RE: engine mystery    Gallery
Logged in as Guest
    Search This Thread
Printable Version
90 Dgree Muffler Adapters
Seller:  RC Specialties
Details:   $19.95   |  4/12/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: engine mystery
Page: <<   < prev  1 [2]
Login
RE: engine mystery - 4/18/2005 10:49 PM
meowy84
Score: 100
Last Login: 5/19/2012
Status: offline
Someone mentioned that they e-mailed Cox/Estes and they'll resume the $5.99 deal in a little while.
Hide Signatures
(in reply to minny minoza)
       Post #: 26
RE: engine mystery - 4/18/2005 11:40 PM
minny minoza
Score: 100
Last Login: 9/7/2005
Status: offline
quote:
ORIGINAL: meowy84
Yeah, I e'd them weeks ago, and they said first week of April. Ain't checked today, but, as of Saturday, the offer was still in suspension.
Pretty amazing deal. Even if I don't fly that many reedies anymore, it's worth it, just for backstock. (Paid ten bux for my last cox glowhead).
_____________________________
"I've heard temperatures in Antarctica can drop to -120 degrees." "Yeah, but it's a DRY cold."
Hide Signatures
(in reply to meowy84)
       Post #: 27
RE: engine mystery - 4/19/2005 7:06 AM
meowy84
Score: 100
Status: offline
Minny, I hear ya. I missed the first time the deal was around but I don't plan on missing out again. At $6 bucks it's a great deal I think. I hope they bring it back soon....10 or 20 Cox reedies will serve me for quite a while.
Hide Signatures
       Post #: 28
RE: engine mystery - 4/20/2005 12:51 AM
djlyon
Score: 100
Last Login: 10/3/2012
Status: offline
Hi all
I have 2 Norvel .061s. One RC, one not RC. They are both designated AME high performance engines. It has always been my understanding that the AME was the designation given to the high performance versions of the Norvel engines. They are both NIB and the box says Norvel with small print calling them AME high performance engines. The Norvel .15 is plain bearing and the Norvel AME.15 is ball bearing.
The 1.0 is on my engines also and means 1cc or .061 cubic inches.
So Minny you have a .061 Norvel AME high performance engine.
I also have a Norvel 40 that I am currently using on a Magic Extra 3D plane. Very nice and quit powerful.
Denis
I never met an engine I didn''t like.
Of the things I''ve lost I miss my mind the most.
Hide Signatures
       Post #: 29
RE: engine mystery - 4/20/2005 1:34 AM
minny minoza
Score: 100
Status: offline
quote:
ORIGINAL: djlyon
Hi all
Thanx, Denis, for the encouraging details.
Been breaking it in on a gravity tank, and it seems to run pretty well--although, as mentioned earlier in this thread, it doesn't wanna run unless I keep the glow heater turned on. I'm anxious to try the cox glowhead suggestion, as I have a few of these lying around. You ever tried this?
Needle also doesn't seem quite as subtle as on my other norvels--but that may be due to the faulty glowplug. Will see if it needles more precisely with a cox glowhead. Slightly diminished performance won't be a problem, as I've still gotta put in a lot of handle time before I'm really ready for super-speed flying.
Gonna run a few more gravity tankfulls through it before I hook it up to a bladder.
Again, Denis, thanx, for your input. This engine came to me unused, although without box or literature, so I'm grateful for the info.
Best,
M
Hide Signatures
(in reply to djlyon)
       Post #: 30
RE: engine mystery - 4/20/2005 1:39 AM
William Robison
Score: 599
Last Login: 1/30/2007
Status: offline
Mike:
If you want to run it flat out all the time a bladder will be OK. If you want to throttle it, a bladder will not work without some form of demand regulator.
Bill.
Real Airplanes have Two Engines
AMA 25139 - More than 40 years.
