CMP/GSP Spitfire
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> CMP/GSP Spitfire
Page: [1] 2 3 4 5 6 7 8 9   next >   >>
Login
CMP/GSP Spitfire - 4/11/2005 4:56:17 PM
SJN
Status: offline
Who can live without having a spitfire
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Sonnich Johannesen
       Post #: 1
RE: CMP/GSP Spitfire - 4/11/2005 4:57:33 PM
SJN
Status: offline
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Sonnich Johannesen
(in reply to SJN)
       Post #: 2
RE: CMP/GSP Spitfire - 4/11/2005 4:58:50 PM
SJN
Status: offline
Im going to use my Webra P-5 91 aero with stock muffler on this one.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Sonnich Johannesen
(in reply to SJN)
       Post #: 3
RE: CMP/GSP Spitfire - 4/11/2005 5:00:27 PM
SJN
Status: offline
I have to butcher the cowl quite a bit, and have enlarged the exhaust hole a bit for better cooling.
I had the same arangement on my now dead extra 300 which had this engine in it.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Sonnich Johannesen
(in reply to SJN)
       Post #: 4
RE: CMP/GSP Spitfire - 4/11/2005 5:56:34 PM
SJN
Status: offline
I was going to buy a new alu spinner tomorrow for it, but then I found this black spinner I had bought by mistake some time ago.
I suppose it looks scale, maybe even more than a "standard" alu spinner..
Honestly, what do you think about it ?
keep or toss ?
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by SJN -- 4/11/2005 5:59:30 PM >
Sonnich Johannesen
(in reply to SJN)
       Post #: 5
RE: CMP/GSP Spitfire - 4/11/2005 5:57:49 PM
SJN
Status: offline
Click for fullsize
Click for fullsize
Sonnich Johannesen
(in reply to SJN)
       Post #: 6
RE: CMP/GSP Spitfire - 4/11/2005 7:18:05 PM
Dave03B
Status: offline
lookin' good. Make sure you weather it
Click for fullsize
Dave Bright - www.wimbornemac.org
(in reply to SJN)
       Post #: 7
RE: CMP/GSP Spitfire - 4/11/2005 9:37:05 PM
UKWes
Status: offline
What retracts you putting in her SJN?
I have one of these in a box (still) and the only thing I am unsure of is what retracts to go for and how to strengthen up the area for them, so any details and pix would be welcome....
I have been switching my mind between the Flair heavy duty mechanicals or pneumatics Eurokits/Robarts, but are not sure how much modification would be needed to get any to fit.
(in reply to Dave03B)
       Post #: 8
RE: CMP/GSP Spitfire - 4/11/2005 9:46:45 PM
SJN
Status: offline
Im going to use "large" eurokit retracts with 6mm piano rod legs in mine.
I will have to carve a litle wood out of the beams for them to fit.
I plan on re-inforcing the joints with some glue and maybe glass.....
Sonnich Johannesen
(in reply to UKWes)
       Post #: 9
RE: CMP/GSP Spitfire - 4/11/2005 9:54:21 PM
skylane42
Status: offline
I have one in the basement for this winter and am looking for some reviews on the plane, building, power used etc. I think I am going to use the ST 91 I have or get ahold of a 120 4 stroker. Not too sure which retracts to use and all the rest of the stuff that comes up with a new project. Please let us know how she flies.. Have you seen thier new P-40 140? I saw a pic on the website but no one had one at Toledo.. the people that had the CMP kits there didn`t know a thing about the P-40 Or it seems any of the other kits..
(in reply to SJN)
       Post #: 10
RE: CMP/GSP Spitfire - 4/11/2005 10:04:05 PM
SJN
Status: offline
You can read the RCU review here, and see videos too
http://www.rcuniverse.com/magazine/article_display.cfm?article_id=117
Sonnich Johannesen
(in reply to skylane42)
       Post #: 11
RE: CMP/GSP Spitfire - 4/11/2005 10:20:26 PM
Dai Phan
Status: offline
Hello,
I too look at this bird but pass it by based on the fact that it looks too stuby! In the air, it looks good but on the ground looks not quite right. I give all my scale ARFs completetly makeover so I want to have the best possible outline before I buy the bird. Interestingly, the Hellcat looks very scale and the P-51 and the FW-190 are very poor in outlines ven thought they are stand-off scale. If you like decent scale warbirds that only scale nuts would know about outline problems, consider the Hurricane by KMP (made in China). Amazingly scale outline. KMP is coming out with a late model Spitfire that is also near perfect scale. Also, CMP is coming out with very accurate P-40 ARFs and VQ Models too. This tells me that fiberglass bodies are the only way to go for an accurate body profiles. Dai
(in reply to SJN)
       Post #: 12
RE: CMP/GSP Spitfire - 4/11/2005 10:24:33 PM
Pete850
Status: offline
Hi,
I have had the CMP Spit for just over a year and it's a great flier. I used an ASP 1.20 4-st with a 15 x 8 MAS and it has plenty of grunt. This engine starts much easier than my mates OS 1.20 pumper and is easily as quick in the air. I used Robart 609HD mechanical retracts. Because they are 85 deg, they give a slightly wider track than 90 degree ones would and it's therefore a bit more stable on the ground.
I set all the surface deflections to the instructions and have them on 30% rates and 60% expo. This is plenty for scale like flying.
The stock wheels were a bit small I felt, so upped them to 3.75" dia, removed the moulded wheel wells and sheeted them in instead.
I'm also using Unitracts 13mm oleos which help a bit w
