New RealFlight G3 Public Beta update available: .387
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> New RealFlight G3 Public Beta update available: .387 Page: [1] 2   next >   >>
Login
New RealFlight G3 Public Beta update available: .387 - 4/9/2005 1:34 AM
jaafit
Score: 100
Last Login: 2/12/2009
Status: offline
A new public beta version of RealFlight G3 is now available. This update fixes a number of bugs; the complete list will follow.
This version is currently available only on the public beta site, although we believe it to be a stable version, and we plan to make it an official public version in the near future. If you experience any of the problems which the revision list below states are now fixed, we encourage you to try this new version. Note that if you have not yet installed the heli update, this version will be a large download, since it includes the heli update.
Perform the following steps to obtain the update:
Start the RealFlight G3 Launcher
Click Additional Options, then Technical Support
Click Enter Tech Support Code
Enter the following code: B#e3j3ea45h598 (If successful, you will see a message saying "You are now registered to use the Public Beta site until the new version is posted to official download site.")
Go back to the main Launcher menu and click Registration/Updates
Make sure that in the bottom left corner it says Temporary Public Beta (PS). If not, try reentering the code
Either click Update to Latest Version (which should tell you that .387 is available) or click Update to Specific Version and choose .387.
The Launcher will need to restart partway through this process. Answer "Yes" when it asks if you want to continue downloading the new version. When this process is finished, you will have RealFlight G3 version .387.
Please post and let us know whether or not this new versions resolves the issues described below. Also, please let us know if you find any new bugs (that is, bugs that did not exist in version .366).
Revision list
Fixes specific to version .387
ADDED: Sukhoi (AO3): added 3D version as alternate choice in aircraft selection dialog
FIXED: Sukhoi (AO3): reduced throws on non-3D version to make it a sport plane
FIXED: Big Stik (AO1): changed to .40 size engine and reduced weight accordingly to match Great Planes Bit Stik 40 kit
FIXED: Corsair (AO1): moved CG, reduced weight in some areas, added incidence to horizontal stab to reduce climbing tendency, and added more flaps
FIXED: Piper Cub (AO1): changed engine to .52 four stroke to match description; lowered wing strength to 85%
FIXED: T-34 (AO5): reduced elevator throw
FIXED: Tiger Moth (AO5): reduced elevator throw and increased aileron size and throw to tame down in pitch and give more roll authority
FIXED: Taylor Craft (AO4): increased elevator throw and also corrected elevator chord percentages as they were not consistent with the mesh
FIXED: Extra 330 (AO3): reduced rudder throw at low rate; modified cg locations and throws for greater stability; enlarged vertical stab to avoid snap rolling at near-stall alphas
FIXED: P-38 (AO3): removed aileron-rudder mixing; increased throws in elevator and ailerons
FIXED: Stinson Reliant (AO3): moved cg, lightened plane, increased size of vertical stab, adjusted throws, modified wing to reduce taper, and made other extensive changes to correct snap rolling tendencies and improve overall flight quality
FIXED: Dazzler (AO2); lightened aircraft; adjusted cg and throws; enlarged vertical stab size; changed propeller to lower pitch, higher diameter. Plane now flies 3D much better and rudder no longer intersects elevator
FIXED: Slinger: removed unused components (smoke servo, etc.)
FIXED: Pitts (AO4): reduced weight considerably, adjusted throws. Much easier to fly now
FIXED: Sopwith Camel (AO2) bug where the wrong airfoil would be used with very old versions of the AO2 disk
FIXED: Battleship (AO4) airport description
FIXED: Tail boom break-apart issues with all helis
FIXED: Simple Flier spins and flies up in the air sometimes after crashing
FIXED: P-38 (AO3) ailerons don't move
FIXED: P-38 (AO3) wings break off too easily
FIXED: Osprey (AO5) elevator doesn't move
FIXED: Stinson Reliant (AO3) ailerons don't move
FIXED: Assorted spelling, grammar, and typo errors in menus and text
FIXED: Tutor Cabin Trainer (AO4) rudder doesn't move
FIXED: Huey tail rotor moved to correct location
FIXED: Concept EP CG
FIXED: Heli servo naming inconsistencies
FIXED: Adjusted some heli component strength multipliers
FIXED: T-34 (AO5) visual landing gear problems
FIXED: Viewing ledge airport object is closed on the back
FIXED: PT-40 see-through problems related to break-apart
FIXED: BLT Park Flyer tail skid to improve landing behavior
FIXED: Fundango tail skid to improve landing behavior
FIXED: IFO landing gear wires to improve landing behavior
FIXED: Viper (AO5) landing gear wires to improve landing behavior
FIXED: P-47 (AO3) see-through problems related to break-apart
FIXED: Radio gadget, white dots on the gimbals had display glitches
FIXED: Giles 202 (AO3) is too easy to tip over
FIXED: Viper (AO5) breakapart mapping and tail skid art
FIXED: Ecureuil see-through problems related to break-apart
FIXED: Huey tail rotor blur disk
FIXED: Bell 222 tail rotor blur disk
FIXED: Dolphin pushrod alignment, white boom supports, and blur disk issues
ADDED: Implemented wheel inertia, so wheels will continue to spin for a few seconds after takeoff
ADDED: Protection against several errors that could cause invalid results (and possibly crashes) during collision calculations
FIXED: Optimizations to the collision system so that it is faster and uses less memory to perform its computations
FIXED: Improved object-to-object contact model
FIXED: Resetting aircraft when another aircraft is at the plane spawn causes prop strike
FIXED: Orientation of aircraft in airplane editor is affected by retract position when loaded
FIXED: Aircraft orientation in aircraft editor affected by aircraft orientation in sim world
FIXED: Init problem that caused helis to be unstable until reset when loaded after an airplane
FIXED: Gyros reset when aircraft is reset; keeps aircraft like the Osprey from tipping over sometimes immediately after reset
FIXED: Improved reset code so that objects rest correctly on reset
FIXED: Crash that occurred in some aircraft when changing propeller type to ducted fan
FIXED: Some potential random crashes
FIXED: Crash when attempting to rename a resource that is currently in use
FIXED: Crash when loading VFI's back to back that were created at different airports
FIXED: Crash that occurs when using old versions of AO1 & AO2 disks
FIXED: Crash that occurs when AO1 or AO2 are installed and a sound profile is selected that is also available on those disks
FIXED: View->Show All doesn't enable pilot nametags
FIXED: Changing color scheme in aircraft selection dialog for airplane currently in use causes the wrong scheme to be marked as active in the Aircraft->Select Color Scheme menu
FIXED: View->Show All is sometimes disabled incorrectly
FIXED: Save as… will allow overwrite of existing file after prompting
FIXED: Camera lag causes jittery view in walk mode
FIXED: Walk mode sometimes behaves as if mouse input was supplied when it wasn't
FIXED: Numerous View bugs, including zoom mode persistence, walk mode behavior issues, etc.
ADDED: read-only property of rotor to aircraft editor which shows pitch values
ADDED: throttle and pitch curves to the helicopters
ADDED: Create empty color schemes directory on user's drive if not found
ADDED: Allow zoom in preview window using +/- keys
FIXED: Flight model change to increase lateral stability during a hover
FIXED: Governor: editor shows armed and active, and shows correct target RPM
FIXED: Headspeed governor setup for helis, so that throttle input now goes to governor, which in turn is fed to actual throttle servo
FIXED: Improved handling and detection of illegal characters in filenames and descriptions
FIXED: Aircraft editor background to match other viewport backgrounds
FIXED: "Airframe" moves around in airport editor hierarchy when certain options are changed
FIXED: Custom color schemes now work for all aircraft
FIXED: Removed "Open as read-only" checkbox from open recordings dialog
FIXED: Pressing controller button while in aircraft editor makes aircraft disappear
FIXED: In slope soaring primer (VFI), aircraft flies through ground
FIXED: FM radio interference flight failure is now much more severe
FIXED: In NavGuides, volts and amps always displayed 0 for electric helis
FIXED: Problems caused by deleting files for the most recently used airport before running the sim again
FIXED: Launcher performs some additional cleanup during uninstall
FIXED: Directory removal bug (sometimes empty directories would be left behind)
FIXED: rotor disk scaling issues, so that now rotors disks/propellers appears the same size in recordings/multiplayer as they do on the local machine
FIXED: removed some unused heli mixing
Fixes which were added in .377
ADDED: Progress bar during collision mesh generation
ADDED: Factor in wheel velocity when determining ground penetration depth
ADDED: More descriptive warning messages when unsupported graphics cards detected
ADDED: In airport selection dialog, moved RealFlight G2 airports to their own folder, separate from G3 airports
ADDED: Support for transmitter modes 1, 3, and 4 in Radio Gadget
ADDED: Option to turn shadows on/off, in addition to shadow quality setting
ADDED: Online update size and estimated download time notification
ADDED: Prevent Windows 95/98/ME from switching to fullscreen mode, which caused crash
FIXED: Slowdown after changing airport (NVidia)
FIXED: Intermittent lockup on startup fixed for some cases
FIXED: Potential crash after receiving "You do not have this airplane..." message
FIXED: Bug that caused error message after G3 had been running for a number of hours
FIXED: Crash when too many objects are being drawn
FIXED: Ground handling improvements and optimizations
FIXED: Aircraft/objects resting on other objects (aircraft can now land on objects)
FIXED: Wheel camber and toe-in problems, which caused ground handling problems for aircraft with gears that are swept forward or back
FIXED: More "glass wall" collision problems
FIXED: Bouncy wheels on some airplanes
FIXED: Issues with helicopter fuselages penetrating ground and overly active broken-off parts
FIXED: Surface roughness behavior (ground is bumpier off of the runway)
FIXED: Screen resolution is persistent
FIXED: Removed non-functional Anisotropic Filtering slider. User can set this through system hardware settings (GeForce or ATI control panel)
FIXED: Backspace resets autozoom
FIXED: Look At menu in MultiMode to offer correct options for player 2
FIXED: Minimum/maximum field of view camera settings now work as intended
FIXED: Fixed crash when using Quick Look functions while in chase view
FIXED: No longer lists disconnected G2 interlink
FIXED: Moved "View Pilot Name Tags" to "View->Show" menu
FIXED: Double-clicking in selection dialogs
FIXED: Assorted other minor UI improvements
FIXED: Better default values for controller calibration
FIXED: Prevent user from entering invalid username
FIXED: Prevent invalid multiplayer participant count (-1)
FIXED: "Radio out of range" flight failure made less severe
FIXED: Randomized PCM lockout flight failure
FIXED: Wind direction in gadget always displays 0 in place of 360
FIXED: Inapplicable NavGuides now reset to "0"
FIXED: Missing engine in recordings
FIXED: Audio playback during recordings/VFI now enabled while in cockpit mode
FIXED: Switched aircraft icon colors to match airport icons
FIXED: Launcher's default setting for "Check for updates before starting RealFlight" is now "off"
FIXED: Incompatibility with non-IE web browsers when attempting to open the manual from within G3 or the Launcher (Firefox, Opera)
FIXED: Chase camera now starts behind aircraft
FIXED: Prevent control objects from being placed underground in airport editor
FIXED: Mountain Pass airport terrain decal appeared small the very first time that airport was loaded
FIXED: Island Paradise airport: windmill objects now turn, bridge is not floating in midair
FIXED: Most of the airplanes were modified for camber, toe-in, and minor adjustments to wheel and landing gear position/angles
FIXED: Corsair main gear protruding through top of wing when retracted
FIXED: Extra 330L missing texture
FIXED: Bell H-13 scale fuel tanks now detect collisions
FIXED: Spitfire main gear protruding through top of wing when retracted
FIXED: P-38 steering gear
FIXED: Remove retract servo from AT-6 steering gear (was incorrect)
< Message edited by jaafit -- 4/12/2005 9:05 AM >
Hide Signatures
       Post #: 1
RE: New RealFlight G3 Public Beta update available: .387 - 4/9/2005 2:08 AM
jimmyd56
Score: 100
Last Login: 3/14/2010
Status: offline
Are you ever going to fix the weird plane names that come up after restarting sim? These are plane's that don't exist. Also after installing update Heli's don't work. #1on list.
