zope_pope
CO, USA Status: offline
Hey buddy, I would if I could, but unfortunately I havent even cut the hinges yet. Great Planes makes an excellent tool for setting throws. I use it all the time and it is only about 15 dollars. It mounts on the horiz stab, wing, fin, whatever you are measuring, and it has a scale that shows you how much deflection you have. For my models I tend to sand about a 45 degree angle or so, maybe less. The easiest way I have found to do this is or atleast get it started is to take a pen or pencil with a straight shape and put the hinge line face down on a table. Then use the pen that is flat on the table and draw a line. it ensures the line is straight and then just sand there from the center line. the great planes Ultimate Biplane .40 instructions have pictures of this technique. Hope it helps. Also, could you do me a favor and take a side shot of how your retracts look when they are extended? Take it straight on from the wing tip. Still having a hard time getting my retracts perfect. Thanks Hey Brad, Yeah I get the I thought you were older a lot. Maybe its the way I type? Not too sure. Anyhow, yeah, I wouldn't mind picking you guys up since gas prices are dropping a little bit finally. 92 bucks an hour isnt too bad split three ways. :P
_____________________________
If you choose not to make a decision, you have still made a decision.
