Self Taught Pilots
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> Self Taught Pilots Page: [1] 2 3 4   next >   >>
Login
Self Taught Pilots - 4/11/2005 4:31:45 PM
FighterBird873
Status: offline
Has anyone learned to fly on their own? I've got my first Spadet-40 all set for its maiden flight. I've got the engine run-in, the radio programmed, and a large safe place to fly. Has anyone else gone down this route and found success? For this thread I would classify failure as a substantial financial loss, such as a bent crank shaft, stripped servos, or a car door with a propnut sized hole in it. Since we are in the SPAD forum, major structural damage doesn't count.
I've got countless hours on the FMS program, more hours on a hobbyzone fighterbird, and a few hours on a Great Planes BLT.
_____________________________
But can a bee be said to be or not to be an entire bee, when half the bee is not a bee, due to some ancient injury?
       Post #: 1
RE: Self Taught Pilots - 4/11/2005 4:58:20 PM
KyFBCGuy
Status: offline
Don't try it... You will crash. Not to say that you will not crash if you have an instructor, but the odds are that you
will crash and do substantial damage to your plane without one. Find a field and get an instructor to hook
you up to a buddy box.I too have countless hours on FMS and was pretty confident that i could fly.
The problem is that sims dont really prepare you for the "What ifs" of RC airplanes.
I was doing fine up until i made that turn a bit faster than i should have, and did something wrong.
It went from "going good" to "Oh SH*T" in about 2 seconds. The instructor said it happened so fast that
he couldnt react in time, and in it went. My fault totally. I was glad it was a spad. If it was a balsa plane
it would have been sawdust.
Get an instructor...you will be glad you did.
Jeff
< Message edited by KyFBCGuy -- 4/11/2005 5:08:44 PM >
(in reply to FighterBird873)
       Post #: 2
RE: Self Taught Pilots - 4/11/2005 6:56:54 PM
FighterBird873
Status: offline
I don't want someone else to fly my plane, I built it, its mine. And if I crash it, so be it. I've accepted that. Someone else must share that POV. Or is it just me?
       Post #: 3
RE: Self Taught Pilots - 4/11/2005 8:46:47 PM
O2man
Status: offline
Fighterbird,
How do you define success? How many unplanned arrivals are acceptable? Believe me I agree that it is your bird and your money, and you may certainly try if you prefer it that way. I recognize the tone as one I have used in my history, and I wouldn't try to argue with you. Just like bicycles, there are many who have done it without help. They are easily identifyable by the old scars. Want to see mine?
Still learning more than I forget,
and that's the way I remember it.
www.spadflyer.com
       Post #: 4
RE: Self Taught Pilots - 4/11/2005 9:35:26 PM
FighterBird873
Status: offline
I think its easier to define failure in a case like this. If I flew half a lap around the field, never keeping the wings level, landed on only the nose wheel, broke the prop, and the yard stick I use for a spar, thats a success. Simply because the repair bill is less then $5. I know an instructor and a buddy box can almost gurantee success. I'm just wondering if I'm the only idiot who ignored that advice.
(in reply to O2man)
       Post #: 5
RE: Self Taught Pilots - 4/11/2005 9:56:22 PM
Super D
Status: offline
I was self taught, I flew several hours of microsoft flight sim, with a joy stick setup same as right stick on a radio. Only reason I did it was money, back then I didnt have much and the local club wanted $152 to join, plus an AMA license. So I did learn to fly after 2 duraplane trainers(not a good 1st airplane), and a lot of time.
If I would have had the money I would have got some help. So my advice is if you can afford it get help from a club. I joined a club and really enjoy it, sure flying is fun but flying with others is even better and more helpful. In this hobby your gonna crash, but the way you and I approached it, is nearly guaranteed.
I realize the plane doesnt cost much but an instructor teach you so much.
Goodluck either way.
Keep working, the millions on welfare depend on you!