Click to see fullsize image.
Click for fullsize
< Message edited by jimmyd56 -- 4/9/2005 2:10 AM >
Hide Signatures
(in reply to jaafit)
       Post #: 2
RE: New RealFlight G3 Public Beta update available: .387 - 4/9/2005 2:22 AM
Matt Merciez
Score: 100
Status: offline
Performed the update and am now unable to launch the sim. After installing the update, I was prompted for the G3 Heli Update CD which I do not have. I put in the original G3 CD. On launch I am getting the following error:
Error: D3DERR_invalidcall
file: M\releases\2005_dominion\kelib3\directx\dxeffect.hpp
Line 604
The only way out of the sim is to CRL-alt Delete
_____________________________
Matt Merciez
Hide Signatures
(in reply to jimmyd56)
       Post #: 3
RE: New RealFlight G3 Public Beta update available: .387 - 4/9/2005 2:27 AM
peefiddyonefan
Score: 100
Last Login: 4/28/2005
Status: offline
Same here!
KnifeEdge has already pulled the update because so many are having problems.
quote:
ORIGINAL: Matt Merciez
Line 604
Download my G3 colorschemes and Plane tweaks at
www.RickDelten.com
Hide Signatures
(in reply to Matt Merciez)
       Post #: 4
RE: New RealFlight G3 Public Beta update available: .387 - 4/9/2005 2:30 AM
Matt Merciez
Score: 100
Status: offline
I was able to go back to version 377 with no problems.
Matt Merciez
Hide Signatures
(in reply to peefiddyonefan)
       Post #: 5
RE: New RealFlight G3 Public Beta update available: .387 - 4/9/2005 3:58 AM
r1derbike
Score: 100
Last Login: 11/25/2009
Status: offline
I had to install fresh from the CDs...back up with .366 now, and all addons.
Charles
"Sometimes, I run out of altitude and airspeed...at the same time!"
Hide Signatures
       Post #: 6
RE: New RealFlight G3 Public Beta update available: .387 - 4/9/2005 4:03 AM
r1derbike
Score: 100
Status: offline
Ryan has just posted a workaround @ the KE site.
Charles
Hide Signatures
(in reply to r1derbike)
       Post #: 7
RE: New RealFlight G3 Public Beta update available: .387 - 4/9/2005 6:50 AM
jaafit
Score: 100
Status: offline
Yes he did. The workaround is:
If you have .313 CDs, have already updated to .387 and are receiving an error when you attempt to run, please follow these instructions to get around it:
Download the RFV3HELI.dck from here. Note that this file is approx. 100MB in size.
Copy it into your C:\Program Files\RealFlightG3\Data directory.
Delete your C:\Program Files\RealFlightG3\Temp directory.
Now, you should be able to run without any errors.
We apologize for this situation, and will work to fix it as soon as we can. We will keep you posted.
< Message edited by jaafit -- 4/9/2005 8:31 AM >
Hide Signatures
       Post #: 8
RE: New RealFlight G3 Public Beta update available: .387 - 4/9/2005 12:27 PM
Matt Merciez
Score: 100
Status: offline
Thanks for releasing the beta patches to the public I have the new version working just fine with the workaround posted. Keep up the great work, I know I appreciate your efforts.
