RE: Walkera #4 Fixed Pitch Helicopter Forum
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Dragonfly 40
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: Walkera #4 Fixed Pitch Helicopter Forum
    Page: <<   < prev  340 341 [342] 343 344 345 346 347 348 349   next >   >>
    Login
    RE: Walkera #4 Fixed Pi... - 5/4/2008 5:06:22 PM
    clp.eng
    Status: offline
    I finally got the servo in & it stopped raining so I took it outside for a test drive. It went up about 2 feet drifted about 2 feet then flipped over! Lost a bearing from the main blade.
    I tried to find a list of recommended spares for the 4-1 but the search feature on this forum is not very friendly.
    The question is what other parts should I order for spares? I have both blades & a spare battery (well RAIDENTECH hasn't got it to me yet & it's going on 3 weeks!), the Superskids are coming.
    What site has good prices & REASONABLE shipping? It seems most of the site's I've found only have parts for the 4 not the 4-1.
    I'd appreciate any suggestions.
    Chuck
    (in reply to dknovick)
           Post #: 8526
    RE: Walkera #4 Fixed Pi... - 5/4/2008 5:39:20 PM
    Tall Paul
    Status: offline
    Rotor head. Get lots of those!
    I broke only one main rotor blade on my 4 #4s.
    Tail rotors.
    Tail motors.
    I learned to repair the sticks that support the landing skids.
    These break a lot at the landing skid.
    The difference between the #4 and #4-1 is from the swash plate up.
    I got all of those parts spare, and haven't used any of them on mine, other than replacing the rotor head several times.
    _____________________________
    Sparky Paul
    http://www.angelfire.com/indie/aerostuff
    (in reply to clp.eng)
           Post #: 8527
    RE: Walkera #4 Fixed P... - 5/4/2008 5:47:45 PM
    drobin
    Status: offline
    I get most of my df4 stuff from US Hobby Supply.They have good prices and fast,reasonable shipping.The other places with good prices and reasonable shipping are helidirect and rc and me.I've heard nothing but bad from raidentech.Other parts I keep are: main frame,main motor,tail motor(couple of them),tail blades,rotor head ring,short and long connecting rod.The fly bar rod breaks but you can buy a 3' carbon rod and cut your own.You can also buy a rod for the tail boom and cut your own.I know it sounds like a lot of parts but everything listed will break at one time or another.The places I told you for parts only charge one shipping price for everything.
           Post #: 8528
    RE: Walkera #4 Fixed Pi... - 5/4/2008 9:44:45 PM
    goofyfoot
    Status: offline
    dknovick,
    Thanks for telling me about the potentiometer. I am still adjusting it but can tell the difference. It does not seem to be very sensitive and the change in motor sound is minimal, at best, but now at least I do not need to constantly hit the rotate right lever.
    For those wondering about the Heli-X software. I downloaded it and think it is great. The flying is much more realistic and the backgrounds are real images. The setup is a little weird it uses a DOS window to launch. If you do get it be sure and read the Readme.txt file. There is one command, I think it is "Idle-up1" that must have an assigned key or the motor will not start. I am running it with an Esky simululator. I also use FMS but have not decided which I prefer.
    I have had good luck getting parts from Raidentek, just for the record.
           Post #: 8529
    RE: Walkera #4 Fixed Pi... - 5/4/2008 10:16:31 PM
    dknovick
    Status: offline
    quote:
    ORIGINAL: goofyfoot
    dknovick,
    Yeah, it doesn't do too much...
    What goes up, most come down. How hard depends on you!
    (in reply to goofyfoot)
           Post #: 8530
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 5/5/2008 1:56:55 AM
    Popriv
    Status: offline
    Hi all,
    New to RC Heli and trying to find a walkera 4 #3 ....
    Seems like everyone is sold out except HongKong...
    Can I get one of these in the states?
    If I cant find one is there anything similar out there?
    The walker 4 #3 seems like a good size to start. (small yard)
    I dont want to go with a coaxle blade..
    Thanks for any info..
    Pops
    (in reply to hrwatson68)
           Post #: 8531
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 5/5/2008 3:21:24 AM
    Feric Jagger
    Status: offline
    quote:
    ORIGINAL: Popriv
    Hi all,
    Pops
    Pops
    Sorry to dampen your enthusiasm but the 4#3 is not a good starter helicopter. It is far too small - it seems to be the case that the larger copters are more stable and easier to fly. I have a 4-1 and a 4#3. The 4-1 is relatively easy to fly compared to the 4#3.
    I would actually suggest starting with a coaxial copter so that you can learn the orientation of the controls. Once you are comfortable with the cyclic controls (and throttle and rudder) you can move on to a fixed pitch copter like the 4-1 (which is still small enough to fly in a backyard).
    The problem with single rotor copters as opposed to coaxial is that single rotor copters are inherently unstable. In the absence of cyclic correction the copter will tip over and crash. You really can't hover a single rotor copter until you have developed an instinctive feel for the cyclic control. Coaxial copters are stable with respect to roll and pitch so that with a coaxial copter you can concentrate on learning the throttle and rudder controls before moving on to the cyclic.
    I guess it's not impossible to start on a single rotor copter, but for a beginner it is hard enough dealing with the throttle and rudder without also having worry about the cyclic. As for starting on a 4#3, being such a small helicopter it requires constant cyclic correction. It is not a beginners copter.
    My advice: Grand Theft Auto IV.
    Stephen
    (in reply to Popriv)
           Post #: 8532
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 5/5/2008 3:57:17 AM
    Popriv
    Status: offline
    Thanks for the info...
    What would you suggest for a coaxle starter?
    I've flown RC Gliders and I'm still trying to grasp the controls of rc helis.
    It looks like the coaxles dont have a tail rotor? how do you control the flight?
    TIA
    Pops
    (in reply to Feric Jagger)
           Post #: 8533
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 5/5/2008 10:27:56 AM
    Feric Jagger
    Status: offline
    quote:
    ORIGINAL: Popriv
    TIA
    Pops
    In my humble view you have two choice: cheap and less cheap.
    The cheap solution is the Walkera 5#4. The less cheap solution is the Blade CX2. I have purchased (and wrecked) two of the Walkeras and they work well enough. The advantage of the Blade is better quality and a 2.4 GHz transmitter. If I were to buy another coax I think I would go for the Blade.
    The tiny option is, of course the Walkera 5G6 2.4GHz. I have owned a couple of these as well. They are probably OK for beginners but due to the poor quality materials and small size they are almost impossible to repair.
    Coaxial copters are quite interesting. But lets talk about normal copters first. Due to Newton's third law of motion, the rotation of the main rotor in a single rotor copter results in a tendency for the rest of the copter to rotate (or yaw) in the opposition direction. The speed of the counter rotation is proportional to the speed of rotation of the main rotor (and of course the ratio between the mass of the rotor and drive train and the mass of the rest of the copter). This tendency to rotate is countered by the tail rotor. So in your average fixed pitch copter the blades rotate clockwise, the body tends to rotate counter clockwise, and the tail rotor applies a clockwise force on the back of the copter which stabilizes the tail. To turn the nose of the copter left you slow down the tail rotor and to turn right you speed it up. This is complicated a little because fixed pitch copters increase vertical lift by speeding up the main rotor which increases the counter clockwise yaw on the body of the copter. I think the gyro is supposed to compensate but with a cheap copter like the 4-1 and the 4#3 the gyro isn't very clever. The tail rotor also pushes the entire copter left which is countered by tilting the swashplate (and main rotor) to the right with a bit or right hand push on the cyclic control. You can try to counter this left hand push by trimming the swashplate to tilt to the right but the left hand push varies with the thrust of the tail rotor which varies with the head speed of the main rotor so there is not much point.
    So, take off with a single rotor fix pitch copter involves advancing the throttle control to the take off position which leads to yaw which has to be countered via the rudder control which leads to lateral thrust which has to be countered via the cyclic (roll) control. Every time the throttle control is adjusted the yaw and roll controls also have to be adjusted. So flying a single rotor copter involves continual juggling of three different controls. I think that is one reason why single rotor copters are hard to fly.
    Coaxial copters are relatively simple. A coaxial copter has two rotors (driven by two motors) rotating in opposite directions. The torque created by these counter rotating rotors cancels out. The cyclic control still control pitch and roll (to move the copter forwards, back and laterally left and right), but yaw is controlled by one of the rotors speeding up or slowing down. With the coaxial copter the throttle control doesn't affect yaw and the absence of a tail rotor means there is no lateral thrust to counter. That is, the throttle in a coaxial copter is not associated with the yaw and roll controls. If the copter is properly set up you can take off and land without touching any control except the throttle and you can fly it around a room by steering it like a model car. Very easy to fly.
    One point to note. My understanding is that most plank fliers fly mode one whereas most copter flies fly mode two. In my opinion the mode two controls (with the cyclic controls on the right stick) is more intuitive and probably easier to learn on. I would advise choosing mode two over mode one for helicopters.
    Also, if you don't have one already, get a flight simulator. FMS and Heli-X are for free but ClearView is very good and only $40. HeliSimRC is also for free but is not as pretty as ClearView or Heli-X.
    If you are going the cheap flight simulator route I would recommend buying one of these cheap USB controllers. It is basically an eight axis no button USB joystick, and it comes with FMS on a disk. You could use a 360 controller (which I did for a while) but it kind of turns the flight simulator into a game. If you want to go the expensive route I won't make any suggestions for fear of being flamed out of existence. You can check out various flight sims via this chart and make up your own mind. I ended up with RealFlight G4 (which came with a very nice USB controller) and consider it AU$300 well spent.
    Stephen
    < Message edited by Feric Jagger -- 5/5/2008 10:52:28 AM >
           Post #: 8534
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 5/5/2008 2:15:40 PM
    Popriv
    Status: offline
    My only experience with helis is the small $30 toy my wife bought at the mall for Xmass.
    I dont know the brand, 6" main blade with 1" rotor blade. It connects to the transmitter to charge from the AA batteries.
    It could almost be controlled when new but now it cant be trimmed and the whole heli almost spins as fast as the main blade.. I'm considering trying to enlarge the tail rotor so its more effective? (I know an exercise in futility)
    Something a little better than this would be good for now.
