Peel Ply techniques
MN
Peel Ply techniques
What, if any, is the best way to use peel ply? What do YOU use peel ply/release film for? I know what it is supposed to do. What was the last/most interesting actual application where you used it?
In one of Rutan's books he recommends using peel ply over an overlap of fabric so that the edge of the fabric will stay down and so the resin will fill in a bit under the peel ply. That will give a smooth, usually hump free overlap.
But how do you hold down the peel ply? I find I only get this smooth an overlap when I vacuum bag. Sometimes if I carefully wrap and secure a small piece I can get the peel ply tight enough for marginally acceptable results, but nothing beats the finish, adhesion, uniformity of lamination thickness and perfect resin content I get with bagged peel ply.
Ordinarily I lay up the work with a moderately generous amount of resin (not sloppy and dripping) and apply the peel ply dry. Is there a circumstance when one might want to wet out the peel ply?
Also, I reuse peel ply where the finish of the work is not critical. I get small thin pieces of the prior lamination that pull off the peel ply and may be a different color that the piece at hand. Does anybody else reuse the stuff? Its expensive!
MN
RE: Peel Ply techniques
I re use the perforated peel ply all the time. The only thing I use it for is when I layup a part in a female mold that I intend to vacumm bag. AFter I am done laying it up, I put the peel ply down on the resin/glass and then a layer of good quality paper towels to soak up the excess resin that comes through the perforated holes when I apply vacumm.
Works good and removes excess weight.
MN
I guess I should have added that all my work is sandwich construction. Fabric over foam. And all the peel ply I use so far is dacron polyester fabric.
But great, I'd love to hear how anyone uses any release film/fabric in any application. Sandwich, mold, plug, whatever.
Dave, does perforated release film give a flat, almost mirror finish inside the molded part, an image of the fabric texture or a wavy glass texture like un perforated film? Can you reuse release film or does it tear up when you remove it?
Thanks.
Thanks.
MN
I am doing wings in a female mold using sandwiched Rohacell, so I don't get a mirror finish. After the resin cures, the rohacell is smoother than it was, but I definately wouldn't call it perfectly flat.
I don't think it would leave a mirror finish using just glass though.
I use peel ply (tight weave dacron fabric) on the bag side of my sandwich panels (wing skins, fuselage parts... flat panels, etc.). I use peel ply when I want to remove excess epoxy, but primarily to result in a bondable surface where panels will be joined, internal parts will be added and so on. The perforated release film leaves a surface much like nonporous film, with the addition of little dots at the location of each perforation.
I don't usually wet-out the peel ply, as that would reduce its ability to wick epoxy out of my layup.
Keep in mind that Rutan was building full scale light aircraft... so the scale of things is a little different. I suspect the strip of peel ply he suggested using would have been wet out to use surface tension to hold it flat. It won't be as flat as a bagged surface though. There's no way around that, so Long-Eze builders do a lot of sanding.
The most "interesting" use I've found for peel ply is to use it as the hinge material in a skin hinge. Cheaper and easier to deal with than Kevlar and works just as well.
-David
-David
MN
ORIGINAL: davidfee
The way I've done the peel ply skin hinges, the peel ply (dacron/nylon fabric) goes between the outer glass (or carbon, whatever) layers and the core material. The epoxy which penetrates the peel ply acts like a million tiny rivets holding the whole thing together. There is a ton of bonding area, relatively speaking.
If you think about the loads on the hinge, you can break them down into shear and tension loads. In shear, there's no way you're ever going to pull the hinge out with flight loads... the core material would fail first. In tension, practice peeling up a fully saturated strip of peel ply from a cured laminate. First you have to get it started... and then the forces required are still very much greater than anything a flying surface will see in use.
The trick is to scribe through the outer layers of glass/carbon/epoxy and stop just shy of the peel ply. Then scribe the inside also (need to cut the lower surface free first). Then you gently flex the hinge to fracture the epoxy along the hingeline. The more you flex, the more free the hinge becomes. I typically cut the peel ply on a bias to further reduce hinge stiffness.
Just make yourself a test article like Mike James did... I think you'll be sold. He used Kevlar, I believe, but the principle is no different.
-David
-David
MN
ORIGINAL: davidfee
Also I couldn't see how to keep the matrix out of the hinge cloth. I figured I'd have to just score and break it like cutting a piece of window glass.
As you say, just go make one. It helps to boot El Diablo out of the details.
To lay up the wing and control surface as one lamination I'd have to have some kind of precision machine to cut through all but one layer of laminate and leave the last one intact. Again, that's just me.
Peel ply lays down quite well all by itself when it is wet out. I use it all the time on my Long EZ, and yes, it is different on full scale. I use it when I want to suck epoxy out of a layup. Put it on the layup, heat it and squeegee it and it takes the extra resin out. You don't want to starve a layup with it though. I have only vacuum bagged one set of wings on the full scale, and it was a huge pain. I would like to learn it with smaller stuff. We don't use vac much on the full scale EZs. The Berkut used it, but like I said, it was a huge pain on that bird. We did vac bag the wings on it, but something that large is tough to get all set up.
Peel ply works great for making a surface uniform so you don't have to sand as much on something that large, given you start with a good surface on the foam. If it is wavy to start with, you will get a bad surface. All my surfaces were cut over size and sanded to final size with straight bars so they are dead nuts! When the glass goes on, it is darn near perfect. Looks great when its done.
