Aerodynamic tools, calculators and test links
Tower Hobbies
Logged in as Guest
  Printable Version
Fei Bao Velox XL Sport Jet - ARF
Seller:  rcjetmodels
Details:   $1,300.00   |  6/15/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Aerodynamics >> Aerodynamic tools, calculators and test links
Page: [1] 2   next >   >>
Login
Aerodynamic tools, calculators and test links - 4/12/2005 5:19:28 AM
BMatthews
Status: offline
This is a new sticky FAQ thread to post up links to various online calculators, simulators and other online software tools that can be used to explain principles or calculate aerodynamic design factors. I'll edit this post to include all links as they come up to save users from wading through all the posts. Headings for some but not all categories are shown below and the links along with a short description are posted under the headings. If you have suggestions for other heading topics please post.
Bring 'em on folks!
_______________________________________________________
Airfoil analysis and airflow simulation:
http://www.grc.nasa.gov/WWW/K-12/airplane/foil2.html - Foilsim, a simple airflow simulator. Let's you play with camber, AoA and determine the Cl of your basic design size and speed. Very educational - BMatthews
CG calculators:
MAC (Mean Aerodynamic Chord) calculators:
http://perso.wanadoo.fr/scherrer/matthieu/english/mce.html - multi panel entry allows more complex shapes -Tall Paul
Tail Volume Coefficients- Horizontal and Vertical:
Bruce-
Proudly wasting balsa since 1965.
Free Flighters go that extra mile........
       Post #: 1
RE: Aerodynamic tools, calculators and test links - 4/17/2005 4:23:56 PM
kamakasi
Status: offline
here is one for a effective dihedral angle calculator I've also got a good c/g locator if I can relocate the file I'll post it.
The older I get... The better I was...
(in reply to BMatthews)
       Post #: 2
RE: Aerodynamic tools, calculators and test links - 4/17/2005 4:36:02 PM
kamakasi
Status: offline
Found the c/g program, not the one I originally had but it looks like it has all the bells and whistles. Aircraft Balance Calculator
You might wand to check outcolorado gliders they seem to really get into the #'s. Mostly glider stuff but we follow the same physical laws as everyone else
       Post #: 3
RE: Aerodynamic tools, calculators and test links - 5/4/2005 2:46:02 AM
BMatthews
Status: offline
quote:
ORIGINAL: Geistware
OK Everyone, Version 6.0 of the calculator are up and does balance calculations as well as CG. Please review it here.
http://www.geistware.com/rcmodeling/cg_super_calc.htm
Bruce-
       Post #: 4
RE: Aerodynamic tools, calculators and test links - 5/5/2005 6:09:05 AM
Wing-Ding
Status: offline
Here is a software tool (spreadsheet) that converts surface deflection expressed in inches to degrees:
www.aeroperfect.com/degree.html
And two spreadsheets that aid in programming Hitec Digital Servos:
www.aeroperfect.com/program_off-plane.html
www.aeroperfect.com/program_on-plane.html
While these are "online software tools", they're not tools for calculating aerodynamic design factors in the strict sense. While they are useful, they may outside what you had in mind. If so, please feel free to remove this post
Bell Electronic Technologies
www.AeroPerfect.com
       Post #: 5
RE: Aerodynamic tools, calculators and test links - 6/26/2005 9:51:37 PM
adam_one
Status: offline
Calculate wingloading, area and estimate stall speed
Calculate NP & CG for wings with two different panels
http://adamone.rchomepage.com
       Post #: 6
RE: Aerodynamic tools, calculators and test links - 10/29/2005 9:41:27 PM
BMatthews
Status: offline
Online servo torque calculators...
http://www.csd.net/~cgadd/eflight/calcs_servo.htm
a second site with the same thing
http://www.coloradogliders.com/servotorquecalculator.htm
and again...
http://www.mmaa-modelairplanes.org/servotorquecalculator.htm
and just in case all the rest go dead a 4th iteration of the same thing
http://www.flyrc.dk/servo.htm
Just be sure you provide a worst case speed of what the model will be able to do in a screaming death dive. And to prevent loading the servo you should use the number given by the calculator for servo torque required and get ones that provide 1.5 to 2 times that torque calc so you know the servo won't be operating near it's stall zone.
