Torn between several engines...don't know what to do...
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Torn between several engines...don't know what to do...
Page: [1]
Login
Torn between several engines...don't know what to do... - 12/28/2001 6:23:43 AM
XtremeAerosport
Status: offline
Okay guys, I took the plunge and got one of the Hangar 9 1/4 scale Cap 232 ARF's. Now, for the engine choice.
I dont want to go 4 stroke...can't afford it right now.
I have a Magnum 180 available. Heavy, decent power, the price is right and Bisson makes a pitts muffler for it.
I found a Super Tigre 3000 here on the boards. Again, heavy, but the price is right too...and it comes with a Bisson Pitts muffler.
I like the MDS 148. Price is good, Pitts muffler is affordable. Power is great for a 150 size.
Moki's are out of the equation for financial reasons.
So, of these three, which would you guys go with?
Jonathan Ott
Extreme Aerosports
Louisville, KY
       Post #: 1
Engine choice - 12/28/2001 7:56:29 AM
CaptainHook
Status: offline
I don't know much about the MDS or the Magnum. The Supertigre will run well with an O.S. 7D carb. You may want to consider the O.S. 160, i've heard great things about it. Maybe a used Saito 1.20 or Moki 1.8 will fit into your budget. I had one with the Saito and it flew well. I would suggest looking into the used market to get the performance you will most likely want.
(in reply to XtremeAerosport)
       Post #: 2
Gas - 12/28/2001 11:54:48 PM
3DRC
Status: offline
Look into a ZDZ 40. It is a gasser and it isn't too much when you bring in the cost of fuel.
Bean
_____________________________
"Experience is what you get, right after you needed it"
       Post #: 3
Torn between several engines...don't know what to do... - 1/1/2002 11:15:03 AM
BigD
Status: offline
Consider a used Moki if you cant afford a new one....they are wonderful and will fly a wide range of planes and weights....
       Post #: 4
Torn between several engines...don't know what to do... - 1/1/2002 12:46:38 PM
budcop
Status: offline
I understand budget constraints, the last engine I purchased was a Magnum, I have not regretted it, a friend at the field always brings several planes with him to fly, nice planes I might add, all he uses is the magnum engines, they run great ! so for the last engine purchase I bought the magnum .91 four stroke, after minor adjustments and break in I would put it up against any of my OS,Saito engines.......Go for the Magnum!
< Message edited by budcop -- Jan 1 2002 7:49AM >
Bud Williams
AMA 1651
       Post #: 5
Thanks everyone... - 1/1/2002 8:44:54 PM
XtremeAerosport
Status: offline
Thanks for the info guys. I found a gently used MDS 148 with a Bisson Pitts muffler that I'm going to put on it. I had this setup on my Sig CAP 231EX and it is a stump puller. My sig was destroyed on the second flight and I traded the engine off for a little Saito for my Pizzaz. Now I have another MDS on the way and it should drag this Cap around with authority.
Thanks again,
Jon
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.389RCU1
