RE: Walkera #4 Fixed Pitch Helicopter Forum
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Dragonfly 40
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: Walkera #4 Fixed Pitch Helicopter Forum
    Page: <<   < prev  7 8 [9] 10 11 12 13 14 15 16   next >   >>
    Login
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/3/2005 5:35:35 PM
    chench
    Status: offline
    Everytime my tail rotor hit something when its spinning it stops and doesnt respond until two or three minutes later; is this just because it straining has heated the electronics up a bit? Also, any solutions for keeping the tail rotor from hitting stuff when on the ground - what about trimming a bit off the tail rotor or would this have too effect on the trimming?
    I trimmed mine by powering up on the hall floor which is slippy and ajustin according to which way it slid.
    Chench
    (in reply to mazakari)
           Post #: 201
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/3/2005 6:20:28 PM
    Crashnet2000
    Status: offline
    Here is my baby so far... i still dont know if she will fly any good.
    I did all these mods during my wait for the new rotor head and a new 4in1 that burned out because the foulty battery.
    What do you think so far ? And do you think she will fly better then the original setup
    Click on my Gallery to view some bigger pictures
    http://www.rcuniverse.com/gallery/galleryCat.cfm?memID=202318
    < Message edited by Crashnet2000 -- 10/3/2005 6:34:28 PM >
    (in reply to chench)
           Post #: 202
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/3/2005 6:30:15 PM
    xelltronics
    Status: offline
    To all walkera lovers out there having tail rotor problems: I simply used the old tail rotor hub, cutoff the damaged blades and replaced them with thick plastic blades from used plastic jars. Just do not tighten the screws too much so they can swing freely when they hit the ground or something. Make sure you make the new blades the same size as the original or slightly larger or you'll have trim problems. Hope this helps!
    Click to see fullsize image.
    Click for fullsize
           Post #: 203
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/3/2005 6:33:26 PM
    xelltronics
    Status: offline
    crashnet, I'd like to see bigger pics but they won't work. Modifications look interesting...
    (in reply to Crashnet2000)
           Post #: 204
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/3/2005 6:34:59 PM
    Crashnet2000
    Status: offline
    Try here
    quote:
    ORIGINAL: xelltronics
    (in reply to xelltronics)
           Post #: 205
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/3/2005 6:44:10 PM
    chench
    Status: offline
    Aw CURSE! Was doing some nice hovering over the lawn when the heli hit the ground - not very hard, but hard enough for me to power down and have a look at it - and the servo, the brand new one i only installed this afternoon, is not responding, just like the one it replaced. Why is this?!
           Post #: 206
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/3/2005 7:09:33 PM
    xelltronics
    Status: offline
    Did'nt notice that link... ... your mods simply look really heavy-duty! those aluminum angle bars and bolts will surely survive g-forces anytime!
           Post #: 207
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/3/2005 7:14:58 PM
    Crashnet2000
    Status: offline
    those are really light
    i will cut down the bolts and drill more holes to the alu.. But do you think it is to heavy ?
           Post #: 208
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/3/2005 8:37:12 PM
    chench
    Status: offline
    Alrite, false alarm bout the servo. Think my tail motor is dying though - only works for like a minute then stops . . . Anyone got any ideas for upgrades on it?
           Post #: 209
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/3/2005 8:55:32 PM
    xelltronics
    Status: offline
    They do add to the weight. Before my walkera was still new, I hooked a small camera and a 9V battery and was still able to fly but with full throttle. Checkout my heli now with huey body. Total Weight is around 312 grams but still flies on stock motor and 8.4V NiMh.
    Click for fullsize
           Post #: 210
    RE: Walkera #4 Fixed Pitch Helicopter Forum - 10/4/2005 1:50:09 AM
    SeaBear
    Status: offline
    Trim question....i punched it up in the air and i did not touch the right stick so i could see what adjustments i need to make. avoided a brick wall safely but on the 3rd 'hop', as it were, i broke my tail rotor....again. so here's my question.....during my short flight i was moving forward and drifting right. also nose turning slightly right. so i think i need to move the right-left trim switch to the right and the forward-back trim switch up. am i true? i'm just trying to save a little time since my flights seem to be brief and always result in a broken tail rotor. God bless the Devcon Plastic Weld people.
    Bryan
