Unbreakable207
Joined: 8/21/2004 From: , MD, AFGHANISTAN Status: offline
quote:
ORIGINAL: Raster quote:
ORIGINAL: Unbreakable207 The stock tires are pritty bad on loose dirt. Pick up some lose step pins and front ribs or proline tires. That looks wicked nice freak. Dang. Yesterday I did some high speed running and grass running with glads and edges. Boy did this thing rip! And for those people who have driven there's on pavement, Doesn't it handle like a touring car? its such a great feelin'. On the grass it soaked up all the ditches and bumps nicely with those oversized shocks. I can't wait to race thins thing! here's an updated pic: -RPM Blue Clawz with Edges and Gladiators -Futaba 3PM radio -Venom Receiver pack -Traxxas tuned pipe -Traxxas Blue Head -Pull start Unbreakable, That Jato looks fabulous! That's pretty much how I'm planning to set up mine. Those tires you put on it, look great. to me, it gives the truck a better look, than the stock ones. I view the stock tires, simply as a set of "break-in" tires and nothing else. Nothing wrong with that, though. Have you noticed a difference in performance with the Traxxas tuned blue pipe? What about with the machined head? How has your running temperature changed with it? Also, which RPM Claws did you use? The ones for the Rustler? Is the offset the same? After break-in, I'm planning to change the wheels and tires, put on the blue 2.5r machined head, the blue tuned pipe and a pull start. I already have a JR XS3 Pro ready to use with it, too. By the way, who makes the Gladiators? I view stadium trucks as a very capable on-road car (in addition to racing on smooth dirt, of course). I also have lots of street tires for them. They are much better for running on parking lots than TCs, since they have more ground clearance and bigger tires. And it doesn't hurt when you run off the pavement, either. Thanks Thank you for the comments. This set-up is excellent. The tires have lots of grip and handling. The cooling head really lowers the temperature.. maybe a little too low... but tuning can fix that. The Traxxas tuned pipe did give me more mid and top end power. I like it, only thing is, it doesn't fit perfectly with the mud guards, but it still is fine. Traxxas is coming out with a whole fleet of pipes soon. RPM Clawz Rears: http://www.carttonic.com/catalog/in...8d24a46fb68f97f RPM Clawz fronts: http://www.carttonic.com/catalog/in...8d24a46fb68f97f Proline gladiators: http://www.carttonic.com/catalog/in...274π_id=49064 Proline Edges: http://www.carttonic.com/catalog/in...274π_id=13062 Tell me how your set up goes.
