tommy s
TX, USA Status: offline
Maybe it's not the fact that the airplane is made of composite material , maybe it's the size of the control surfaces causing the flutter. The movable control surfaces on most airplanes are way bigger than they need to be in my opinion. I know on my Excelleron the movable surfaces are huge and I have them moving very little to execute the maneuvers in a pattern flight , they could be much smaller and still function well. It seems a lot of manufacturers nowdays are designing planes to fly pattern and 3-D , so they design bigger control surfaces when smaller ones would do just fine. I'll bet everyone who flies R/C has seen what flutter can do to an airplane. I see a lot of 3-D models at the field where I fly experience horrible flutter with terminal results , probably because of excess speed with their huge elevators, rudders and ailerons. I have an older pattern plane, an Illusion with a MVVS .91 , and the surfaces on it are about 1/2 the size of the ones on my Excelleron and even at that size are very sensitive and move very little. Maybe the answer is as simple an downsizing the control surfaces and really slack free linkage with good mechanical advantage. tommy s
< Message edited by tommy s -- 4/28/2005 10:46:50 PM >
