RE: Great Planes PT- 17 Stearman ARF
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: Great Planes PT- 17 Stearman ARF
Page: <<   < prev  1 2 3 4 5 6 [7] 8   next >   >>
Login
RE: Great Planes PT- 17 Stearman ARF - 1/24/2008 1:34:39 AM
lou1947
Status: offline
Just finished mine and have a 100 saito on it. Have not flown it yet because of the weather. Wondering if you think the 100 saito will be enough or should i go with a 125 Saito? I loke flying scale but I don't mind having a little extra power. How was the stearman on take off? I have heard that they are a handful on takeoffs.
(in reply to Super08)
       Post #: 151
RE: Great Planes PT- 17 Stearman ARF - 1/24/2008 1:37:18 AM
Super08
Status: offline
Should be plenty. The factory one had an OS .91 in it.
(in reply to lou1947)
       Post #: 152
RE: Great Planes PT- 17 Stearman ARF - 1/24/2008 1:40:06 AM
lou1947
Status: offline
Wow was she on take off?
       Post #: 153
RE: Great Planes PT- 17 Stearman ARF - 1/24/2008 1:42:59 AM
lou1947
Status: offline
By the way very nice pictures. I can see that you are also up north and the weather is not condusive to flying
       Post #: 154
RE: Great Planes PT- 17 Stearman ARF - 1/24/2008 1:56:33 AM
Xairflyer
Status: offline
I find it very easy to take off it just leaps into the air, hardest thing is to keep it on the ground to make it more scale, ground handling is great with the 5" wheels on mine.
_____________________________
www.letterkennymodelflyingclub.com
       Post #: 155
RE: Great Planes PT- 17 Stearman ARF - 1/24/2008 2:00:17 AM
lou1947
Status: offline
Thanks for the replies.
(in reply to Xairflyer)
       Post #: 156
RE: Great Planes PT- 17 Stearman ARF - 1/24/2008 3:38:03 PM
Super08
Status: offline
Lou
Yes I'm wayyyyy up north, won't be doing any flying here until April.
       Post #: 157
RE: Great Planes PT- 17 Stearman ARF - 1/28/2008 2:16:37 AM
FlyBy8
Status: offline
Has anyone seen a OS 160 twin in this Stearman? Have one on the shelf and I am considering it.
       Post #: 158
RE: Great Planes PT- 17 Stearman ARF - 2/25/2008 9:19:42 PM
bucho
Status: offline
does anybody know if the Du-Bro Tailwheel sistem fits this pt 17 ?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRWW9&P=7
       Post #: 159
RE: Great Planes PT- 17 Stearman ARF - 2/25/2008 9:22:17 PM
bucho
Status: offline
i found the tail wheel used in this model was so weak, does anyone have a solution for this?
(in reply to bucho)
       Post #: 160
RE: Great Planes PT- 17 Stearman ARF - 2/28/2008 1:51:28 AM
BOUND_4_HELL
Status: offline
I used a Sullivan tail wheel on my and I did not have any problems. I used a bigger one than the weight of the plane. They have nice sturdy springs and it can swivel without messing up your rudder servo.
As for an engine I used a G2300 from Supper Tiger, and before all the Super Tiger bashers get on board, it turned out to be one of my best engines. Turned a 17 X 7 APC prop at 9300 RMP. Pulled 13,5 lb of static thrust. Last summer I had more fun than a man should be allowed to have >> flying the Stearman with smoke on.
Check the Stearman in action on You Tube, just copy and past in your browser. The Stearman makes contact with the grass, so I called the video “ Parting the Grass “.
BOUND_4_HELL
You can never have too much power, as you can always throttle back.
http://www.youtube.com/watch?v=CVN1G2o0pMI
(in reply to bucho)
       Post #: 161
RE: Great Planes PT- 17 Stearman ARF - 2/28/2008 2:48:32 AM
BOUND_4_HELL
Status: offline
Have you considered larger motors like a 140 or 160 size or a smaller gas engines???? Not a lot of people know this unless you own one of these ARF’s made by Great Planes. The P-6E Hawk or my favourite plane of all time the PT-17 Stearmen, both are short coupled bi-planes and therefore need a lot of extra weight in the nose to balance them. The manual recommends approx. 18 oz of lead in the nose, so why not use that weight up with a larger engine??
It seams like the designers at Great Planes are encouraging us to put a larger motor in them. They even give you a nice thick and strong firewall, and ground clearance for a larger propeller. “Thanks Great Planes”.
Because of this you do not lose any wing loading and the Pt-17 comes out to about 25 oz/sq ft, including the bigger engine. These Bi-planes with a bigger motor have an enormous flight envelope, from very slow to very fast and all the thrilling aerobatics in-between. Once you fly one of these bi-planes with a bigger engine like a 160. I guarantee it will become the one you take to the field the most often, cause depending on your mood that day, you can fly it, any which way you want.
Check my Stearman in action with a G2300 engine swinging a 17 X 7 APC prop on You Tube. The Stearman makes contact with the grass, so I called the video “ Parting the Grass “.
BOUND_4_HELL
       Post #: 162
RE: Great Planes PT- 17 Stearman ARF - 2/29/2008 6:08:12 PM
Super08
Status: offline
Looks like fun. I can't wait for spring to try mine out.
(in reply to BOUND_4_HELL)
       Post #: 163
RE: Great Planes PT- 17 Stearman ARF - 3/5/2008 4:43:00 AM
dharrell
Status: offline
Anyone ever tried to put an OS 5-300 radial in this bird? Thanks
Dean
(in reply to Hellcat716)
       Post #: 164
RE: Great Planes PT- 17 Stearman ARF - 3/6/2008 4:13:25 PM
BOUND_4_HELL
Status: offline
This may interest you, Aero-Works has a slightly bigger but similar PT-17 Stearman for sale and they have videos and photos with a radial engine on it. Check them out at
http://www.aero-works.net/store/detail.aspx?ID=232
BOUND_4_HELL
________________________________________________________________
You can check my Stearman in action on You Tube. The Stearman makes contact with the grass after an inverted spin, so I called the video “ Parting the Grass “.
