Mode One
Joined: 5/4/2005 From: Park Rapids, MN, USA Status: offline
It’s Friday evening, I’ve been in the basement and finally getting down to covering my SE5a. I have the rudder and the fin covered with the antique Super Coverite I decided to use for covering material. I found Super Coverite to have a savings over Solartex. At a similar quantity, Coverite cost 89 cents per square foot whereas Solartex was $1.13 per square foot. I ended up with 56.25 square feet of Coverite and will have a bit of material left over. I would not have had enough to completely cover the plane with the similar roll of Solartex. Albeit, I could have had colored Solartex and Super Coverite only comes in the Antique color. So, I will need to paint the PC-10, something I am O.K. with, as the Olive Drab available from Solartex never looked right for PC-10 and Solartex appears to not be making their PC-10 anymore. Anyway, the covering process is going good! I haven’t used Coverite in over 10 years and am amazed at how easy the material is to apply! It goes around compounds like the rudder and fin outline curves very easy! Using it is akin to putting on an old pair of shoes, it is comfortable and easy to work with. I like the antique color, also. I’ve been off the last two and a half weeks as the place I work has been closed down. As I have said, I was hoping to get the covering done. However, as in all things in life, I‘ve found there is always more work to do, to get a project to where I’m satisfied to move on to the next step. I’m there now and what I’ve covered so far looks good to me. I have concerns about the direction the hobby is taking. More and more R/Cers seem to not be building kits! This really saddens me, as I get such enjoyment from building (read the Stafford thread). Building really centers me. It is a release from the day to day grind. But I know if kits cease to be, I will simply build scratch from plans, my own or others. Dynaflite SE5a Guys, this seems to be getting pretty one sided!
< Message edited by Mode One -- 1/6/2007 3:18:55 AM >
_____________________________
Mode One, AMA 59157
