RE: Walkera #4 Fixed Pitch Helicopter Forum
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: Walkera #4 Fixed Pitch Helicopter Forum
Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: Walkera #4 Fixed Pitch Helicopter Forum - 8/24/2005 9:30 AM
oops
Score: 100
Last Login: 11/8/2008
Status: offline
I've been clipping the trailing edge to increase the aspect ratio of the blade - that doesn't get as much head speed increase as tips, but does maintain stabilility at a lower RPM.
DAvid
Hide Signatures
(in reply to chris6414)
       Post #: 126
RE: Walkera #4 Fixed Pitch Helicopter Forum - 8/24/2005 10:42 AM
cptsnoopy
Score: 100
Last Login: 8/2/2008
Status: offline
a little tip that i found out about these walkera fixed pitch heli's. this works for both the #4 and the #22d. They use the same rotor head and blades. if you remove the little plastic nuts that fit inside the blades and shave off about a 1/32" from the end that goes into the blade as a bushing. you can then tighten them up enough to prevent movement of the blades. other wise the plastic nut bottoms out and you will strip the nut out before you get the blades to stop moving about in the rotor head. before each flight you must visually align the blades. If you do that and carefully balance the blades the little helis seem to fly pretty darn stable. keep in mind though that you can still induce the wobbles from violent manuvers or slowing down from high speed flight too quickly.
Hide Signatures
(in reply to oops)
       Post #: 127
RE: Walkera #4 Fixed Pitch Helicopter Forum - 8/31/2005 6:14 PM
chench
Score: 100
Last Login: 6/5/2009
Status: offline
Does anyone want a 72 MHz reciever? 'Cos i got one lying around that i cant use because my transmitters on 35 and cant send back 'cos i opened the packaging so im gona sell it cheap. Nothing wrog with it to the best of my knowledge. E-mail me at pip.tabor@btinternet.com
Hide Signatures
(in reply to mazakari)
       Post #: 128
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/15/2005 7:07 AM
rctoysinchina
Score: 100
Last Login: 9/27/2005
Status: offline
We have a great number of walkera dragonfly No.4 in our UK store. They are 40 MHz in radio frequency that means cannot be used in UK. So we will sell them to Germany, France, Ireland, Italy and Spain in the lowest price . Welcome your inquriy .
Email : li_pp828@yahoo.com.cn
Hide Signatures
(in reply to chench)
       Post #: 129
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/24/2005 5:54 AM
SeaBear
Score: 100
Last Login: 7/22/2009
Status: offline
hello all from the latest victim of helifever. i got my dragonfly 4 yesterday and need some help. i've read this thread and there are alot of what seem like great ideas but there's so many i don't know where to start. here's where i am:
extremely violent shaking prior to what i think would be lift off
i moved to my living room floor which, i guess sort of helped. the carpet absorbs some of that shaking which may only be masking bigger problems
after that i begin to get lift off but it seems to want to dive right so i shut it down
after my latest session (which ended with a snapped tail rotor) my battery and tail motor seemed a bit on the warm side. not too hot to touch but warmer than they did after my 1st go round.
what should i do? can i fix the tail rotor or do i need to replace? how do i get this thing in the air? how long do i charge the battery and do i store it charged or leave it down? the so called manual said to do it for 2 hours before the first flight but what about after that?
i would appreciate any help you veterans can give me. i'm new to this. i actually bought and assembled a raptor 30 a couple of years ago but chickened out and sold it before i got it in the air.
also, any suggestions on how to make my radio work with the sim? my cord won't work with either simulator. i downloaded FMS and it wouldn't work with either. am i missing something or do i just have a bad cord?
thanks again.
Hide Signatures
(in reply to hrwatson68)
       Post #: 130
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/24/2005 9:44 AM
Crashnet2000
Score: 100
Last Login: 5/15/2008
Status: offline
I have the same problem with my new Dragonfly #4... I shakes like mad before lift off and when it starts to lift like 3 mm from the ground it starts to flip over to the right side !
OK i thought and started to play with the controler without diconnecting the battery wich was the dumbest thing i have done "i think".
I played with the dip switches on the back and all of the sudden the damn thing goes wild..... i turned of the radio controller but the helicopter gave full throotle and started to glide around so i jumped in and grabed it. Almost took my eye out when i tryed to disconnect the battery....
When i was trying to disconnect the battery it started to smoke from the receiver "4in1", now i am sitting here with a broken rotor head core, fryed receiver and broken tail boom !
When i opened the receiver up i could see one chip standing up! hmmm it seems that i can solder it back...
Can someone explain what the hell happend when i was playing with the dip switches.. I think it was the second one up that i toggled to the left ?
Why does i wooble around like a maniac ?
< Message edited by Crashnet2000 -- 9/24/2005 9:46 AM >
Hide Signatures
(in reply to SeaBear)
       Post #: 131
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/24/2005 10:23 AM
oops
Score: 100
Status: offline
Wobbling? It's the result of too low a headspeed when flying, or a serious balance issue on the ground.
