Re: Transfer of digital video to PC
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Digital Video (DV) & Video Editing Software >> Re: Transfer of digital video to PC Page: [1]
Login
Re: Transfer of digital video to PC - 4/10/2005 1:15:40 AM
Langster
Status: offline
Hi,
I have just purchased a Canon 850i digital camcorder. Although I can transfer stills and low resolution footage from the cameras SD mnemory card to my PC through a USB cable I can't transfer any video using this link. Is the firewire connection the only way to send digital video to my PC?
Thanks for any help
Lang
       Post #: 1
RE: Re: Transfer of digital video to PC - 4/10/2005 7:18:17 AM
lcacciatore
Status: offline
Yes you need to use the firewire connection to transfer your video to your PC.
(in reply to Langster)
       Post #: 2
RE: Re: Transfer of digital video to PC - 4/10/2005 7:18:38 AM
J_R
Status: offline
http://www.canon.com.au/support/customer/default.asp?DXI=KnowledgeBase/Customer/KBArticleForm&File=KB01173&productID=mv850i
Check this Australian Cannon site
       Post #: 3
RE: Re: Transfer of digital video to PC - 4/11/2005 12:00:48 AM
Langster
Status: offline
Thanks lcacciatore and J_R,
This information is very helpful and hopefully I can pick up the right Firewire card in the next week or so.
Lang
(in reply to J_R)
       Post #: 4
RE: Re: Transfer of digital video to PC - 4/11/2005 4:07:57 PM
J_R
Status: offline
Look for a kit that contains the cable and the card. If you don't you may pay more for the cable than the card.
Also note how many pins are necessary on the camera, for the cable. Firewire generally comes with either a 6 pin to 6 pin cable, or a 6 pin to 4 pin. All cameras I have see use the 6 to 4.
       Post #: 5
RE: Re: Transfer of digital video to PC - 4/26/2005 11:40:13 PM
Langster
Status: offline
Thanks again,
I have purchased a firewire card and editing software (Pinnacle Studio Plus, Version 9.3.0) and have made some flying videos...excellent. But another question can anyone tell me what format is typically used for flying videos on the net?
Lang
(in reply to J_R)
       Post #: 6
RE: Re: Transfer of digital video to PC - 4/27/2005 1:27:19 AM
Fubar-One
Status: offline
If you mean videos on a site that others can watch/download then usually they are in Windows Media Format or wmv.
With Studio 9 you can play with the frame rates when it comes to "Make Movie" time for higher or lower quality.
My stuff is all wmv except for whatever I plan to burn into a DVD movie. I save those in MPEG format for later in addition to the wmv streaming videos.
_____________________________
"B Positive to ground, over..."
       Post #: 7
RE: Re: Transfer of digital video to PC - 5/10/2006 5:14:02 AM
tvguy
Status: offline
Yeah firewire is the quickest and best way to transfer footage to the pc. If you have a realtime capture card in your pc, with rca connections, then you could capture the footage that way, this is however the expensive way, as realtime capture cards with analog inputs are quite expensive. I have also noticed that allot of sites are using MPEG format now
(in reply to Fubar-One)
       Post #: 8
RE: Re: Transfer of digital video to PC - 5/10/2006 5:16:46 AM
tvguy
Status: offline
most net videos use WMV format or Apples .mov (quicktime) formats for the net. also most editting software will have an internet setting when you are outputing to a file.
       Post #: 9
RE: Re: Transfer of digital video to PC - 5/12/2006 6:55:39 PM
E-Mo
Status: offline
I needed to instal a FW port on my comp
found this link to a do-it-yourself installation
not real difficult, i did get a grounding loop to protect my comp
static can damage the card & comp
http://www.tigerdirect.com/static/html/PCI-Installation-articlel.html
(in reply to tvguy)
       Post #: 10
RE: Re: Transfer of digital video to PC - 9/28/2006 11:12:48 PM
mt2nitronut
Status: offline
hey langster if you upload your video to your pc you can use youtube here is a vid of my hpi mt2 with the trx 2.5 racing engine http://www.youtube.com/watch?v=GMNzr_t1x58,just thaught i would say they broadcast most formats .
quote:
ORIGINAL: Langster
Thanks again,
Lang
living free being me,ripping the nitro,bashing the mt 2 of course.
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
