RE: -Official Traxxas JATO Thread-
Tower Hobbies
Logged in as Guest
Users viewing this topic: Hugh Betcha
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> RE: -Official Traxxas JATO Thread-
Page: <<   < prev  108 109 110 111 112 113 [114] 115 116 117   next >   >>
Login
RE: ... - 5/5/2008 12:46:06 AM
RC-Captain
Status: offline
check the wheels looking from the top of the car and make sure the back 2 wheels point in the same direction and the front 2 wheels point in the same direction. If yes then lift the front of the car and spin the wheels one at a time does one spin slower than the other ? If no then lift the back pick one wheel and spin it forward , do both rotate forward ? if yes do it backwards do both rotate backwards ? if yes then find some room and roll the truck on the ground what does it do ? go straight ? , to the left ? to the right ? let me know .
CAP
_____________________________
I finally broke bread and bought a real charger , THE TRITON 2............
(in reply to JattoMan3.3)
       Post #: 2826
RE: ... - 5/5/2008 2:04:51 AM
Bgdustin4
Status: offline
i got my jato a few days ago and i striped out the spur gear in like 15 min don't know why i orderd a steel one same tooth as the stock one think i will need to upgrade the rany gears i seen some one talking about bronze gears or something like that where would i get them ?
(in reply to RC-Captain)
       Post #: 2827
RE: ... - 5/5/2008 2:10:30 AM
RC-Captain
Status: offline
If I was you I would adjust your slipper clutch and try using the same gears that originally came with the truck. I was out at a track today , which I have never been at , and my Jato took a beating . NOTHING BROKE OR STRIPPED . I have an idea now on how to control the jumps but I must have flipped and rolled my JATO 50 times before landing on all four wheels ,which is why the slipper clutch is need to keep the teeth from breaking.
CAP
(in reply to Bgdustin4)
       Post #: 2828
RE: ... - 5/5/2008 2:14:50 AM
Bgdustin4
Status: offline
i had a redcat befor this jato and i don't know much about the slipper thing i read the book about it how far shuld i turn it out don't know how far in it is right now tho ill go look
       Post #: 2829
RE: ... - 5/5/2008 2:19:40 AM
RC-Captain
Status: offline
Holding the car , you should be able to turn the big gear with the spring and nut in front about 3 quarters of a turn before you see the whell start to slip or turn.
CAP
       Post #: 2830
RE: ... - 5/5/2008 2:23:04 AM
Bgdustin4
Status: offline
i just went and tried to tighten it and it was all the way snug i mean i did not force it or any thing but i lossed it up some ill see how it works out that spur gear shuld be here monday if i leave it like that with that steel one and have really fast acceleration think it would mess up the trany ?
       Post #: 2831
RE: ... - 5/5/2008 2:33:46 AM
RC-Captain
Status: offline
were you able to hold the car and turn the gear 3/4 of a turn beforethe wheels attempted to move ? Yea if it was all the way tight you got lucky by ruining the gears. A guy has an electric one and destroyed is mass differential. and tranny gears.
CAP
       Post #: 2832
RE: ... - 5/5/2008 2:40:42 AM
Bgdustin4
Status: offline
i can get like a half a turn but if i go any losser then that then it just spins and the wheels don't mone at all u can talking about turning it with your hand right i don't ahve a spur gear on there so im just turning it with my hand, also the ajuster screw is loose enuf i can tightin it with my hand to is that to loose ?
       Post #: 2833
RE: ... - 5/5/2008 2:50:44 AM
RC-Captain
Status: offline
Im sorry to do the test you will need the spur gear on the truck.
CAP
       Post #: 2834
RE: ... - 5/5/2008 2:53:03 AM
Bgdustin4
Status: offline
ok when i get it what to i turn just roll the truck ? and see if the whells move 3/4 a turn befor it starts moveing the spur gear ? also could u look at my photos and what u think my jato is worth i got it with all that stuff on it already just curius
       Post #: 2835
RE: -Official Traxxas JATO Thread- - 5/5/2008 10:25:13 PM
FastestJato
Status: offline
my wheels aint turning probobly tranny going to open it 2day an see whats the problem
GO JATO OR GET LEFT BEHIND
(in reply to rcjunkie50)
       Post #: 2836
RE: ... - 5/6/2008 3:06:48 PM
espn86
Status: offline
Hi, just brok my 3.3 engine, and now I need a new one. Some tips?
What about this? http://www.rcplanet.com/O_S_18TZ_TX_w_Rotary_Carb_p/osm11943.htm
Do I need more parts?, or will it just fit right in?
       Post #: 2837
RE: ... - 5/7/2008 1:05:03 AM
motorhead91
Status: offline
you will need the slide carb version..
you could TRY to make the rotary carb work, but getting the linkages to work right would be hard
Chuck Norris Doesn't Have To Write Books. The Words Assemble Themselves In Fear.
(in reply to espn86)
       Post #: 2838
RE: ... - 5/7/2008 3:37:17 AM
RC-Captain
Status: offline
HOW DID YOU BREAK THE ENGINE ? JUST CURIOUS.......... I think I put my Jato through every bad landing I could possibly do and nothing broke.........knock on wood.
CAP.
       Post #: 2839
RE: ... - 5/7/2008 3:57:44 AM
RMH3
Status: offline
Ok, I just got the Jato 3.3 and i want to ditch the battery holding/Wheelie Bar bumper and put on the extra one that came w/ the truck..Prob is I cant get it off because there is a screw coming through the back... Driving me nuts!!! Ty!!!!! and i cant see ne hints on the blow up models in the manual or online......Thanks
       Post #: 2840
RE: ... - 5/7/2008 4:56:08 AM
