shauntot
Joined: 8/12/2005 From: paranaque manila, PHILIPPINES Status: offline
raven / jason - thanks very much for the quick replies again. to be honest, i am toying with the idea of getting the brushless system for my xxx-t mainly because of the fact that a brushless motor almost does not require maintenance (replacing brushes, cutting comm, etc), and also the added benefit of longer run times plus the incredible speed. i use lots of brushless motors, escs and lipos on my planes, and would also like to get one for my car as well due to the advantages it has, plus, i'm seeing that I can use some of my lipos for the brushless system for the xxxt, which would really save me from buying more batteries. thank you for the info on the 5.5 and 5800. i mostly run on pavement just for fun, so it looks like i'll be getting a 5800 system, if i don't want to be replacing tires every 5 batt packs spent
_____________________________
Crashing is a given, don't be sad when you do, for there's always glue!!!
