BigK9
CA, USA Status: offline
Can someone tell me where the centerline for the engine for this plane should be? The instructions are worthless (all they had to do was include a couple of dimension). I assume there are supposed to be horizontal and vertical lines on the front of the firewall for the engine thrust line center, but mine did not come with any lines. The holes for the fuel lines are also off. I can wing it I guess, but I hate doing that. If someone can just tell me where the center point on the firewall should be by measuring up from the bottom lip, that would be all I need. Also, I had Century Jet move the upper nipple for the air retract kit they sell for this plane and it fits much better now. The old one had a nipple on the side and would have necessitated cutting the mounting rail to get it in, which is a no-no for me. They told me they are changing the config of their units for this plane based on my change.
