DarZeelon
Joined: 4/9/2003 From: Rosh-Ha'Ayin, ISRAEL Status: online
quote:
ORIGINAL: Harry Lagman About 10 minutes later, another guy accelerated (edited by Dar ) his OS .61 FX (my wager for the mystery engine) with an MA 11x7 and got 13,400. All were at sea level. Larry, I wanted to see how long it will take for someone to guess this (quoted from the MAN 05/03 engine shootout - Dave Gierke)... The MA offers light loads, in its up to 11" props. Using the Prop-Power calculator, punching in the same HP number from the APC@13,000 and changing the prop load constant to the smaller MA number, produced 13,398 projected RPM... Very close, I would say. If Jim says his CF K&B does this 13,800, I tend to believe him, especially if it is a PDP, since my MVVS .49 can spin a Bolly Clubman 11.5x6 (very similar load) at 13,600 with the tuned silencer. And BTW, sea level and higher altitude RPM numbers differ very little, since prop loads are reduced by the thinner air, like the power is. Power output differs by very much, however, despite RPM remaining unchanged.
_____________________________
Dar Zeelon - ISRAEL - ddzeelon@gmail.com MVVS - Jett - Nelson - Bolly - Mejzlik