Enjoy!
< Message edited by BMatthews -- 10/29/2005 9:46:37 PM >
Bruce-
(in reply to adam_one)
       Post #: 7
RE: Aerodynamic tools, calculators and test links - 11/14/2005 10:11:52 PM
VTaerospace
Status: offline
http://www.mh-aerotools.de/airfoils/index.htm is a great resource. It has quite a few programs for model aircraft design. Noteably, JavaFoil a 2D airfoil analysis tool, JavaProp, and Java Pipe. There are also many other programs available on Dr. Hepperle's website. You just have to look around a bit. A one i find handy often is the aerodynamic center calculator.
And for the more advanced and adventurous out there, AVL is a great 3 dimensional aerodynamic analysis tool. Google it. You'll find it.
       Post #: 8
RE: Aerodynamic tools, calculators and test links - 12/24/2005 10:31:58 PM
Aschiuta
Status: offline
Using the java applet from here http://www.mh-aerotools.de/airfoils/javafoil.htm i design the airfoil from my scratch build aircraft The Beast.
Great tool!
Val
(in reply to VTaerospace)
       Post #: 9
RE: Aerodynamic tools, calculators and test links - 12/30/2005 1:47:14 AM
cyclops2
Status: offline
Is there any site that has airfoils grouped, as to the type of aircraft use? I am looking for a site that visually shows the foil.
I found a perfect such site in Japan, but all the foils were in reference #'s and plotting #'s.
I live and die on print out and enlarge.
Thanks for any sites, Rich.
(in reply to Aschiuta)
       Post #: 10
RE: Aerodynamic tools, calculators and test links - 12/30/2005 2:06:47 AM
Aschiuta
Status: offline
No i do not know such a site.
you can take a look here-> UIUC airfoil databse
You have both numerical data and the image.
Val
(in reply to cyclops2)
       Post #: 11
RE: Aerodynamic tools, calculators and test links - 12/30/2005 3:09:51 AM
cyclops2
Status: offline
After looking at most of the foils visually. I come away with the truthfull realization that no one agrees what is the most efficient in any application after all these years.
Thanks for removing any doubts I had about airfoil selection.
       Post #: 12
RE: Aerodynamic tools, calculators and test links - 12/30/2005 3:18:02 AM
Aschiuta
Status: offline
Well, there is no perfect airfoil for everything... depends of what are your requirements for that aircraft (speed, long flying time, maneuvrability etc etc), you have to pick the best airfoil to suit that. And of course, even if you know the requirements, you will still have hard time to pick the best . I know maybe it sound a little be off, but think about of formula 1 wings and body aerodynamics.. there is no perfect way, no perfect package, and also the package is modified to suit the circuit, and it is in always development.
Val
       Post #: 13
RE: Aerodynamic tools, calculators and test links - 12/30/2005 5:36:52 PM
cyclops2
Status: offline
You are absolutly correct about competitiveness developing better air foils for each condition.
       Post #: 14
RE: Aerodynamic tools, calculators and test links - 12/30/2005 5:39:59 PM
cyclops2
Status: offline
Why would I expect the competitors to all admit, 1 was now the best for a particular setup.
I can be very simplistic at times, because I do not compete actively.
       Post #: 15
RE: Aerodynamic tools, calculators and test links - 1/19/2006 5:55:32 AM
GJM
Status: offline
Is anyone out there aware of a formula for calculating the number of G's a design would be able to pull. It would be helpful when trying to design a structure.
Thanks guys!
Brian G.
       Post #: 16
RE: Aerodynamic tools, calculators and test links - 3/29/2006 11:00:36 PM
dick Hanson
