snowbl!nd
Joined: 1/21/2005 From: Manchester, UNITED KINGDOM Status: offline
Increasing rear toe-in will increase rear traction, reducing the possibility of spinning out under cornering. Also, when you nail the throttle coming out of a corner, the toe-in will keep the back of the car in check, pointing it in a straight line and stopping it wandering all over the place. *The more rear toe-in you have the more rear traction you will have (to a point), but you will suffer from increased tire wear. As for camber, i run 0degrees (tyres completely flat on surface) which seems to work well (largest surface area contact patch). For just driving around leave it at 0degrees (also allows your tyres to wear evenly, therefore lasting longer), as for performance (if racing) you may want some camber, but i do not know what would work.
_____________________________
RC obsession. The quest to discover just how deep those pockets really are... Life is short - Drive fast.