       Post #: 6
RE: Self Taught Pilots - 4/11/2005 11:07:32 PM
O2man
Status: offline
fighterbird,
This forum is littered with stories of those who have tried to be self-taught. There are varying levels of success. You already have a little experience, and apparently you have a large and relatively safe space to experiment in, so while I don't recommend it for a novice, I don't think you really qualify as a novice. What you will find is that the Spadet is a whole lot quicker than anything you have told us about having any stick time on. That is, quicker in terms of control response,ie. jumpy when not handled gently. If you are not putting anyone else at risk, and the only hazard is your "ice cream money", give it a try. Broken props and landing gear are a common experience here, even when we have experience.
One request. Be sure to have your camera handy in case there is a memorable smoking hole to show off. Spads make pretty good lawn darts in the right hands. All us "experts" love to sympathize with (gloat over) an errant pilot.
www.spadflyer.com
(in reply to Super D)
       Post #: 7
RE: Self Taught Pilots - 4/11/2005 11:54:03 PM
koopster
Status: offline
It is true that it is your plane, and if you crash you are out a prop and maybe a spar. That is all fine and well, unless of course the plane happens to hit you in the head or chest on its way into the ground. A prop spinning at thousands of rpm on the front of a plane travelling many miles per hour can make a real mess of the contents of the shirt you are wearing at the time! I realize that it is your shirt , but I would still get an instructor
       Post #: 8
RE: Self Taught Pilots - 4/12/2005 12:22:45 AM
Scar
Status: offline
quote:
ORIGINAL: FighterBird873
There are many who share your POV, and I'm sure they will be posting soon. I'm not one, but I can respect your decision.
Were you asking for tips on learning to fly without assistance? Or were you just proclaiming your intent? In the former case, we all have advice. In the latter case, you don't need us.
Ask for what you need, makes it simple for everyone.
Best wishes,
Dave Olson
My spelling isn't good enough to post grafitti.
       Post #: 9
RE: Self Taught Pilots - 4/12/2005 12:58:24 AM
I.C.O.N.
Status: offline
I'M ONE!
Hey it's really not all that tough.(as I am putting on the flame suit) Yes, you will probably crash. but everbody crashes. the amount of time in the air is different, but everybody crashes. My first attemt after about 6hrs on a sim lasted 7 secs and about 10hrs of gluing the balsa back together. the second lasted about 1min and a half. and only 6 hours to glue the balsa back together. then after about a total of 20hrs on the sim the third flight was a charm. I was able to do everything I did on the sim and then found SPAD's and immediatly dissmantled the trainer for a Demon.
Crashed that too. had no idea how to build a plane since the first trainer was just about RTF. Second demon lasted a flight and I killed the motor. That one I account to cold weather and bad luck.
and my THIRD Demon got 7 flights on it!!!!! It was a lot of fun. I then promptly hit a tree.
My last one has a couple good flights on it(and may have more to come), until the servos started locking up and are moslty in pieces. But, hey they sure took a lickin. I am currently awaiting some new gear that I ordered TODAY!!
I had all the room I needed to play with when flying. Although I ended up using more then I thought I would.
So all in all it has been a lot of fun. Maybe you could do better then I did. Who know's
I think saftey is a concern. There are a lot of things you just get nervous about when it is the REAL thing.
All in All I would say it would have been a much better expierence to have been taught. I would probably be better for it today.
So I would not recommend it, but it is doable. I am not saying I am great yet. And I may Join a club in the future to learn some better techniques that I probably will have a hard time learning on my own.
+1 on the camera of the maiden flight. It will be fun to go back an look at no matter what the outcome.
One piece of advice. STAY SLOW. the biggest problem I had was getting into trouble at speeds that were out of my league. HHHMMMM some things may never change.
Good luck!
(in reply to Scar)
       Post #: 10
RE: Self Taught Pilots - 4/12/2005 2:47:58 AM
RC-Captain
Status: offline
The mere question is can you get help ?
If yes , then do it..
