RE: -Official Traxxas JATO Thread-
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> RE: -Official Traxxas JATO Thread-
Page: <<   < prev  110 111 112 113 114 [115] 116 117 118 119   next >   >>
Login
RE: ... - 5/8/2008 9:04:32 AM
scottywilkes
Status: offline
to the person asking about the speed T, the speed T runs a ball diff, while the jato runs a geared differential, the geared diff relies on the diff oils to give the restriction at speed, it wont feel like much when its standing still.
While the ball diff is a central gear, with small balls within it, they are then sandwiched with a plate either side and tightened with a central nut, the more u tighten it the less diff action u get.
Dont worry your diff is fine
_____________________________
MGT;Mach 427, FT NTC3;RBC12, RTR NTC3, Tamiya F103, NEVST, RC18T, Jato;STS28
(in reply to FastestJato)
       Post #: 2851
RE: ... - 5/11/2008 7:21:13 PM
motorhead91
Status: offline
speaking of diffs, i think i just blew mine out yesterday, not sure though, didn't have a chance to look at it
its probably not good though when both wheels turn forward with the brakes applied, and a clinking noise comes from the tranny case
Chuck Norris Doesn't Have To Write Books. The Words Assemble Themselves In Fear.
(in reply to scottywilkes)
       Post #: 2852
RE: ... - 5/12/2008 11:36:22 PM
deepsouthoutlawracer
Status: offline
does anybody know if there is anything i can do to stop tearing up the first gear in my jato???
everything runs perfect except for the 1st gear wich gets stripped out every couple tanks of fuel.
can i do anything like a diff trans?
i dont want to got to the 1st speed gear kit.
but any suggestions
(in reply to motorhead91)
       Post #: 2853
RE: ... - 5/12/2008 11:59:56 PM
RC-Captain
Status: offline
Sounds like you are running in first gear at high speeds and are shifting into second WAY TO LATE . There is an ajustment for shifting later RTM it tells you how to adjust it properly. When I first got my JATO , I couldn't get into second gear until 60 yards or so so I lowerd the shift, now I can get into second around 35-40 yards.
CAP
I finally broke bread and bought a real charger , THE TRITON 2............
(in reply to deepsouthoutlawracer)
       Post #: 2854
RE: ... - 5/13/2008 12:34:33 AM
Status: offline
ok thanks............ how far do u think i should turn it to start
(in reply to RC-Captain)
       Post #: 2855
RE: ... - 5/13/2008 12:37:22 AM
motorhead91
Status: offline
its hard to tell, just adjust it and see where it gets you..
very small adjustments greatly affect the shift point
i looked in my tranny case and the gears shredded, so it looks like i will be buying the aluminum set
       Post #: 2856
RE: ... - 5/13/2008 1:07:56 AM
RC-Captain
Status: offline
motorhead is right, you have to do 1/8 turns at a time and run the truck after each turn at least two high speed passes listening for when it shifts.
CAP
       Post #: 2857
RE: ... - 5/13/2008 1:32:06 AM
COPS HATE ME
Status: offline
this will be cool to do with a jato
#5522X Traxxas 7075 titanium-anodized chassis
#5536R Traxxas 6061 titanium-anodized aluminum steering blocks
#5536X Traxxas 6061 titanium-anodized aluminum 25-degree caster blocks
#5532X Traxxas 6061 titanium-anodized aluminum 30-degree caster blocks
#5555X Traxxas 6061 titanium-anodized aluminum hub carriers
#5542X Traxxas 6061 machined aluminum drag link
#5460X Traxxas aluminum GTR hard-anodized shock set
#5429 Traxxas 1.0 rate tan springs (pair)
#5431 Traxxas 1.2 rate silver springs (pair)
#5483 Traxxas Resonator single-chamber pipe
#4120 Traxxas 20T clutch bell gear
#5551X Traxxas low-mass CVD rear driveshaft set
#3036 Traxxas 1100MaH 5-cell receiver pack
#5539X Traxxas red-anodized turnbuckles
#5537X Traxxas blue-anodized 7075 aluminum spindles
#1747X Traxxas blue-anodized aluminum flanged lock nuts
#5186 Traxxas fire-red anodized aluminum wheelie bar wheels
#1120-00 Pro-Line Moab 2.2 tires
#1126-00 Pro-Line Mohawk tires
#1974 Traxxas 2.2 dished wheels (front)
#1972 Traxxas 2.2 dished wheels (rear)
#5135 Traxxas 10K diff fluid
       Post #: 2858
RE: ... - 5/13/2008 1:53:01 AM
Status: offline
to motor head wear can i but the aluminum set of gears????
(in reply to COPS HATE ME)
       Post #: 2859
RE: ... - 5/13/2008 2:23:12 AM
Status: offline
rc captain or motor head are there aluminum gears for the gears that come plastic or stock in the jato transmission?
       Post #: 2860
RE: ... - 5/13/2008 3:15:04 AM
RC-Captain
Status: offline
plastic or stock ? im not sure what you mean. Since I never opened my tranny I don't know what they are made of but one guy said he is getting metal gears so one would guess they are nylon .
CAP
       Post #: 2861
RE: ... - 5/13/2008 12:01:41 PM
mrpricelessp
Status: offline
hey guys the gears in the tranny are mos def. plastic, that was the first upgrade i made to my jato, I have brass tranny gears, I purchased from my LHS in N.O. havent had any probs thus far.,and i running the O.S. 21tm
       Post #: 2862
RE: ... - 5/13/2008 12:22:03 PM
scottywilkes
Status: offline
im running the bronze gears in my tranny, and im running a big block Mach 427 (.26) and STSD28M, i just recently demolished the smaller bronze pinion gear when the grub shaft came out, smashing into the 2nd speed gear and ripping a nice chunk out of the gear as well LOL. Anyhoo ive replaced them with stock plastic gears again, and after about 2 litres with the MACH 427 the plastic gears are still fine.
(in reply to mrpricelessp)
       Post #: 2863