Matt Merciez
Hide Signatures
       Post #: 9
RE: New RealFlight G3 Public Beta update available: .387 - 4/9/2005 5:01 PM
jhimmel
Score: 100
Last Login: 11/18/2006
Status: offline
Wow, nice list of fixes.
Like others, I got the error messages after the update.
However, after updated install procedure - all is working well and I am enjoying the beta update!
Jim H.
Hide Signatures
       Post #: 10
RE: New RealFlight G3 Public Beta update available: .387 - 4/9/2005 7:36 PM
BasinBum
Score: 1127
Status: offline
I got mine working no problem. I can hover the Extra in AD#1 finally and it feels a lot like my Wildhare maybe just a little "smaller" feeling. Between this update and the planes on Rick Delten's site I'm loving G3. I now need a faster video card so I can run trees and objects but that stuff is secondary to having realistic planes to fly for me. I have been working on point rolls for the last week and when I went out to the field everything translated exactly and my flying was much improved in that area so trees and everything are not nearly as important as flight physics.
Having tried some other sims I was disapointed with some of the planes on G3. The snapping and "heavyness" made them hard to fly. I watched someone stuff an Extra the other day with a G62 on a smaller airframe and realized that a lot of the G3 planes are just realistic, a lot of planes out there fly like crap. The Rick Delten downloads all fly like 40% planes which is great but if you want to learn not to crash your old Kyosho Cap232 a snapping simulator is the best practice.
Keep up the good work!
Hide Signatures
(in reply to jhimmel)
       Post #: 11
RE: New RealFlight G3 Public Beta update available: .387 - 4/9/2005 11:17 PM
r1derbike
Score: 100
Status: offline
A top-notch gaming system is required to utilize G3 to its fullest. You may turn-off features to run on lesser systems. The snappiness of the planes makes better pilots. The "feel" of G3 after you get used to its quirks, is closer to the real-deal than other "floaty", "dreamy" sims I've tried. YMMV. It WILL make you a better 3D pilot. There is so much to explore with G3, you'll be hard-pressed to fly every inch of it. A favorite of mine, is slope-soaring with 3D airplanes, at idle, and of course, 3D flying. Keeping G3 instead of selling for AFPD was the right thing for me, after flying AFPD. Even with the sim sped-up, it just felt too "floaty" and unrealistic for me, as if invisible helium balloons were tethered to the aircraft. YMMV
Favorite airplanes in order:
Edge 540 (3D mod)
Hangar 9 46% Ultimate
Yak-54 (3D throws/surfaces)
P-51 (Miss America)
A-10 Wart Hog
P-38 Lightning
L-39
Charles
AMD Athlon 64 FX-55
DFI LanParty NF4 Ultra D - NF4310 Bios
EVGA 6800 Ultra 256 meg PCI-e Video Card(s) SLI
OCZ PC4200 EL Platinum 1 Gig Kit DIMMs
Archos External 20 Gig USB Drive/Player
Western Digital 74 Gig Raptor SATA Drive
Seagate 100 Gig IDE Drive
Seagate 200 Gig IDE Drive
NEC DVD+/-RW DL ND-3520A Drive
Asus CD-S480/AH CDROM Drive
Asus Digital Media Reader
Thermaltake Silent Boost Cooler
Thermaltake Silent Power 680 watt supply
Thermaltake Tsunami Dream Case
Samsung 900DF CRT monitor
__________________
< Message edited by r1derbike -- 4/9/2005 11:29 PM >
Hide Signatures
(in reply to BasinBum)
       Post #: 12
RE: New RealFlight G3 Public Beta update available: .387 - 4/9/2005 11:19 PM
r1derbike
Score: 100
Status: offline
Almost forgot. KE is doing superb job listening to its customers, and acting quickly to address issues.
Charles
Hide Signatures
       Post #: 13
RE: New RealFlight G3 Public Beta update available: .387 - 4/9/2005 11:41 PM
r1derbike
Score: 100
Status: offline
Basin:
I just had to try the Extra...that thing is a torque-rollers dream! Very nice TRs! Prefer the Technicoll colorscheme. If many planes have been reworked like the little Extra, they are headed in the right direction!
