scottywilkes
Joined: 10/21/2005 From: launceston, AUSTRALIA Status: offline
adjust the steering turnbuckle. Its the silver bar leading to the wheel, not the upper one, that adjust camber not toe you want to adjust the toe of that wheel, easiest way is turn the radio etc on so that the servo is in its neutral position, then in the middle of the silver turnbuckle theres like a hex, you should have got a tool with the jato to adjust it, or just use some pliars, 1 way makes the wheel point more outwards (more toe out) The other makes it move inwards (increasing Toe in) U will notice when u start adjusting, if it goes outwards, turn it the other way
_____________________________
MGT;Mach 427, FT NTC3;RBC12, RTR NTC3, Tamiya F103, NEVST, RC18T, Jato;STS28
