rotation (as if the pot value was too large). In other words, all the adjustment was within a 5° area. I could disconnect the main motor, fire up the heli and slowly turn the trimmer on the 4in1. At some point, the tail motor would speed up. Once I went past this small point, it slowed right back down again. Very sensitive, but it did work. Again, I haven't done this for over 3 years, so I could be mistaken or the 4in1s could be slightly different now.
    As I recall (again, I could remember wrong), I didn't have to reset the 4in1 with each small movement, the tail motor speed would change as I turned the trimmer.
    Anyway, give it a try. There's nothing to lose.
    Gary
    SuperSkids® www.super-skids.com
           Post #: 8457
    RE: Walkera #4 Fixed Pitc... - 3/31/2008 2:54:33 AM
    billmay
    Status: offline
    My experience with my "late model" Falcon 40 4-in-1 gain control is exactly the same as yours. However, even when I set the gain to give maximum tail motor rpms I can't honestly say that I saw any improvement in tail control (maybe because it was set right to begin with). Perhaps the more important point is that this is NOT a proportional control like that found on the Esky and Eflite 4-in-1's/3-in-1's which will allow you to correct for a heli that is always slowly turning in one direction or the other.
    Bill
           Post #: 8458
    RE: Walkera #4 Fixed Pitc... - 3/31/2008 3:07:47 AM
    dknovick
    Status: offline
    It's about time for me to play with it, the trim for my tail is almost full right. I'll see if it's consistent with the two of yours.
           Post #: 8459
    RE: Walkera #4 Fixed Pitc... - 4/3/2008 4:01:27 PM
    Globemaster3
    Status: offline
