G-38 on a Sig 300xs?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> G-38 on a Sig 300xs?
Page: [1]
Login
G-38 on a Sig 300xs? - 12/29/2001 9:28:53 PM
Steve
Status: offline
Is the G-38 a good choice for the Sig 300xs or will it need more power?
Steve
       Post #: 1
G-38 on a Sig 300xs? - 12/30/2001 1:27:09 AM
BAS
Status: offline
A friend of mine is running a g38 on his and it hauls it around great no more power needed but keep in mine t;he g38 is a heavy motor compared to fpe and Brisons and the rest of the newer gassers . I am not sure if tail weight was needed or not on his , Good luck
_____________________________
Bruce A Swartfager
(in reply to Steve)
       Post #: 2
G-38 on a Sig 300xs? - 12/30/2001 1:08:53 PM
ShempHoward
Status: offline
There is one of these at one of the 2 clubs I fly at with a Brison 2.4 in it which with the rudder and elevator servos in the tail seems to have balanced out with little or no added weight. He did a very good job of reinforcing the servo mounts in the wing panels as well which this plane neeeds as the stock servo mounting system is weak. The plane flies well with good vertical authority but I have only seen it fly a few times and that was when the kit first became available. The owner also reinforced the firewall with a system of pinning with dowels and the use of fiberglass cloth. I have not seen the owner in quite some time so I have no idea how well it held up with this gas engine on it. Although the G38 is of similar displacement I think it will be heavier and a little less powerful than the Brison 2.4. Conversely at the other club a fellow is flying the World Models 120 size Cap 232 with a G38 and is happy with it and the way it handles. Again with servos in he tail. My observation was that it was a bit heavy flying and seemed to land a tad hotter than pehaps it should.
(in reply to Steve)
       Post #: 3
G-38 on a Sig 300xs? - 12/30/2001 2:29:29 PM
JBH
Status: offline
Hi Steve!
[COLOR=teal]>>Is the G-38 a good choice for the Sig 300xs or will it need more power?<<[/COLOR]
It weighs as much as the ZDZ-80.
The SIG 300xs can balance easily with a motor half that weight.
The price is tempting... but...
(in reply to Steve)
       Post #: 4
Sigs 300SX w/G-38 - 12/30/2001 5:25:36 PM
Jimmy Bananas
Status: offline
I'm the person that BAS was talking about..G-38 is enough power for me,but with this engine,it weights 15 Ibs..Had to add tail weight..flies very good,but landings are a little hotter than I expected...do need power to land...It likes to bounce on landing.....good luck
(in reply to Steve)
       Post #: 5
G-38 on a Sig 300xs? - 12/30/2001 7:40:32 PM
Paul Grubich
Status: offline
Hi Jimmy, good to see you made it over here.
Paul
(in reply to Steve)
       Post #: 6
Bouncing - 12/30/2001 9:35:49 PM
Steve
Status: offline
Jimmy;
I had a Goldberg Stadaucher with a bad bouncing problem. I hated it! Is there any remidy for this problem? Softer gear, bigger wheels ect...
Thanks Steve
(in reply to Steve)
       Post #: 7
Bounce..Bounce - 12/30/2001 10:11:37 PM
Jimmy Bananas
Status: offline
Steve:
Try harder wheels...soft type don't get it....don't know the size of your wheels on your plane.....try the harder wheels first.....then try 1/4" larger wheels, again the hard type....every plane lands differnet.....my 300, I damn near have to 3 point it to avoid the bounce...hope this helps
(in reply to Steve)
       Post #: 8
G-38 on a Sig 300xs? - 12/30/2001 10:26:14 PM
Steve
Status: offline
Jimmy;
I'll try some stiff wheels. Thanks
Steve
(in reply to Steve)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.797RCU1