Also AMA or some type of insurance coverage will help if somthing goes wrong.
If no, let me give you some tips. First of all I don't know what a fiterbird is , but if you can't ROG with it then forget trying to ROG with a glow powered plane.
If you can and have ROGed then I feel with the help of the SIM (if you have landed flawlessly many times) you can pull it off. The one thing I'm not thrilled with is the first glow plane you will be flying is a SPAD. Not because it is a SPAD but because of the CG ,weight ,and other factors you probably will not be familiar with. If the SPAD is ARF then just one more tip, Get the sucker as HIGH IN THE AIR as you can so if you lose control you can recover (sometimes).
Keep in mind I am not a year old as far as flying glow trainers , but I have been flying EP planes for close to 5 years now , I think , been having to much fun to even remember.
Good Luck
P.S. I have nosed my .40LA engine into the ground , tree, a couple of times and to date all I have changed was the crankcase and back plate which was not damaged by the crash.
< Message edited by RC-FIEND -- 4/12/2005 3:03:31 AM >
I finally broke bread and bought a real charger , THE TRITON 2............
(in reply to I.C.O.N.)
       Post #: 11
RE: Self Taught Pilots - 4/12/2005 6:11:08 AM
lecrote
Status: offline
OK I didn't read all the post.
Here's my history.
Start RC plane in summer 1990 never had my wings.
Back to RC in 1996 after my technician course is finish.
One day's i made a kind of duraplane fuse to go with my plane and to fly alone because I was tired to wait for instructor.
Result= I lost my plane in a big corn field... I searched for almost 2 weeks every days without success
No engine = no RC
Back to RC in 2002 with 1 year of FMS and the SPAD, again alone. (jesus i'm hard brain )
In the same summer I crashed 4 planes.
Like others said if you can get help go for it.
It's not only for the flight itself. You will learn on engine and many other's
Hope that's help
Dan
Coro fly like balsa...
But it crash so much better!!!
(in reply to RC-Captain)
       Post #: 12
RE: Self Taught Pilots - 4/12/2005 11:47:52 AM
kbear
Status: offline
I'm sort of self taught, for my first flight with a deb, I had a guy from work take it off for me. the engine quit on me and my first landing was dead stick(this is now my favorite way to land, go figure). Minor damage to the landing gear. after that It was all me. I still think that some help would be good if you can get it, but if you are going to do it yourself, here is my advice and some things that helped me. Find as big a field as you can so that you can land anywhere. Buy a ton of wooden props. Yes they brake easy, but they do less damage to your engine when you crash or land hard. Fly a spad that you personally built. This way you will know how to repair it. Spads are cheap so go ahead and build a second one as a spare. you will probably need it. Make your trim as visable as possible, high contrast, even if it means it's kind of ugly. Ugly flies better any way LOL. Take off with the plane going directly out away from you, and don't turn until you have some altitude. Fly your sim every time you are going out to fly. This gets your brain wired right. I do this even now. While the FMS sim is nice, I would suggest a retail sim. You may be able to get a deal on a G2 with the new G3 out now. Practice the hard parts on the sim as much as possible. Don't just bang the sticks around. use it as a training tool, not a video game. Remember that a larger glow plane is going to go faster and needs more room to recover from mistakes. This is most important, Don't fly around allot of people, you don't want to hurt anyone. also don't fly completely alone, you want help if you get hurt. Don't let someone talk you into trying s maneuver that your not ready to do. And now to sound parental, Remember that this is serious stuff. These planes are not toys and can easily KILL someone. Ok got that out of my system, have fun and don't get discouraged. I know guys that have flown over a year with an instructor before they soloed. One of those guy's son soloed in three flights. These are just my opinions and they come from my experiences. I'm sure there are many who will not agree with some or all of them. I still think you should seek assistance. Good Luck and let us know how it goes.
(in reply to lecrote)
       Post #: 13
RE: Self Taught Pilots - 4/12/2005 2:24:50 PM
