Equalizer II problems
Tower Hobbies
Logged in as Guest
  Printable Version
Carden 35% Extra 260 - RTF
Seller:  jmiracle
Details:   $2,950.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Smart-Fly (Quest Engineering) Support Forum >> Equalizer II problems
Page: [1]
Login
Equalizer II problems - 4/22/2005 5:58:15 AM
Goggles
Status: offline
Back in Feb I purchased 2 Equalizer II's and I set them up as per manual with JR 8231's, 2 per wing. When it came time for maiden a couple weeks ago I was setting everything up at the field and doing preflight checks I noticed when I moved the aileron sticks slowly I got a very jittery movement on each aileron, they were stepping badly on each movement. I was also getting very short range checks and then I had 1 Eq that lost the setup to the second servo. I pulled the Eq's out and put a spare reciever that had Aux channel 1 for the 2nd servo (running dual rx's) and at that moment I had excellent range check again. The 8231's also ran much smoother and I ended up putting on a few good flights that day.
Please advise what I should do because at this moment I do not trust using these in any of my planes.
Kelvin Buck.
_____________________________
Gailvin Air Models
Preformance Aircraft Unlimited; Fromeco Batteries Canadian Distributor
       Post #: 1
RE: Equalizer II problems - 4/22/2005 2:21:01 PM
rrritchey
Status: offline
Kevin,
Well, I am not sure what happened but it sounds like you want to return them for your money back and that is no problem. Just send them back to us and we will refund your money. The Equalizer has been a very dependable product but sometimes something will happen. We are sorry you experienced these problems.
Robert Ritchey
Owner, Smart-Fly
(in reply to Goggles)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU1
