Ryobi 31cc
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Ryobi 31cc
Page: [1]
Login
Ryobi 31cc - 12/28/2001 9:43:51 AM
AC2
Status: offline
Any thoughts out there about using this on a Balsa USA Citabria Pro?
Any advice?
I plan on recovering the entire plane which is set up now for a YS120 so it is a good time to make the conversion.
Just looking to get away from the glow fuel mess. I would assume I have to move the servos to the rear etc for cg purposes, and would re-inforce the firewall. I am also considering putting some more lumber in the rear?
Anyone taken on this project before? If so any pics?
       Post #: 1
Citabria Pro/Ryobi - 12/28/2001 5:27:21 PM
pettit
Status: offline
It may work, but the Ryobi is a 4 lb engine and the magneto/flywheel may not clear the cowl. You'd have to get an aftermarket electronic ignition, like I used on my Dynaflite Chipmunk.
The Citabria Pro is a very light plane, probably 10-11 lbs ready to fly, with an appropriate engine. Why add 2 or 3 more pounds to it, plus added tail weight needed to balance, when you can use a 91 to 120 four cycle like it was designed for?
If you really want a gas engine, take a look at the RCS140, small light and easier to install.
_____________________________
Dick Pettit
Associate Editor, R/C REPORT Magazine
"You Can Buy Better,
But You Can't Pay More"
(in reply to AC2)
       Post #: 2
Ryobi - 12/28/2001 8:35:54 PM
AC2
Status: offline
Thank you for the reply, I have heard that the airframe is too light from another source as well. I wonder if the ryobi will work on a Northwest Technologies Corsair? I bought the engine so these are the two planes I have. I may have to consider buying another plane for the engine, but was hoping I would not have to.
Thanks!
(in reply to AC2)
       Post #: 3
ryobi - 12/29/2001 8:26:51 AM
flying2bill
Status: offline
This engine is best suited for 1/4 scale cubs and Taylorcrafts, ecspecially if you still have the stock carb on it. Too heavy for your Citabria and not enough umph for a Corsair (pronounced CUSS-air). Works good in most Balsa USA big planes.
(in reply to AC2)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU1
