nexzzt
Joined: 8/12/2007 From: QLD, AUSTRALIA Status: offline
quote:
ORIGINAL: cummins driver Well, it looks like no video for a while I made my motor to tranny shaft stouter, and got the brakes working, and was gonna take it for a short drive to make sure it was gonna work ok, cause i wanted to get it reliable so it is fun to run. Well about 15 feet out i dont know what happened, but it ran away from me, and hit a wagon flat dad had sitting outside the shop. It hit right at the top of the motor, and busted the magneto and bent the frame. I knew the frame wasnt too stout, but I wasnt planning to run it into that kinda stuff either(of course, who does) I think I will just take it all back apart, and cut the aluminum plate out for a frame and go about designing it better this time. Im going to try to make it shorter, get the driveline angles the best i can, move the tranny as far forward as i can, and go from there. It should be lighter too. My original design wasnt the best but i thought it would work until i decided to buy the stuff to do it better. Oh well. I guess I will slowly go about making it better than it was before. I will post pictures of the progress..... for the 2nd time At least i have an idea of how it should run now. Sorry to dissapoint everyone with no video Wow, sorry to hear that. One good thing about the spektrum gear is the fail safe, and combined with a throttle return spring it is pretty safe. Anyway, keep at it, I always find the build a little more fun than running it but it is nice to run it at least a little while. Also, if you can post some build pics as you go, I like seeing how ppl fix/get around problems etc.