Hide Signatures
       Post #: 31
RE: engine mystery - 4/20/2005 2:04 AM
minny minoza
Score: 100
Status: offline
CL, so it'll be flat out all the time. (Took a piece of SS wire and cobbled the throttle full open. Rube Goldburg would be proud).
Hide Signatures
(in reply to William Robison)
       Post #: 32
RE: engine mystery - 4/20/2005 2:31 AM
djlyon
Score: 100
Status: offline
Minny
I have the instructions for these engines. They are quite thurough. If you would like I can scan them and email them to you. The instructions come with 2 head shims taped to them which guess you don't have. Unfortunate. The instructions do have a glaring error. They say you need a bladder tank or a pressure back plate to pressurize the tank for max performance. Pressure has nothing to do with max performance but enlargening the ventury until the engine won't run unless the tank is pressurized does have something to do with max performance. Or they could be telling you that the needle valve is so cruddy that they need pressure to get a consistant needle setting ala some old cox TDs. Flaming out when removing the glow is an indication of too rich a needle. I have never run these engines so unfortunately I can't give any first hand advice.
Denis
Hide Signatures
       Post #: 33
RE: engine mystery - 4/20/2005 5:57 AM
minny minoza
Score: 100
Status: offline
"I have the instructions for these engines. They are quite thurough. If you would like I can scan them and email them to you. The instructions come with 2 head shims taped to them which guess you don't have. Unfortunate."
Would love a look at the instructions. And it's interesting: when I pulled the head, I noticed there were two shims in there already. Maybe this is standard, and the instructions included still two more--but at least I'm not completely without head rings for this engine.
Oh, and thanx, for the tip about the error. If you wanna e- them to me, I'm mikemcoo@efn.org
Thanx a meg, Denis,
M
Hide Signatures
       Post #: 34
RE: engine mystery - 4/20/2005 6:05 AM
djlyon
Score: 100
Status: offline
They'll be coming within the next couple of days.
Denis
Hide Signatures
       Post #: 35
RE: engine mystery - 2/24/2012 6:33 PM
Halvey
Score: 100
Last Login: 10/7/2012
Status: offline
Bringing this thread back from antiquity. Just picked up the same engine pictured above with the same markings other than the serial mark under the mount lug (6100027). Mising the cylinder mounting screws (4). Wondering if the new Big Mig mounting screws shown on the NV website will fit.
http://www.nvengines.com/index.php?page=shop.product_details&flypage=flypage-ask.tpl&product_id=90&category_id=5&option=com_virtuemart&Itemid=65
Hide Signatures
       Post #: 36
RE: engine mystery - 2/24/2012 6:59 PM
Ernie Misner
Score: 130
Last Login: 5/25/2013
Status: offline
Now if we could just bring William Robison back from antiquity. Sure do miss him!
Ernie Misner
Hide Signatures
(in reply to Halvey)
       Post #: 37
RE: engine mystery - 2/24/2012 8:39 PM
Mr Cox
Score: 102
Status: online
Yes the screws are the same, but I haven't bought those exact screws from NV myself.
The name Big Mig refers to the transfer porting, the is no outer difference between the AME and the Big Mig. The engine at the beginning of this thread is an early, pre-revlite, type, but the crank case stayed the same.
Hide Signatures
       Post #: 38
RE: engine mystery - 2/25/2012 1:08 AM
JNorton
Score: 149
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: Ernie Misner
Ernie Misner
Yah I'm with you Ernie. Brought back a lot of memories of Bill. All good.
John
Have desk ... Will Fly.... Saito Member #467
Ultimate Brotherhood #11, Ultra Sport Brotherhood #90
Hide Signatures
(in reply to Ernie Misner)
       Post #: 39
RE: engine mystery - 2/25/2012 1:11 AM
Halvey
Score: 100
Status: offline
quote:
ORIGINAL: Mr Cox
Thanks Bas.
PV
Hide Signatures
(in reply to Mr Cox)
       Post #: 40
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: engine mystery
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.593RCU1
