Rapter 30 Collective Limits
Tower Hobbies
Logged in as Guest
  Printable Version
Brshless up graded E-Flite Blade CP Pro w/Spektrum Rcvr - RTF
Seller:  hhager2
Details:   $500.00   |  11/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> RC Helicopter General Discussions >> Rapter 30 Collective Limits
Page: [1]
Login
Rapter 30 Collective Limits - 12/27/2001 7:19:39 AM
volare
Status: offline
I tried to use the method in Rays's Heli Manual
to figure out the collective limits on my Raptor 30 but it didn't work for me. I never felt the pushrod move and I ended up calculating about 40 degrees of usable pitch, which I'm sure isn't right. Does anyone have any suggestions to figure out how much usable pitch there is? Or can you just tell me how much there usually is on this bird?
       Post #: 1
Rapter 30 Collective Limits - 12/27/2001 9:04:48 PM
volare
Status: offline
That's all good but I want to know the actual LIMIT for the usable pitch without getting binding. You aren't telling me that for sure...
< Message edited by volare -- Dec 27 2001 4:07PM >
(in reply to volare)
       Post #: 2
Rapter 30 Collective Limits - 12/27/2001 9:47:23 PM
Scotty740
Status: offline
I you use the full travel of the pitch arm in of the in the window of the frame you should be able to get about 22 deg total pitch travel. That should work without binding if you keep the cyclic pitch on the main blades to 6 or 7 deg.
You should be able to set the pitch arm at the bottom of the window and read the pitch on the main blades with the swash plate level then raise the pitch arm to the top of the window and check again. I have mine set to about -10 deg to +11 deg. You can vary this range by changing the length of the long links going to the head from the swashplate.
_____________________________
Scott Stickle
       Post #: 3
Rapter 30 Collective Limits - 12/28/2001 12:46:18 AM
volare
Status: offline
Okay, thanks.
I don't know what happened the first time but I measured again and I have +13 and -11.5 That is still more than usual from what I've read...but I guess more is better than less.
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.363RCU3