Get the blades as tight as is practical. So they are stiff to move. Align them by hand. An imaginary line that passes through both screws on the head would intersect about the middle of the tip edge.
Make sure the paddles are horizontal and flat to the flybar.
Use enough throttle to get off the ground.
And never play with the dipswitches while the transmitter is turned on. One of them will go to full throttle.
David
Hide Signatures
(in reply to Crashnet2000)
       Post #: 132
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/24/2005 10:48 AM
Crashnet2000
Score: 100
Status: offline
i swear i will never play with them again !
The damn rotor spins so fast when it hit me yesterday in the arm i thought it would brake the bones....
Hide Signatures
(in reply to oops)
       Post #: 133
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/24/2005 12:15 PM
mazakari
Score: 100
Last Login: 1/8/2009
Status: offline
quote:
ORIGINAL: Crashnet2000
Hi Crashnet,
The dip switches are used to reverse the servo functions (and throttle as you have found out!! )
Example, if left stick low is throttle off and left stick high is full throttle, then reversing the throttle dip will give you left stick low 'full throttle' and left stick high will then become throttle off.
This is the same for the servo's, flicking the roll servo dip switch, left will become right and vis versa.
When checking these things its always worth disconnecting your motor. That way you won't give yourself a painful suprise!!
When setting up the throttle, remove both your main and tail blades so again you have made the heli 'safe'.
As for the wobble, as OOPS posted, you need to tighten the blades and align them as he has said. The heli does have a tendancy to drift near the take off point, this is due to its light weight and the collective yaw coupling effect. Once the heli is in the air and out of ground effect it will become a lot more stable.
The best way to get it into the air is to increase power so it becomes light on its skids and then just 'punch' it up into the air (get it through ground effect as quick as you can).
Once you have it a couple of feet high in the air it will become a lot more stable. As you become more proficient you won't have to use this method as you will naturally counter the effect without thinking about it.
Hope this helps a little and you can get your heli back together soon,
Jon
< Message edited by mazakari -- 9/24/2005 12:17 PM >
Hide Signatures
       Post #: 134
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/24/2005 3:42 PM
oops
Score: 100
Status: offline
Nearly broke your arm?
You're lucky it was a Walkera 4 !.. Otherwise, you would be feeling a LOT more sore...
Bigger heli's with wooden blades will easily break your arm, and possibly worse. Plastic blades will splinter, but still do considerable damage. At least the Walkera 4's are reasonably safe when you tangle with them.
Of course, on FULL throttle, that would be a little worse than the normal human-contact incidents most of us have.
They are reasonably safe to play with generally, except by playing with the dipswitch, you bypassed the safety.
The usual method for turning on is something like this... (For a Walkera 4)
1. Turn on transmitter. Set throttle LOW.
2. Turn on heli, while maintaining a GOOD grip on it.
3. Place Heli on level ground.
4. Briefly turn heli OFF. (Interrupt carrier signal).
5. Turn back on.
6. Check swashplate servo's are moving freely, then apply power slowly until rotor spins. Check tail rotor operation.
7. Fly.
Step 4 and 5 are far from ideal, but do reset the gyro. If you are confident with the heli, you can omit 1 and 4. I usually hold my heli's so that they are safe and I can kill the power quickly if there's an issue. Usually by the skids and tailboom in a wide grip with my right hand. Then if there's radio problems, I can kill the power quickly and safely.
As mazakari says, punch it up from the ground. Once you get skillful, you can take off into a 2cm hover without thinking, but otherwise, getting about 3 feet height is a good idea. Also, try to trim for level flight before you get to that stage. Or get a more experienced pilot to help you.
David
Hide Signatures
       Post #: 135
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/24/2005 7:15 PM
Crashnet2000
Score: 100
Status: offline
What are the correct dipswith settings ??? i can´t see anything in the damn Manual! i only see that the top4 is used but not how they are set.. Can someone help out before i really do something stupid
o yeah i almost forgot !
The damn 4in1 receiver burned out totaly it was not only the chip but the board and... every thing else it!
What should i get instead ? Please help a novice out
Thanks for all the help i got
< Message edited by Crashnet2000 -- 9/24/2005 7:29 PM >
Hide Signatures
(in reply to oops)
       Post #: 136
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/24/2005 8:09 PM
thecheatscalc
Score: 100
Last Login: 4/17/2009
Status: offline
what the hec have you been doing? you must be overloading the circut boards by doing something... like having a battery with too high of a voltage. also make sure that the blades are no more that 14 degrees. this is slightly more that the bottom of the blades being level with the ground. if you had it more that should explain a bit of your problems. Also make sure that the paddles arent loose, are at the same legnths and are at both at the same pitch usually 0-2 degrees (flat) ok?
_____________________________
www.ushobbysupply.com - your #4 HQ!
All stock located in the U-S of A!
