oops -> RE: Walkera #4 Fixed Pitch Helicopter Forum (9/24/2005 3:42:30 PM)
Nearly broke your arm? You're lucky it was a Walkera 4 !.. Otherwise, you would be feeling a LOT more sore... Bigger heli's with wooden blades will easily break your arm, and possibly worse. Plastic blades will splinter, but still do considerable damage. At least the Walkera 4's are reasonably safe when you tangle with them. Of course, on FULL throttle, that would be a little worse than the normal human-contact incidents most of us have. They are reasonably safe to play with generally, except by playing with the dipswitch, you bypassed the safety. The usual method for turning on is something like this... (For a Walkera 4) 1. Turn on transmitter. Set throttle LOW. 2. Turn on heli, while maintaining a GOOD grip on it. 3. Place Heli on level ground. 4. Briefly turn heli OFF. (Interrupt carrier signal). 5. Turn back on. 6. Check swashplate servo's are moving freely, then apply power slowly until rotor spins. Check tail rotor operation. 7. Fly. Step 4 and 5 are far from ideal, but do reset the gyro. If you are confident with the heli, you can omit 1 and 4. I usually hold my heli's so that they are safe and I can kill the power quickly if there's an issue. Usually by the skids and tailboom in a wide grip with my right hand. Then if there's radio problems, I can kill the power quickly and safely. As mazakari says, punch it up from the ground. Once you get skillful, you can take off into a 2cm hover without thinking, but otherwise, getting about 3 feet height is a good idea. Also, try to trim for level flight before you get to that stage. Or get a more experienced pilot to help you. David
