Mode One
Joined: 5/4/2005 From: Park Rapids, MN, USA Status: offline
I left the aluminum attachment tab placement in the locations Dynaflite designed and changed the cant and rake of the cabanes so they would meet them in the lower positions. Because they are perpendicular to the fuselage centerline from the side view, the forward Cabanes, only cant out more then as designed. The aft cabanes both cant out more and are raked forward more. Other then shortening the interplane struts, they are the same. I did all this by drawing a full scale mock-up of what I wanted in side and front views on the back of the fuselage plans. The plywood cabane socket parts need to be slightly modifed, to allow the change in angles. You could also keep the cabane angles and sockets the same as designed by Dynaflite, and move the plywood ribs for the Aluminum tabs in closer. You might need to make new ones, because the aft cabanes would meet the wing farther aft. If you want, I could send you a line drawing showing the new angles from the side and front. They are rudimentery, however. I could FAX or mail. Send me an email, if you want to do this.
_____________________________
Mode One, AMA 59157
