javiergarzab
Joined: 3/31/2005 From: CuernavacaMorelos, MEXICO Status: offline
Hixx, I'll post the pictures on Monday when I get my digital camera back. (I left it at my office) I used dubro medium size nylon hinges, they are pinned and I used 5 for each aileron. They are spaced almost 7cm each. I just cutted the ailerons, sanded the edge and placed some 1/2 inch deep x 1 inch wide cuts with a cutter on the ailerons and on the wing (Matching the positions), then I used Foam Safe CA (Thick) and installed the hinges to the wing. Be careful not to put the CA to close to the pin on the hinges or to allow gravity to move CA to it, or you'll end with a rigid aileron. I left the CA dry and then applied CA to the hinge on the aileron side and slide them into the aileron cuts. I decided not to use any kicker so that I could align the aileron. The gap between the aileron and the wing ended up at about 2 or 3 mm. I was able to fly today, even though I was only able to make 3 short flights (5 minute) here are the results of all my modifications: 1.- Hinges,they work really well. I still have the same throw, but they are faster and help to perform better rolls. It might also be caused because I'm using a dual servo configuration, one on each wing... That should help the speed too, but I think that most of the merit goes to the hinges. 2.- Flapperons... I have to admit that I'm very disappointed on this. They had no effect on lowering the stall speed. They had almost no effect, but to make it harder to fly. It seemed as if I lost a lot of wing roll capacity, and gained nothing from it. It was very windy, so I'll give them another try on a better day to see if my perceptions are wrong. 3.- My aluminum home made motor mount broke on my 4th flight attempt, so now I'll give a try at some other materials. I haven't been able to find the Hacker A30-10XL mount on the internet. If anybody knows where I could find a replacement then I'll be very thankful. Regards. Javier