Off to fly other planes...
Charles
Hide Signatures
       Post #: 14
RE: New RealFlight G3 Public Beta update available: .387 - 4/10/2005 5:15 AM
JimSlone
Score: 100
Last Login: 5/13/2005
Status: offline
Thank you!
Hide Signatures
       Post #: 15
RE: New RealFlight G3 Public Beta update available: .387 - 4/12/2005 6:00 AM
Bud Faulkner
Score: 105
Last Login: 7/28/2008
Status: offline
jaffiit, when you said to copy the RFV3HELI to a temporary file and put it back after downloading the update do you mean cut and paste or copy? If I copy and move it it's still there and when I put it back I will be asked if I want to overide the existing one? Thanks,
Bud
"The propeller is the fan that keeps the pilot cool, turn it off and watch him sweat"
Hide Signatures
(in reply to JimSlone)
       Post #: 16
RE: New RealFlight G3 Public Beta update available: .387 - 4/12/2005 6:52 AM
BasinBum
Score: 1127
Status: offline
Bud,
Go back and read the directions again, you don't copy it to a temp file.
Hide Signatures
(in reply to Bud Faulkner)
       Post #: 17
RE: New RealFlight G3 Public Beta update available: .387 - 4/12/2005 9:03 AM
jaafit
Score: 100
Status: offline
We fixed the problem so you can ignore those extra steps now. In fact, I'm gonna go edit that post again lol.
Hide Signatures
       Post #: 18
RE: New RealFlight G3 Public Beta update available: .387 - 4/12/2005 2:22 PM
Bud Faulkner
Score: 105
Status: offline
I did as the instructions said yesterday before you edited it...I copied the helidck and replaced it after downloading, the file size was the same and RF ran fine but what if anything did it do to the heli file? When I overrode it with the one I put in a temp folder did I lose any of the heli download?
Hide Signatures
       Post #: 19
RE: New RealFlight G3 Public Beta update available: .387 - 4/12/2005 5:41 PM
jaafit
Score: 100
Status: offline
Nope; absolutely nothing would have changed.
quote:
ORIGINAL: Bud Faulkner
Hide Signatures
       Post #: 20
RE: New RealFlight G3 Public Beta update available: .387 - 4/12/2005 9:28 PM
Pantryman
Score: 100
Last Login: 1/7/2006
Status: offline
Hi!
I tried entering the code but
1. I cannot enter smallcap characters.
2. Nothing happens; I still get very old official updates.
Anyone knows what could cause this?
Thanks in advance.
Pantryman.
Hide Signatures
       Post #: 21
RE: New RealFlight G3 Public Beta update available: .387 - 4/12/2005 11:58 PM
BasinBum
Score: 1127
Status: offline
Try cut and pasting the codes
Hide Signatures
(in reply to Pantryman)
       Post #: 22
RE: New RealFlight G3 Public Beta update available: .387 - 4/13/2005 3:47 PM
Pantryman
Score: 100
Status: offline
Thanks BasinBum!
It worked great.
Pantryman.
Hide Signatures
       Post #: 23
RE: New RealFlight G3 Public Beta update available: .387 - 4/14/2005 3:45 AM
Pantryman
Score: 100
Status: offline
jaafit,
with .387 and multiplayer / trying to Join I get the following error:
Error creating effect G3terrainred
ntdll.dll
offset 00001010
mod ver 5.1.2600.2180
it completely locks up.
Any idea?
< Message edited by Pantryman -- 4/14/2005 3:52 AM >
Hide Signatures
       Post #: 24
RE: New RealFlight G3 Public Beta update available: .387 - 4/14/2005 6:07 PM
jaafit
Score: 100
Status: offline
Did you try going back to .366 to see if that helped?
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.766RCU1
