RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-5A / Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-5A / Build
Page: <<   < prev  9 10 11 12 13 [14] 15 16 17 18   next >   >>
Login
RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-5... - 3/31/2007 2:35:52 PM
JIMARRINGTON
Status: offline
Mode One,
Can hardly wait for your pics and "test flight" results.
I am still moving ahead on my SE. The tailfeathers are just like my small electrics just using larger pieces of wood. They are going together quickly. Fin and Rudder are done. Working on the stabilizer now. The middle balsa piece for the stabilizer in my kit was cut about 1/16" too short. Will have to shim it in. Was yours cut too short also?
Jim
(in reply to Mode One)
       Post #: 326
RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-... - 4/1/2007 12:07:52 AM
Mode One
Status: offline
Almost so long ago, I can't remember, however, I think a basswood doubler goes between it and the T.E of the stab. However, it seems that this part was short anyways. I think I made a new one, or added shims like you suggetsed.
< Message edited by Mode One -- 4/1/2007 1:04:14 PM >
_____________________________
Mode One, AMA 59157
(in reply to JIMARRINGTON)
       Post #: 327
RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-... - 4/1/2007 1:08:42 PM
Mode One
Status: offline
The Mall Show was great fun. It was the first time I actually got to see the model completely assembled, so was a treat from that aspect, also. I didn't win anything, for the model. However, it's the door prizes for these things that make it worthwhile and I really cleaned up! First I won a new Sullivan starter then a Sig Somethin' Extra ARF. Not sure if I'm going to hold onto the ARF or sell it on Ebay!
Mode One, AMA 59157
       Post #: 328
RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-... - 4/6/2007 11:29:00 PM
Mode One
Status: offline
I have some photos, they're at a Mall Show and a little dark.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Mode One -- 4/7/2007 4:28:11 AM >
Mode One, AMA 59157
       Post #: 329
RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-... - 4/7/2007 12:47:39 PM
Mode One
Status: offline
More photos, pre-painting. The wing tip photo shows changes I made to the tip. Dynaflite's design had radial tip pieces at the leading edge, I eliminated these and added balsa blocks at the tips, which have been faired to shape. The bottom of the wing tip is the same as Dynaflite designed. To rear of the fairing blocks are two gussets to stabilize the tip shape sheet balsa parts The front view was taken to show how much the top wing was dropped. If you can imagine the top wing another 1.5 inches higher, that would put the bottom of the wing, where the top is now. You can also see where I used sheet styrene with embossed rivit details to simulate the sheet metal cowling (bonnet, for the Britts). The 4 photos you see took about 1 hour to upsload. Yep, my phonelines are SLOW!
Click for fullsize
Click for fullsize
< Message edited by Mode One -- 4/7/2007 1:10:50 PM >
Mode One, AMA 59157
       Post #: 330
RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-... - 4/8/2007 9:09:45 AM
Mcubed
Status: offline
Here are some pictures of the undercart I am building for mine I started at the bottom.
Of all the things I have lost over the years I miss my mind the most!!!!!!!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Of all the things I have lost over the years, I miss my mind the most!!!
       Post #: 331
RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-... - 4/8/2007 12:06:56 PM
Mode One
Status: offline
Mcubed, Is this a second airplane or a rebuild of the first? Have you been paying attention to the 1/6th SE5a build on Scale R/C Airplanes?
The L.G. Looks great!
Mode One, AMA 59157
(in reply to Mcubed)
       Post #: 332
RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-... - 4/8/2007 1:37:38 PM
Mcubed
Status: offline
I am starting the second plane, I considered modifying the first one but then I thought "hey I enjoy flying it as it is".
Yes I have had a look at the 1/6 build, that guy is way out of my class. Absolutley briliant model.
       Post #: 333
RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-... - 4/12/2007 3:43:29 PM
Mode One
Status: offline
Although I have a Magnum .80 installed in the airplane, I just ordered a Saito 1.00 to power the plane with. After seeing the thing assembled and hefting it around a bit, I got to thinking the .80 just might not have enough smutz. I always wanted a 1.00 4 stroke anyway!
Mode One, AMA 59157
       Post #: 334
RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-... - 4/12/2007 8:11:03 PM
JIMARRINGTON
Status: offline
Here is a link to an SE5 restoration that has some really neat pictures. http://storage.mfa.free.fr/SE5Auk.html
Jim
       Post #: 335
RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-5A / Build - 6/11/2007 3:50:50 AM
frankam
Status: offline
WHEN BUILDING THE FRONT STRUT MOUNTS FOR THE DYNAFLIT SE5A DID YOU HAVE A PROBLEM WITH THE DICUT SIDE PIECES NOT FITTING AND HAD TO MODIFY THESE PARTS TO MAKE THEM WORK, THE TWO ANGLED PARTS. THESE PARTS ARE CALLED OUT AS (SM)
(in reply to bhole74)
       Post #: 336
RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-... - 6/11/2007 2:40:16 PM
Prop Nut
Status: offline
Frank, I had to custom fit mine.
Scope? Listerine? Or Prop Wash?
(in reply to frankam)
       Post #: 337
RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-... - 6/11/2007 10:17:41 PM
Mode One
Status: offline
Frank,
Since I lowered the top wing to a more scale like wing gap, yes, I had to modify them. My cabane struts are more splayed-out then as the kit was designed. I did use the original parts; but, I modified them.
Also Frank, I went back quite a ways and could find no responses from bhole74, where did this come from?
< Message edited by Mode One -- 6/11/2007 10:25:27 PM >
Mode One, AMA 59157
(in reply to Prop Nut)
       Post #: 338
RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-... - 6/11/2007 11:17:07 PM
Prop Nut
Status: offline
Mark, I dont think that he was actually replying to Brian (BHole). I think he just clicked reply where Brian had made a comment at the end of a previous page. Its an annoying feature that RCU has.
       Post #: 339
RE: Dynaflite SE5A / S.E. 5A / SE-5 / SE-... - 6/14/2007 3:50:29 AM
Mcubed
Status: offline
Still Building, I have decided to Rebuild the SE5a I have been flying for the time being, adding more scale detail and correcting the lines etcetera.
I have stripped down the fuse to allow a rebuild of the cockpit area. and am looking at the ways of attaching the upper wing in the lower position. Given that the wing struts are very firmley attached to the fuse I will probably modify the wing to adjust the mouting points rather than changing the strut angles as I would for a fresh build.
Good flying weather over hear except for the storms, the floods and the ongoing drought!
Click for fullsize
Click for
