sgilkey
MI, USA Status: offline
Yeah, that was Brian's plane you hit, a virgin plane on its first combat mission. It looks like it was hit with a SAM! That wing is toast. It spiraled down into the weeds and we saw smoke rising, we were afraid a battery short or something had set the grass on fire. Folks ran out with a fire extinguisher to find the Webra screaming at WOT, the smoke had simply been the exhaust. The engine appears to be ok though the whole plane was covered with pulverized/chopped plant matter, and the engine got a chlorophyll speed hone. Suggestion to keep your fins in place: near the very front and very rear, lance a hole with a phillips screwdriver thru the coro, about an inch away from the fuse joint, thru both the fin and subfin. Then tie them together with zipties. Belt and suspenders that will help retain your fin bits in the event of a direct hit. You flew well, especially considering it was a first meet, that was a pretty tough crowd of all experienced fliers! If your front end is slightly out of whack after an impact, it's because the G10 slides relatvie to the HDPE core, which seems to help absorb energy and reduce the chance of the engine beams breaking. Just loosen the engine mount bolts, straighten out the hose, and retorque the bolts. I periodically retorque the bolts just to make sure everything stays tight, even though we use locknuts.
