Nerevar
quote:
ORIGINAL: Xairflyer I am picking up mine on friday, I want to also redo the colour scheme, to the more familular all blue fuselage. What have you guys found the best paint to use on monokote ? Dont really fancy re covering. I haven't ever painted Monokote, but have painted SolarTex - which is another heat shrink covering. SolarTex is a woven, fabric-look, material, made in England (if memory serves me correctly). So, the weave gave it an ideal surface for paint to bound to. With that said - I suppose Monokote could be sanded to roughen the surface for paint to adhere to. A polyurethane base paint worked well for what I did. However, be advised that polyurethane is H E A V Y, and the Stearman is big, so that equates to a significant weight gain for your plane. Like I said, I haven't tried it But if I were going to do this, I'd try this first (in the color of your choice) - Top Flite Lustrekote . It's made by Top Flite, the same company that makes Monokote. And in the 'features' section, it says; ".... Use on balsa, plywood, fiberglass, aluminum, ABS plastic, and MonoKote-covered surfaces .....". - and also; "Get a tough, lightweight, fuel proof finish--easily!". (I added the bold and underline) Be sure to read all the info, including the 'comments' section, for any incompatibilities. Remember - this is JUST what I would do. Again, I haven't tried it myself. I hope that what ever you decide to do, that it works out well for you. The PT-17 is a fantastic plane and a really great flyer! Enjoy it! Ramon