Hide Signatures
       Post #: 137
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/25/2005 11:24 AM
Crashnet2000
Score: 100
Status: offline
i havent done anything to overload it.. i think
The company i bought it from will ship out a new one including a new battery, they think the burned receiver was the batterys foult.
What about the dipswitches ? Anyone who could share some info on how your settings are ?
Thanks alot
Hide Signatures
(in reply to thecheatscalc)
       Post #: 138
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/25/2005 12:26 PM
chench
Score: 100
Status: offline
Crashnet2000 - The first one down should be to the right, the second to the left, the third and fourth to the right, and all the rest to the left.
Does anyone know where i can get the screws that hold in the tail motor as iv lost mine, thanks.
Hide Signatures
       Post #: 139
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/25/2005 1:47 PM
Crashnet2000
Score: 100
Status: offline
like this ?
1 on
2 off
3 on
4 off
Hide Signatures
       Post #: 140
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/25/2005 4:04 PM
chench
Score: 100
Status: offline
No,
1 on
2 off
3 on
4 on
5 off
6 off
7 off
8 off
Hide Signatures
       Post #: 141
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/25/2005 5:02 PM
tomcatguy74
Score: 104
Last Login: 8/28/2009
Status: offline
Hi all,
I have been thinking about getting one of these walkera #4s.
Is this the heli that the forum is about?
http://cgi.ebay.com/NEW-DRAGONFLY-RADIO-CONTROLLED-HELICOPTER-V4-6-BONUS_W0QQitemZ5999996051QQcategoryZ2563QQrdZ1QQcmdZViewItem
What can you tell me about this heli?
Is this the heli that has the "next generation stock servos that won't go bad like was said earlier in the forum?
This is coming from Canada, so is it possible they will have better customer service?
I had a Rotofly once and only kept it for a few days. I broke it a few times and was not reallt successful in flight.
This heli shown above on ebay has a sim and cable so I guess I could learn on it.
Please give me some opinions on it please. It only has 16 hrs left!!!
Oh, how is the sim that come with the heli, is it any good?
Sorry for all the questions, I just want to be prepared.
Rob
< Message edited by tomcatguy74 -- 9/25/2005 5:48 PM >
Traxxas Revo 3.3, E-maxx 3905
Team Losi Micro-T
E-Flite Blade 400 & Blade mCX
Parkzone T-28
Hide Signatures
       Post #: 142
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/25/2005 6:03 PM
Crashnet2000
Score: 100
Status: offline
Thanks a lot
Hide Signatures
       Post #: 143
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/25/2005 6:06 PM
Crashnet2000
Score: 100
Status: offline
Buy it from this seller instead...
http://cgi.ebay.co.uk/New-Dragonfly-4-4CH-R-C-Electric-Helicopter_W0QQitemZ6001076412QQcategoryZ2563QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Good price and very good seller
quote:
ORIGINAL: tomcatguy74
Hi all,
Rob
Hide Signatures
(in reply to tomcatguy74)
       Post #: 144
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/25/2005 7:35 PM
tomcatguy74
Score: 104
Status: offline
Hi crash and everyone!
That is a definate place to buy!!! Please tell me what you think of this heli? I also have questions in the post above yours about the heli and the simulator.
Is the heli highly upgradeable?
Thanks for the link!!
Rob
< Message edited by tomcatguy74 -- 9/25/2005 7:42 PM >
Team Losi Micro-T
Parkzone T-28
Hide Signatures
       Post #: 145
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/26/2005 11:56 PM
thecheatscalc
Score: 100
Status: offline
yes it is just look in the "offical place to show off helis" post look at mazkaratzi's heli that's a #4 (at least most of his pics are) so yes you can upgrade it quite a bit, and I do hear it's a very sturdy bird. go for it it's also the best deal you can find anywhere.
Hide Signatures
       Post #: 146
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/27/2005 3:48 AM
tomcatguy74
Score: 104
Status: offline
I found a better deal though and bought it.
Look at all the goodies it comes with!!
Team Losi Micro-T
Parkzone T-28
Hide Signatures
       Post #: 147
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/27/2005 4:02 AM
tomcatguy74
Score: 104
Status: offline
Hi guys,
What plugs will the batts for the dragonfly have? I have a phrophet plus charger for all my mini cars and I have the micro, deans, tamyia, and the HPI plugs.
Rob
Team Losi Micro-T
Parkzone T-28
Hide Signatures
       Post #: 148
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/27/2005 9:14 AM
Crashnet2000
Score: 100
Status: offline
yeah, that is the seller i recommended in tha last post so techicly i found it for you
< Message edited by Crashnet2000 -- 9/27/2005 9:15 AM >
Hide Signatures
       Post #: 149
RE: Walkera #4 Fixed Pitch Helicopter Forum - 9/27/2005 12:59 PM
tomcatguy74
Score: 104
Status: offline
Thanks Crash. I appreciate it bud!!
Rob
Team Losi Micro-T
Parkzone T-28
Hide Signatures
       Post #: 150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.578RCU1
