Dirty South Racing
VA, USA Status: offline
quote:
ORIGINAL: Nick2618 quote:
ORIGINAL: Dirty South Racing quote:
ORIGINAL: plastation7 Do the gearboxes strip out a lot or something? I think what he ment was that the way the rear shock tower is mounted on the gear box housing if you flip or wreck alot it tends to break the gear box housing, not that the gears strip out. Never broke my gearbox. Have broken a couple rear shock towers thou. If you run metal shock tower then you brake the tranny case instead of the shock tower... Yes, that's what I ment. I think that's what stinkypinky is talking about, but he may want to clarify that.
