RE: Walkera #4 Fixed Pitch Helicopter Forum
Tower Hobbies
Logged in as Guest
Users viewing this topic: billmay
  Printable Version
More Resources on the
Dragonfly 40
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: Walkera #4 Fixed Pitch Helicopter Forum
    Page: <<   < prev  341 342 [343] 344 345 346 347 348 349 350   next >   >>
    Login
    RE: Walkera #4 Fixed P... - 5/6/2008 10:17:32 PM
    Rompn
    Status: offline
    So I have been away from the forum for what looks like 100 or so pages now. Anyway, I'm looking into picking up another # 4 since my original is busted pretty good. Iv'e read that they are no longer making these and are only selling the 4-1 now? I read some of the differences between the two but should I look for some old # 4 stocked away or is the new 4-1 a good heli? Also, the #4 - 3 looks like a great little micro. Anyone have one on here?
    _____________________________
    Patrick Goldsworthy
    Bmxtrme@Aol.com
    (in reply to GTX SlotCar)
           Post #: 8551
    RE: Walkera #4 Fixed Pi... - 5/6/2008 10:28:22 PM
    brettw
    Status: offline
    quote:
    ORIGINAL: clp.eng
    Won't the extra weight hurt performance (not that I'm worrying toooo much about that yet but maybe soon...)? I think I can get music wire from the LHS.
    Chuck
    It would be marginal if the weight does affect it. If you are using a lipo I wouldnt expect it to make that much of a difference however it will save plenty of flybars.
    Cheers
    Brett
    http://www.eastcoasthobbies.com.au
    (in reply to clp.eng)
           Post #: 8552
    RE: Walkera #4 Fixed P... - 5/6/2008 10:35:10 PM
    brettw
    Status: offline
    quote:
    ORIGINAL: Rompn
    The only difference between the 4 & the 4#1 is the head design and the canopy. To change the head to the version 3 design you just need the HM-4#1-Z-01 & HM-4#1-Z-02 oh and two small screws that hold the flybar on as Walkera do not provide these
    However in saying that there is a new 2.4G 4G1A & 4G1B that has just been released from Walkera, they are a new designed head and the "B" version has a metal head.
    Have a look at this post > http://www.rcuniverse.com/forum/m_7461826/tm.htm
    Cheers
    Brett
    East Coast Hobbies
    (in reply to Rompn)
           Post #: 8553
    RE: Walkera #4 Fixed P... - 5/6/2008 11:01:43 PM
    GTX SlotCar
    Status: offline
    Brett, do you know when the 4G1 will be available? It looks like the frame might be different.
    Gary
    SuperSkids® www.super-skids.com
    (in reply to brettw)
           Post #: 8554
    RE: Walkera #4 Fixed P... - 5/7/2008 1:33:21 AM
    AtomicFlyer
    Status: offline
    quote:
    ORIGINAL: clp.eng
    quote:
    ORIGINAL: drobin
    I use a dremal to cut the carbon rod.A hacksaw will work but go around the outside a little.May keep it from splintering.Wire cutters will not work.
    What attachment do you use to cut with? I've only used mine for drilling.
    Chuck
    To cut carbon fiber rod, I use the Dremel Cut Off Wheel Number 409. They are sold in a 36 unit package. I cut a small dado in a piece of wood to hold the CF while I cut it. And I put a wet paper towel underneath to catch the carbon dust when I'm cutting. It's still a bit messy so I do it out in the garage.
    Marc
    Click to see fullsize image.
    Click for fullsize
           Post #: 8555
    RE: Walkera #4 Fixed P... - 5/7/2008 1:42:36 AM
    AtomicFlyer
    Status: offline
    quote:
    ORIGINAL: brettw
    quote:
    ORIGINAL: Rompn
    ...I read some of the differences between the two but should I look for some old # 4 stocked away or is the new 4-1 a good heli? ....
    The only difference between the 4 & the 4#1 is the head design and the canopy. To change the head to the version 3 design you just need the HM-4#1-Z-01 & HM-4#1-Z-02 oh and two small screws that hold the flybar on as Walkera do not provide these ....
    Brett
    East Coast Hobbies
    I think the original screws were Phillips head, but I replaced them with 2mmx6mm cap head hex screws. Much easier to get in and out with a hex wrench.
    Marc
           Post #: 8556
    RE: Walkera #4 Fixed P... - 5/7/2008 4:15:51 AM
    brettw
    Status: offline
    quote:
    ORIGINAL: GTX SlotCar
    Im hoping to have an answer today and if they have them ill get a shipment in and let you know or if you want send you a frame if its different for testing.
    Details are a little thin at the moment.
    Cheers
    Brett
    East Coast Hobbies
           Post #: 8557
    RE: Walkera #4 Fixed P... - 5/7/2008 7:35:14 AM
    mwcyborg
    Status: offline
    Hi chophop please help me out?
    Brett mentioned you may be able to help out with canopy mods for motor and battery cooling?
    Any help would be appreciated man.
           Post #: 8558
    RE: Walkera #4 Fixed P... - 5/7/2008 1:19:04 PM
    clp.eng
    Status: offline
    quote:
    ORIGINAL: clp.eng
    ...Is it worth breaking the originals before I put them on or do they protect other things? I only ask because I just got the training "wheels" on.
    .....Chuck
    They do help with other things, but if you just got set up you may as well wait until you break something. You might want to pull off your tail fin and glue the SuperSkids 'tail saver bead' on, though. It'll stop the tail rod from snagging.
    Thanks, Gary.
           Post #: 8559
    RE: Walkera #4 Fixed P... - 5/7/2008 1:21:41 PM
    clp.eng
    Status: offline
    quote:
    ORIGINAL: Rompn
    I have the 4#3. According to the guys at the OTHER forum, I was too new to learn how to fly on it & they said get a biiger one to start with which is why I'm here. There are new versions of the 4#3 coming out (metal head, 2.4G) so you might want to check over at RC Groups forum.
    Chuck
    (in reply to Rompn)
           Post #: 8560
    RE: Walkera #4 Fixed P... - 5/7/2008 1:23:38 PM
    clp.eng
    Status: offline
    quote:
    ORIGINAL: AtomicFlyer
    quote:
    ORIGINAL: clp.eng
    quote:
    ORIGINAL: drobin
    Chuck
    Marc
    Marc,
    Thanks for the info. That looks pretty easy. I'll pick up some blades this weekend.
    Chuck
    (in reply to AtomicFlyer)
           Post #: 8561
