RE: Your kidding,,,,,,
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> VPP - Variable Pitch Prop 4D flying >> RE: Your kidding,,,,,,
Page: <<   < prev  1 [2]
Login
RE: Your kidding,,,,,, - 5/25/2005 3:08:12 PM
Tommy_Gun
Status: offline
Buliding a full scale aircraft to take the loads of deceleration from in flight prop reversal would be a real challenge.
Wayne Handley did it with his turbine powered Raven for a bit, but it wasnt anything that was near as abrupt as what you see in the model videos.
_____________________________
Yeeeeahhh seee.
Say hello to my leetle fren.
(in reply to flip3d454)
       Post #: 26
RE: Your kidding,,,,,, - 5/25/2005 3:32:24 PM
Breakstuff5050
Status: offline
There are alot of full scale planes that have reverse pitch to back up on the runway and stuff, but like FlinVR said about the raven, its not near as abrupt!
Team Leland
www.lelandstoytrains.com
(in reply to Tommy_Gun)
       Post #: 27
RE: Your kidding,,,,,, - 5/27/2005 3:32:05 AM
Fly-n-3D
Status: offline
The vpp looks great! You have to see the video of it at hobby-lobby.com. In the future we will probably see a full scale edge with a vpp prop.
(in reply to Breakstuff5050)
       Post #: 28
RE: Your kidding,,,,,, - 5/27/2005 4:15:09 AM
Breakstuff5050
Status: offline
quote:
ORIGINAL: RC13
Too bad none of us will be alive to see that, bc right now we are having trouble producing VPP props that can handle over 10 oz of thrust. Much less a 14,000 LB airplane (not sure how much a full scale aerobatic plane weighs though.)
Team Leland
(in reply to Fly-n-3D)
       Post #: 29
RE: Your kidding,,,,,, - 5/27/2005 9:22:20 PM
Tommy_Gun
Status: offline
I just dynamic balanced the prop on a full scale Extra 300.
The pilot says hers weighs in around 1700 lbs.
Yeeeeahhh seee.
       Post #: 30
RE: Your kidding,,,,,, - 5/27/2005 10:20:59 PM
Breakstuff5050
Status: offline
looks like I was in the ball park!
Team Leland
       Post #: 31
RE: Your kidding,,,,,, - 6/2/2005 8:14:38 AM
Dr.Watson
Status: offline
anybody tried a VPP on a Slow Stick!!!! just kidding!! that would be awsome though!
http://www.therczone.com/forums/index.php?referrerid=1256
www.fxgrafix.net
       Post #: 32
RE: Your kidding,,,,,, - 6/6/2005 10:31:18 PM
martinoto
Status: offline
I don't remember the exact year, but the famous Hanno Prettner won a World Champ using a Variable Pitch Prop in his Calypso, with a .60 engine. Apparently it helped him to reduce speed in nose-down verticals.
I also remember seen the VPP unit (very expensive), and I was told that it was a servo eater¡¡¡
Next championship Hanno went with "spoilers" attached to the retracts, which went partially down for that purposes... obviously a simpler solution.
If somebody can remember this, it would help me not to feel too old....
"Give me balsa and a cutter, and I will cut a little too much"
(in reply to Dr.Watson)
       Post #: 33
RE: Your kidding,,,,,, - 6/7/2005 4:24:31 AM
mdavies31
Status: offline
This guy does, post #5.
http://www.rcuniverse.com/forum/Variable_pitch_props/m_138653/tm.htm
(in reply to martinoto)
       Post #: 34
RE: Your kidding,,,,,, - 9/20/2006 4:12:10 AM
EddieWeeks
Status: offline
They are now doing 100 cc gas VPP
http://www.variablepitchhobbies.com/
(in reply to mdavies31)
       Post #: 35
RE: Your kidding,,,,,, - 11/15/2007 7:37:29 AM
troposcuba
Status: offline
C-130's can back outta their parking spots. I have been in several that backed up on the ground. I think that qualifies. they also reverse when they land to help reduce the rollout after getting it on the ground. i think it would be a disaster if it happened in flight though. not sure, but i think there is some kind of failsafe that prevents that.
at 'em boys, give 'er the gun!
(in reply to EddieWeeks)
       Post #: 36
RE: Your kidding,,,,,, - 11/15/2007 11:43:24 AM
Bugzilla
Status: offline
quote:
ORIGINAL: troposcuba
Can you say "drop like a rock?" Yeah, there is a failsafe that keeps that from happening. I used to work on 130's for the Air Force, and I had the same question. Engine troops and crew chiefs cleared that up for me.
"Life is a near death experience"-George Carlin
(in reply to troposcuba)
       Post #: 37
RE: Your kidding,,,,,, - 11/15/2007 11:46:35 PM
troposcuba
Status: offline
quote:
ORIGINAL: Bugzilla
that's what i figured. i am a sheetmetal troop currently working 130's and A-10's in the USAF. I never asked that question, but figured that was the case. I guess i can show some pilots the vids of the 4d foamies and ask if they have the guts to give it a try... without me onboard!
(in reply to Bugzilla)
       Post #: 38
RE: Your kidding,,,,,, - 11/21/2007 8:05:51 PM
CoytAW
Status: offline
my uncle does c-130 training in st. joseph, missouri. they do some crazy stuff with those things. im sure they have the guts to try it... if there were a possibility of success!
       Post #: 39
Jump to:
